PDA
View Full Version : General Honda Civic Forum Archive.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 [29] 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59
  1. New at this: I need member's HELP!!!
  2. Prepping a used kit question.
  3. Steering
  4. CLEAN oil filter removal?
  5. Bulldog remote starters....
  6. DEI 555I or DEI 555H?
  7. VAFC 2 on my ECU?
  8. Help with odometer
  9. C.A.R.B. E.O. certification
  10. coupe tails on a sedan?
  11. Has anyone replaced their fuel filter..
  12. diff on EX and LX muffler
  13. wheel shaking when turning right
  14. Fuel tank = Upside down Triangle
  15. halo damage prevention
  16. What is wrong with the security system.....?!
  17. In need for someone with a 2001 civic Helms Manual
  18. Adjustable Fuel Pressure Regulator
  19. Projector to Stock Head light
  20. Is it better to buy black or primed?
  21. Battery and Digital Capacitor question
  22. apexi auto timer
  23. apexi silencer hardware install
  24. lambo doors..
  25. the technical side or RSX seats and SRS??
  26. Got bored so did some wiring/installing!!
  27. Good news from MSD!
  28. tyc tails and lights
  29. How much brake fluid do I need?
  30. bore
  31. "Parking light" fuse
  32. ECU q's
  33. dash replacement
  34. Eye lids welded on the hood.....
  35. Driving w/o front sway, bad?
  36. Pulling
  37. tranny fluid
  38. stripped out civic
  39. need help with hood pin problem
  40. Need some help installing generic cai...
  41. How-To Paint your Tail Lights!
  42. Need Help with intake?
  43. I need an intake manifold/injector base gasket NOW!!
  44. putting fiberglass over your dash
  45. Help interior paint removal
  46. rear disc conversion
  47. oil pressure dropping part 2
  48. CEL, I know the code, what to fix?
  49. Voltmeter power source?
  50. headlight install....no keyless entry???
  51. are the internals the same?
  52. Can you take out the black part in the front bumper?
  53. SOHC Throttle Bodies
  54. Header Question!!!!!!!!
  55. Help with Torque
  56. cam gear
  57. How do you get rid of the "maintence required" light?
  58. question with gauges?????????
  59. oil pressure dropping
  60. Really cold weather performance?
  61. re-aim lights after bulb install?
  62. taking off the head
  63. Exhaust system question
  64. Speed governors
  65. Copper head gasket
  66. lighten flywheel?
  67. revo SS
  68. Any info on trans coolers?
  69. ABS light on in the snow???
  70. Piston specs
  71. performance without the $$$
  72. first time I come to you for Help...
  73. Installing my tranny cooler
  74. Help! Chip in paint on hood.
  75. LX headers
  76. DC sports headers work on DX/LX
  77. can i get colder air
  78. tranny
  79. Need Help Asap
  80. auto start DIY?
  81. focuz high flow cat?
  82. help..car wont start
  83. 60' times (sorry for Repost)
  84. SRS Unit
  85. Please Look 2001+ D15B??
  86. Grounding the alternator??
  87. air bag light
  88. clicking....
  89. engine code
  90. Anyone with Unorthodox Crankshaft pulley
  91. do you have this?
  92. NX Express kit part # and best price
  93. Serious Spark Plug DIY question..
  94. Aem Fliter Cleaner?
  95. !!!o2 simulator question!!!
  96. engine swap question??
  97. Has anyone paid Honda to do valve clearancing?
  98. Anyone know the specs for all civic models?
  99. Push button start with no key?
  100. stealing car
  101. Engine Swapping
  102. Just need a yes or no answer if I HAVE to take off front bumper 4 headlights...
  103. Need Help Locating The Fuel Injection Air Control Valve
  104. SAFC2 wiring diagram
  105. Help~~~DIY for Reverse Glo Gauge (Manual)
  106. engines out the ying yang
  107. valve springs and titanium retainers?
  108. spec on camshaft????
  109. what is different?
  110. spark plugs?
  111. 2004 Foglight Install
  112. Bolt started to round-off
  113. Spark Plug Gappin'
  114. clutch shaking?
  115. Locks kit to alarm
  116. DIY Indiglo gauges (94 accord)
  117. K20 swap or Turbo w/D17 ????????
  118. WHY? WILL it?
  119. header touching the frame
  120. price for kamninari kit ??
  121. carbon fibre altezza grill question?
  122. 2001 Civic defrost/air conditioning
  123. Civic si seat swap
  124. tech @ honda suggested i would (see for details and Q)
  125. Timing Belt Tq Specs
  126. DIY Clearing headlights Question
  127. Pistons
  128. push button start!!
  129. Is this possible??
  130. Painting Exhaust????
  131. For all you DIYourselfers out there
  132. LX-EX exhaust swap people!!
  133. nitrous/02sim/airfuel gauge
  134. Installing Header! Need help now!
  135. AEM cam gears and stuff?
  136. skunk2 coilover install help!
  137. passenger lock does not work
  138. question about our gauges.
  139. Dhracing Group Buy Is On Tonight!!
  140. Questions about clearing lights...
  141. ame pulley
  142. need help putting on a str cam gear
  143. help
  144. 911 911 911 hp header help
  145. who has xenon
  146. 2003 civic si tech info
  147. Can I make this fit my car?
  148. ECU Upgrade Program 65001
  149. Need Help (Oil Pan)
  150. Intake manifold
  151. Internals done pics
  152. n2o kit from a different...
  153. 99 civic bolt on exhasut
  154. DIY servicing
  155. Painting parts under hood.
  156. AEM V2 Question
  157. What size pod do I get for this Boost Gauge?
  158. AEM SRi???????
  159. Where is Manual Transmission Fluid Reservoir in the Engine Bay. ??
  160. car swaying after replacing wheels and tires
  161. im haveing trouble putting on my coilovers
  162. cleaning an injen cai filter?
  163. oil change question
  164. stupid vafc post #2
  165. stupid vafc!!!
  166. Just install my v-afc 2
  167. help? turn check engine light off
  168. RSX exhaust on a 99 dx?
  169. type B rear lip modification for coupes
  170. Apexi VAFC II **Complete Fix**
  171. lx high flow cat ?downpipe?
  172. Help, ASP
  173. Help Now Please!!
  174. How fast does a 2000-2004 Civic EX go to 0-60???
  175. Taking off front fenders
  176. Aftermarket catalytic converters - how did some of you get around EPA regulations?
  177. first and second gear lil lose/soft
  178. V-AFC, settings
  179. lowering my car
  180. What is the Apex'i S-AFC & What does it so exactly?
  181. taking apart lens half
  182. 2001 2dr civic ex exhaust questions/problems
  183. vent removal
  184. Tech Help Needed: How to Remove DBL Sided Tape!
  185. what type of engine?? vin number on engine??
  186. driver door problem!
  187. Tips for removing stripped lug nut?
  188. Special tool for rotor removal?
  189. Can't turn off alarm HELP!!
  190. EX Fuel Cut
  191. Stock Ex Fuel Cut
  192. Body Kits
  193. Clearing my headlights....question about DIY
  194. Belts and Fan Belt
  195. okay yet another post on the 0W-20 oil
  196. 02sim-AFG
  197. How to turn off SRS light?
  198. vtec HELP!!
  199. Best oil or most commonly used?
  200. will this work well?
  201. short shifter problem?
  202. repairing headlights?
  203. Cleaning the Engine..
  204. broken bolt HELP!!
  205. Honda Diagram need help
  206. DIY: Polyurethane Motor Mounts
  207. Spark Plug Replacements..
  208. AEM V2 and rain
  209. Euro lights
  210. Popping outta 3rd Gear
  211. Help for my Headlights!!
  212. Short Ram Intake Question
  213. look at high flow cat !
  214. sequential gearbox
  215. taking off oem spoiler...diy:filling the holes?
  216. which downpipe ? high flow cat ?
  217. advance ignition timing ?
  218. Rear Spring/Strut Install Question
  219. scratchy sound by wheel...
  220. service soon light again
  221. Gauge vent mount DIY?
  222. Prepping polyeurathane
  223. change antifreeze help
  224. autocross tuning
  225. Turn signals
  226. Why do people hate on air intakes?
  227. Air Filter directly on Throttle Body
  228. stock lx exhaust specs
  229. what clutch to get
  230. oil change question
  231. tuning a 2001 honda civic lx
  232. Problems with Apexi Vtec on 7thgen
  233. Front Strut Tower Brace & Intake????
  234. for the techies! ignition system ???????
  235. Steering Wheel Removal Problem
  236. restarting car when its on already
  237. Skunk2 D-series Intake Manifold.......
  238. Field Vtec Controller Installation and Comments
  239. Have any of you had this issue?
  240. silencer removal
  241. s-afc 2
  242. Maintance Light Solution
  243. just hit 40k... what should i service
  244. the Injen works
  245. need help quick
  246. Cleaning the Throttle Body..
  247. Aftermarket oil pan...
  248. hybrid gauge lights?
  249. nothing turns on but the lights (inside and out)
  250. Stupid Oil filter question
