- Remove Exhaust resonator? Sound?
- still bored and more ideas
- Has anyone tried this
- Santa is bringing a remote start / keyless entry.
- APC 7443 LED's don't work!
- What to use to cut door panel?
- !!!!!!!SPEEDOMETER DEAD!!!!!!!!
- VAFC Check Engine Light ?
- fender well
- SpeedLimiter
- What is this for? (pic)
- 18 psi on a D17...
- Easiest way to remove rear H?
- 1/4 mile !!!!!!!!
- DIY Seat Removal?
- Remove intake manifold?
- Cv joints
- Help on Headlight
- Intake cone air filter rotates or fixed?
- Window Switch for Nitrous
- How to remove the 12V outlet?
- sleeving the block vs block gaurd
- windsheild repair....
- AEM bypass valve
- paint sucks, tiny scratches?
- Need help installing RS front lip - want it to look tight! Acekicker? Niter1dah? Others?
- intake manifold?
- I think my auto tranny is slipping..
- strut tower brace bar thingy
- Any engine experts in here?
- Power Windows, a minor problem.
- Please Help
- Painting the interior
- Tech question on 97 civic
- Vbration around 3000 RPMs
- NEED HELP ASAP
- what should i do to fix these 2 paint things. ~~HELP~~
- projector lights, left side always burn out less than a day
- REMOVING TRUNK SPRINGS FOR INSTALLING OEM SPOILER????
- Did search, no luck! How do you adjust your projector headlamp beam?
- Port work questions...ask away
- moving the clutch reservoir for my strutbar?
- Help! removing seats...
- Which Kind Of Hi/Low Beam Bulbs Would I Need? 02 Civic TYC Head Lamps
- Interior
- coilovers on stock strut
- Would this fuel system work for a turbo setup?
- Abnormal speedometer behavior
- Broken Stud
- uAnyone know how to install strut bars?
- Any tips on removing center trim piece
- Speed Sensor Question
- I just bought a Lower Rear Tie Bar, i need some help on exactly how to install?
- How 2 re-align bolts on rear lower install
- ne1 here with an s2000?
- Removing Head
- Injen Intake hose - SRI vs CAI
- Acrylic dash failure :(
- Does anyone know how to install a new front bumper?
- LED Bulbs
- DIY Clear Head Lights?
- Indiglo gauge wiring
- Installing headers
- Intake Question?
- Why use T3... what about the Mitsu 16g?
- Tranny Question?/?
- rear upper strut install
- Motor Swap Question...
- new custom mod, what do you guys think???
- hanger mounts for resonator
- Heater dont work no air..cruise control not working
- Where to find oem looking spoiler w/0 3rd brake light????
- Stock Headlights
- af gauge
- Tach installed in DX
- Question about hose next to fule line?
- neuspeed strut tower bar installed question
- Car leaking fluid!!
- Acrylic....
- Question for all with painted interiors
- front bumper
- I need some help with a Sun Visor question?
- Cost of Clips
- Where'd you put the gauges?
- Wiring an L.E.D. Scanner (how?)
- installing indiglo gauges
- Wheel Bearings???
- How do you reach your signal bulbs without taking off the headlight?
- Guage cluster
- Need help with spring/strut question.....
- Adjusting TYC headlights? HELP!!!
- Please Help me! Friends Birthday tommoro!!!
- ATF in the Intake????
- o2 sensor problem
- Dash light color change question:
- cant remove my rear bumper.......
- Exhaust
- Need help to wire this stuff[image inside]
- DIY: JDM B16A/B18C5 Style Valve Cover Paint Job
- Did anyone try the Truck springs replacement DIY for 2k2 SEDAN, is it work?
- Question About painting trim
- Transmission Broke Down
- Ride on 7thgen homepage
- How to attach the "H"
- Could I wire one side...
- rsx sway bar bolt turning with nut
- help please
- B series engine swap
- Fluid check?
- VTEC Head Swap
- Cool Place To Install Mini-Tachometer
- Question about high watt headlight bulbs
- Help installing a fuel pressure regulator
- Cleared Headlights and headlight installation
- Whats behind this panel?? PICS
- engine didn't start. . .
- HELP!!!!
- Hello everyone, I m new to the club
- HELP ASAP PLEASE!!!!
- del sol seats
- Integra Seats or RSX seats
- Ex Head swap?
- Fogging?
- Red Dash Lights
- problem w/ brakes, need help fast!!!
- > DX gauge pod swap to lx/ex is this possible???
- Kaminari kit
- RSX type S rear sway bar conversion for Civic EX from Honda Werx - questions from newbie
- ? about hose for injen sri
- Mobil 1 Syn Oil
- CF Hood problem
- help with my body kit
- Having honda install a new gauge cluster......
- tech info on swaps not 7th gen
- List of torque specs & socket size
- Need HELP ASAP!
- Day time running lights
- Clearing Headlights Question?????????/
- question on cvt ??
- once again the rsx sway bar
- Automatic into Manual *not n00b* Honda Techs welcomed
- DIY Installation: RVM Under-drive Crank Pulley
- Making the 7th gen civic shifter tighter?
- Squeaking and creaking!
- Front Upper please help
- _____PROJECTOR LIGHT POSITIVE AND NEGATIVE Q'S_____!
- DIY - EL Tape Sidemarkers (no hole drilling required)
- DIY - Wiring Sidemarkers to blink out of sequence w/ corner turnsignals
- fog lights help
- How to wire sidemarkers?
- ABS brake...how much???
- are air tools needed for rear lower install
- Vee VS. In-Line cyl configuration
- What's the code?
- Removing Rear Domelight
- Warning to all do not goto Wheel Works San Jose on Winfield.
- racing headers?!
- low beams both shot at the same time.....
- Removing rear plastic pillar
- k20 swap....
- bars!?
- painting top piece of door panel - need your help
- Angel eye question
- 0W-30
- DIY Altezza Grill
- do we have a classifed section
- Coolant interval
- HELP ME! DIY for 2k2 Coupe Tail Lights
- Apex VAFC diagram
- DIY Camera Mount? Where?
- Non-EX Sway Bar Parts
- turbo question..revhard
- grinding sensation coming from brake pedal
- Can't get strut tower bolts off to install front upper strut bar... WTF?
- open deck and close deck
- DIY's for previous generation civics
- does anyone know who makes good interal stuff in a good price??
- My rear camber kits..need help
- For those with a shaved trunk...
- clearing headlights dot sae?
- DIY: Manual Shift Boot on AT
- need help quick - easy answer
- Weight on stock 15" Alloys
- tranny gear choices?? can you change them??
- Dent Removal?
- SOMEBODY PLEASE HELP IMMEDIATELY!!
- Very Nice Place To Install Switches
- Idle speed off
- Rear upper strut bar install
- springs thump
- question about tweeter pod??
- no bracket arms
- Yet Another Angel Eyes Projector Question...
- Temperature inside a projector beam headlamp...?
- our abs system....is it different?
- Help on painting housing on headlights
- How do I change my interior color?
- help!!!!
- How many point to raise insurance quotes?
- will s200 motor with tranny fit in our cars??
- Installing rear lower tie bar.....HELP!!
- Turbo manifold...
- DIY Upper Grille
- HP 4-1 Header w/ OEM Header Heat Shield
- Greddy Catback w/ OEM EX muffler
- Service Manual: Idle Speed
- How'd you get the lights to fit?
- eed help on what 2 do???????
- air vents flop around :(
- anti theft for fog lights
- Rear H emblem
- hey civicvtec1ps.... and others....
- top speed sucks
- boooooo my 1st rattle
- e-brake "boot" and handle removal
- Anyone have a VCN400
- Door Fabric
- NX wet kit wiring problem! HELP!!!
- Need everyones help, Checked the DIY's allready
- custom paint !!
- Which Jet sizes to use?
- diy throttle cable?
- Alarm settings - How to change?
- high compression valves
- 4k RPM vibration
- Port and Polish (not your usual question)
- Removal of stock radio
- Custom Axel back Exhaust question?
- Type R seats...
- Q with clearing headlights..
- FUEL PRESSURE REGULATOR
- Seat Harnesses
- Help, cars Chirping
- side mirror
- InJen CAI
- exhaust
- 0-60?
- Where Can I Get Double-Sided Tape For My Kit? (Checked HD Already)
- Ractive Coilovers
- are headlights on EL the same ?
- gas mileage gone south - any ideas?
- h1-h4 conversion?
- HKS Mushroom filter on Injen CAI
- Anyone know which fuse is for tha hazzardS?
- how long does clearing headlights take?
- DIY: Hood Pins *Updated*
- Trouble after CAI Install
- I / H / E
- Full Size Spare
- Oil Numbers
