PDA
View Full Version : General Honda Civic Forum Archive.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 [56] 57 58 59
  1. ATTN: POGI/anyone that's gone through the firewall
  2. EGR valve
  3. DIY: Installing Apex'i S-AFC
  4. HX => EX?
  5. HOW TO ADJUST HEADLIGHTS
  6. where is the parking light fuse!!!!!!!??????
  7. OK...let me get this str8 (about N2O) Experts please post.
  8. exhaust question
  9. exhaust hurting performance!?
  10. if i see another "what size or kind of rims?" post again
  11. What size rims?
  12. AEM OE Brake Upgrade Question
  13. shift boot for 5-speed
  14. M3 signal wiring
  15. S2000 steering wheel?
  16. are lightweight rims strong enough for everyday use?
  17. Port and polish
  18. ATTN Grey
  19. idea for returnless fuel system
  20. Dropping your car / rims...
  21. Ignition wire....
  22. Coilovers-- again
  23. MPG Tuning question
  24. Tach test connection
  25. HID Shield Question
  26. Throttle Cable Adjustment *HELP*
  27. help
  28. leaking strut
  29. coilovers???????????????????????????????
  30. JUST RECIVIED PULLIES: HOW DO I PUT THEM IN
  31. PROBLEM WITH CLEARING HEADLIGHTS, TWO VERSIONS OF HEADLIGHTS
  32. where did you put your dimmer switch?
  33. Hp Header "New distributor Post" READ-Retitled by ALLMAN
  34. Questions about R1 Racing Single Coilovers & Tokico Shocks
  35. Need Some Suggestions For Friends Tranny Problem
  36. match PIAA Xtreme Whites..
  37. WW Side Skirts coming off :/
  38. Coil-overs vs. springs
  39. QUESTION ABOUT BODYKIT AND LOWERING
  40. Cat and Streight Pipe
  41. resetting the ECU
  42. Neuspeed Sport Spring Installation Question
  43. Suppension
  44. Stock Fender Gap???
  45. ?17" Wheels/Tires?
  46. DX/LX to EX Cat swap?...Grey
  47. AEM CAI sound?
  48. Should I really try it.
  49. Help Mesh grill!!!!
  50. I need mad HELP
  51. two big black boxes under the hood
  52. throttle
  53. ATTN: THOSE WITH KONI STRUTS
  54. sub instalation
  55. Need help on neon wiring in trunk! Won't turn on when it's supposed to!
  56. Anyone cut there shifter down themselves yet?
  57. Noob lookin to lower his car...
  58. has any1 adjusted their koni height? Attn: mwwhonda
  59. ATTN: All those with 215 width tires
  60. spare tire under the car
  61. Installing Racing Seats?
  62. Question About Installing Koni Yellow Shocks
  63. Change The Climate Control Light Color
  64. led lights on the dashboard!
  65. Who was getting the turbo?
  66. DIY DC INTAKE & EXHAUST
  67. TIRES!!!!
  68. anyone have a repar manuel for a 2001 civic?
  69. 17's and speedometer
  70. Tuner Lug Nuts?
  71. Headlight Aiming
  72. What's the diff for healights bulbs!!!
  73. OBX B3 Bomb Exhaust?
  74. NEUSPEED UPPER FRONT STRUT BAR INSTALL HELP!
  75. ss adapter install
  76. installing tail lights
  77. Where do I wire a neon in my trunk?
  78. Safc on civic ex/si!!
  79. no muffler=performance??? or rice????
  80. ~*<> KeYLeSs EnTrY <>*~
  81. NOS HELP!
  82. shift boot for auto
  83. Camber Kits
  84. HOW DO YOU GET THE EBRAKE HANDLE OFF???
  85. DOES ANYONE HAVE PIC OF BLUE DASH BLUE SPEEDO?
  86. how do i get that sound when i shift?
  87. AEM short ram intake
  88. kaminari and lowering
  89. FLASHING!!!!!!!!
  90. switch install, need help
  91. trbomax, turbonator, spiral....etc
  92. Look what i found in are civicssss
  93. HOW DO YOU DUE YOURE DASH BLUE?
  94. Tranny?
  95. Turn Signal question
  96. HKS turbo results question
  97. what about smaller pipe?
  98. Push Button Starter ???
  99. muffler mounted weird? need help!
  100. PIAA Fog Lights
  101. why 2.25 inch piping
  102. Power shifting Q's
  103. What type of lug pattern do we have?
  104. Trunk Light
  105. DIY:make ur own CAI/SRI
  106. insulation
  107. DIY on trunk????
  108. Safer?
  109. vtec switch point
  110. throttle body
  111. Wiring To Park Lights
  112. 2k2 LX-G .......factory stabalizer bars...hmmmm
  113. Problem with my Eibach Pro-Kit
  114. maintanence light
  115. Map Sensor??
  116. DIY: Throttle-Body Heater Bypass
  117. [ 4-5 lug conversion : via RSX swap ]
  118. air filters
  119. Painting Interior Trim Pieces (In Canada)
  120. Attn Civic Punker 17
  121. Who has H&R springs?
  122. Do your CD's Skip ??
  123. DIY: Rear Deck Spearker installation
  124. Strut Bar Question
  125. how do you get tha handle off
  126. port and polish?
  127. window tint...need help asap
  128. Attn: Boosted... I need knowledge!!!! Please??
  129. Painting exterior trim pieces
  130. CAI Problems
  131. GTR Kombat Spoiler??? Help (Sonsonzai)
  132. Question AEM CAI w/Bypass
  133. ECU, need help quick....
  134. manual knob on auto
  135. Glow Pedals
  136. Washing with an AEM CAI
  137. painting interior
  138. Need some suggestions - automatic shift knob
  139. Front type r upper grill - painting
  140. People with Reverse EL gauges!! PLEASE HELP!!!
  141. Duplicolor Paint for engine bay trim?
  142. blew a fuse w/leds
  143. Fuel Filter Question
  144. Skunk2's
  145. HELP ME WITH MY ALARM
  146. OEM Paint Supplier
  147. Question for 2k1civic.com
  148. DIY Remove Resonator Box
  149. droppin the civic
  150. Altezza tail light CONDINSATION!!
  151. Gauges...
  152. How to Book...
  153. New Interior Ideas
  154. DIY: Hard-Wired Radar Detector (EX Only)
  155. 2k1 to 2k2 cupholder converstion
  156. EL Gauges install
  157. AFC controller
  158. tire balancing
  159. Location of your Street Glows
  160. LX and EX stock wheels & tires
  161. Coilover Question?
  162. Anyone with Tsunami front bumper
  163. interior trim DIY Folly
  164. Need Shocks Information
  165. Swapping to a 6 speed tranny
  166. head unit question on EX....
  167. to change automatic to manual
  168. Sealing DIY Headlights?
  169. EXTERIOR PAINT
  170. Interior Help
  171. air bypass valve
  172. HOW MUCH WOULD A NX NITROUS INSTALLATION COST?
  173. Front upper grille
  174. Attention all BC Members I need your help
  175. stuck front bumper!!!!!!!!!!!!!!!!!
  176. Another Nitrous Question
  177. Tricked Trunk question
  178. Need help clearing headlights
  179. Spinning Tires?
  180. Wiring Harness
  181. finally completed my major mods.. can help if needed
  182. Concerns with HX lean-burn system
  183. Removing the stock headunit
  184. What's the deal with the a/c DIY???
  185. Just an FYI...Because it freaked me out !!
  186. ???Projector Help
  187. SMOKE KIT ANYONE?
  188. Ingalls rear vs. shimming
  189. Grille Mesh Install???
  190. EX head on LX?
  191. Injen Race Division Installation
  192. raceing seats!!!
  193. 4dr Tail Light installation help...
  194. Gauge Cluster Help!
  195. 3 pc. racing hart damage
  196. Stripped Screw
  197. Taking out inside roof?
  198. Apex-i Rev/Speed Meter
  199. A/F Guage problems
  200. Installing Hose kit on Lx sedan
  201. how low can i go
  202. HELP!! Curbed My Rim!!!
  203. i need help with my nx kit!!!!!!!!!
  204. stock wheel weight?
  205. cutting the AT stick?
  206. front strut bars and intake fit
  207. When will the CAI become...
  208. Intake NEED HELP!!!!
  209. whells/springs Q's
  210. HELP ME CLEAR MY HEADLIGHTS!!!
  211. Taking out stock CD player??
  212. Neon Tube Placement
  213. Regarding the "auto trans hack"...sorry guys
  214. Found unkown part...help?
  215. can i change my spoiler
  216. how to install euro tails!?
  217. shave emblems
  218. Paint bezel or visor. Does it reflect light ?
  219. ATTN: ToastyGhosty
  220. Wiring question...
  221. trunk springs??
  222. black sh*t on the chrome (clearing headlights)
  223. Camber?? Ground Control?? WTF
  224. Painting Spark Plug Cover, HELP!
  225. If you have a Type R shift knob on your Civic... HELP ME!!!
  226. problem w/my nos
  227. adding a tachometer
  228. changing gear ratios on 5-speed?
  229. AEM CAI, Problems???
  230. Problems wiring to Ciggerete lighter
  231. [ Possible to use NSX auto-trannie's? ]
  232. where the diy hyperblinker for the ex
  233. What happened????
  234. ex to dx swap?
  235. when you put your springs in...
  236. HYPERBLINKER on sedan,anyone?i tried but i failed
  237. DIY sidemarker install???
  238. DIY flip/flop trunk !!!!!
  239. More HP?
  240. Cam for Dx?
  241. How do you wire extra speakers?
  242. Seporating Streetglow wires
  243. body molding??
  244. Computer chip????
  245. Quick question on Civic hoods.
  246. FULL CAT BACK Exhaust? / Chrome or Ceramic ?
  247. Weapon R Rear upper strut bar ?
  248. Fried Motherboard for blinker relay!!! need help!
  249. For those intere in SS and SS Adapter!!
