spec on camshaft????
Old Jan 13, 2004
nongv's Avatar
nongv is an unknown quantity at this point
does anyone know the spec on our stock camshaft and the older civic stock cam shaft? will they older one fit our car? i got a older stock civic cam shaft (the 93 civic si one) and wanted to try it but need the spec on the cam shaft to see if it is better than our cam shaft.
Old Jan 13, 2004
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
I highly doubt that it would fit. But if you want specs on a D17 camshaft:
End Play: 0.05-0.15mm
Camshaft-to-holder oil clearance: 0.050-0.089mm
Total Runout: 0.03mm
::: D17A2 Lobe Height :::
VTEC intake primary: 38.604mm
VTEC intake secondary: 32.848mm
VTEC exhaust: 38.784mm
::: D17A6 Lobe Height :::
VTEC intake primary: 38.427mm
VTEC intake secondary: 32.193mm
::: D17A1 Lobe Height :::
Intake: 35.299mm
Exhaust: 37.281mm
Old Jan 13, 2004
nongv's Avatar
thanks for that but do you happen to know the Duration and Lift of our camshaft?
Elciteeve
Sep 28, 2015 12:40 PM
fvckbg
Sep 8, 2015 09:55 PM
thaler4cuse
Sep 7, 2015 08:25 PM
Chameleonman
Bolt-on Engine Performance
Sep 5, 2015 04:06 AM
WaryDriver
Aug 16, 2015 11:22 AM
