- srs light
- grounding kit
- ANy one who DIYed door panels on a Coupe...
- Check Engine-0420 code
- Cruise Control Relocation Question
- Washer Fluid Indicator Light Stays Lit
- trunk release idea?
- Need Info about blown engine for 2001 civic
- Cooling Fan
- Jdm D17 Vtec Engine ?
- 2002 honda civic lx 4door
- SEATBELT INDICATOR-ATTENTION 03's
- Dyno Proven power: Injen Short Ram vs. Stock
- Air Filter Bolts won't Come off!
- EASY HU relocation!!! check this out
- head swap
- need your guys help
- A/C making car idle low?
- Pulley making weird sound
- How do you install an Air/Fuel Ratio Gauge in a 2004 Honda Civic??
- Rounded off bolts
- help with 5 lug conversation with vic coilover
- 04 Mt
- Can I skip getting a wideband if I run emanage?
- n/t
- Ac
- Fuel Delivery Problems
- Strange problem... wierd click under dash, rpm drops **Update**
- SAFC2 settings??
- problem shifting hard from 1st to 2nd, please help...
- HELP.......slider removal from factory seat bracket
- Help......pcv Valve - Check Engine Light
- cd player code for civic 2001 ex
- oil pans..
- Engine dies while driving.
- Help on fixing my stupidity.
- help!
- Coolong Fans
- HELP my dash lights wont work
- exhaust tip help
- do i have to cut?
- K2o VS D17A2
- Amp Installation on stock stereo
- Anyone With Crower Stage 2 Cam Help!!
- injector question.
- cigarette light wires
- flashing light location ??
- remote starter problems !!!
- F$#ken Goverment Thing
- anyone try this? (taking the braces out between fogs)
- does tint affect radio reception?
- 99 Honda Civic Si W/ Vafc Ii
- CAI Question
- exhaust tips
- Any 2005 SE Radio Secrets?
- Air condition making my car act funny?
- side repeaters....
- d17 in eg hatch, k20a3 in em2
- k20 swap vs. sti
- How to fix windshield wipers?
- O2 sensor wiring for 04 civic ex
- Need Help...
- rattle
- Port and Polish???
- I have an AC noise too
- Removing Taillights
- why the liquid ITB simply won't work
- how does ecu change timing with temperature?
- o2 sensor..
- engine knocking???
- 04-05 projector headlights on ebay
- Body kit Help
- Liquid cooled throttle body, test phase one completed.
- help with changing cabin fliter
- Oil Pan Cracked!!
- lighting problem
- front lip for civic
- installin RPM meter
- 02 sensor extension for exhaust swap
- Ticking noise under hood
- b pillar plastic cover removal
- numbers under digital mileage
- Body kit
- '02 SI steering wheel on '01 EX???
- messed up throttle?
- Body kit or lip kit
- Throttle Body Heater Bypass - WHO HAS IT!
- Urgent Gauge Cluster Swap Question Question
- Can you paint a CF hood, and is it worth it?
- Engine Swap
- Removing DX Door Panels
- want to put in 03 si steering wheel in 02 civic lx, HELP!
- A Pop, and wierd first gear? Help!?
- a/c removal for turbo..
- Injen short v.s Injen cold
- '01 Sedan Keyless Entry Questions
- Where is A/C service port?
- Type r grille fit 02 coupe?
- A2 Pistons in A1 motor
- short throw shift adaptor
- [UPDATES - DEALER] Help me! Relay problem? Cable shorted??
- [COMPLETE STORY] Some electronic messed up Help!
- auto to manual
- a/c not cold enough
- AUTO - Standard Conversion
- throttle adjust
- 2nd Alternator shut down! *LOOK*
- 02 Civic - A/C Problem
- Check Engine Light Problem
- Need help with Viper 791XV IGNITION
- How to remove trunk molding
- bleed brake fluid
- bleed brake fluid
- Simple question concerning A/C
- Checking your MPG?
- Air conditioning mouisture?
- burnt ceiling..
- Service manual
- Smoke spitting Prelude...
- starting problem/sort of
- Asap...does A Rear Si Bench Fit In A Sedan ????
- dx cold air intake into a ex ?
- headers,hi-flow cat, exhuast fitting?
- (QUESTION) No A/C in my 2002 Honda Civic Coupe DX
- Cheap mods that wont void warranty?
- headlight question
- Battery Light Issue
- Will gutting the cat help performance?
- glove box removal
- Is this part needed for pressure in my slave cylinder?
- o2 sensor ?
- New ecu
- Noise - upon startup
- no A/C in my 2002 Honda Civic DX Coupe
- How to remove side lining?
- amp mounting on 04 civic sedan
- battery died
- how to paint interior?
- emanage not controlling sub injectors
- Stock Clutch or Aftermarkert
- help install vafc2!
- quick question
- Strobe under car kit
- ??diy Axleback???
- CEL problem?
- A/C problem
- diff. btwn resonater and high flow cat.
- low end power?
- Removing Center Console ( Manual Shift Boot )
- sedan people with SI Seats...what did u do about the rears? *and side AIRGBAGS*
- Will 01-03 front bumper fit an 04?
- how different is mannual iac and auto iac?
- Electrians help!!
- body kit installation
- Mid pipe Question
- ex/si catback exhaust on my lx.. will it work?
- 01-03 fogs wiring with 04 switch problem, illumination and indicator reversed
- Anyone Know How To Install Projector Headlights
- Please review the condition of my spark plugs! [RESOLVED]
- E-manage questions...
- Driving with e-brake on ... how bad can it be?
- help my car was hit from the front
- Door Rattles
- Engine light. . .is it time to mod?
- ecu re-mapping
- will this Tenzo seat fit our car??
- air filters for stock box
- Civic Axel
- High RPM Mods
- Acceleration is DEAD!!
- what size is better for the power
- need help findin a way to run exhaust with cat
- Dash Lights
- Engine weights
- Your mods = ? gains?
- Anyone know how to adjust idle range?
- D16Z6 and D16Y8
- Turn your fans on Manually
- clearing TYC's
- Who has the List of all the TSB's for the 01-05 civic?
- Squeaky Rear GroundControl...
- D18 if you cant find it here.
- Towing
- megan resonator/greddy evo 2 ????
- vin # required for new seat belts?
- power stearing
- Carpet Dye Protectant?
- What paint is best to black out headlights?
- D17A9 Tuing
- Help with cluster swap auto 04 into 02
- Broken bolt and LX > EX exhaust questions
- lx to ex header?
- Part # For Throttle Bodie Nut
- Custom Cold Air
- Civic VP engine internals?
- 99 SI -Main Shaft bearing - transmission
- 60,000 mile Transmission fluid change
- redline problem
- Trunk Spring reinstall?
- VAFC 2 setting please share.......
- cant take oil pan off, help
- People who have done head swap
- Tightened E-Brake, any opinion?
- Good exhaust set-up?
- whats the point of all this spaggetti?
- Problematic intake air temp sensors?
- Exhaust for LX
- Transmissions that fit our cars?
- rsx axel back and bpipe
- Trunk/Fuel Door release cable replacement...
- rsx shift console in civic 01
- Door Panles
- what to use
- Thread size ?
- HELP: Car Wont Start, rapid clicking noise
- Does anyone know how to make the rear seatbelts release?
- Air/Fuel Ratio Gauge
- Intake hiss
- A/C Problem
- 7th Gen noob Q.
- What does this trouble code mean?
- No Pressure on My clutch Pedal
- what is normal idle RPM?
- AC in a k20 7thgen?
- PS Fuse
- When does VTEC work?
- redline problem on a auto hx
- braking noise
- Header hitting sub-frame?
- CAI of a DX/LX on a EX???
- Anyone heard of LUK Gold Series Clutch?
- Engine help?
- FIPK2 or Typhoon?
- help, axles????
- speedometer
- Alternator Sensing Wire
- hi flow cat question?
- headlights, blinkers DONT WORK?!?!?
- Problems with the SRS light in my Civic 2001
- Ex Header/Exhaust fitment on Dx/LX
- Bored? Clean your grounds.
- MUGEN TWIN loop -05 civic
- ex head swap
- HID's Install Question
- headswap n cams ?
- headswap n cams ?
- Red Wire. White Wire. Picture plzzzzzz
