Pulling
Old Jan 25, 2004
civicstylz4u's Avatar
civicstylz4u is an unknown quantity at this point
Question Pulling
I have a 2003 Civic SIG, it had the OEM firestone tires on it, I had a problem with them shaking so I changed them for Michelin Harmony tires which are incredibly smooth but my car always pulls to the right even on a slow acceleration. When I am cursing up to speed my steering wheel is straight and the car drives in a straight line. I have sent it back to Honda where they have performed now /....are you ready 6 wheel alignments and it has not been fixed. When the car is cold it does not pull too much but once it’s warmed up or the tires are worm it will dart towards the curb. If I excel hard the wheel turns fast to the right. When I got the car it never did that. Took it back to Honda, where they checked the suspension. Do you think it’s the tires since they grip really well??? I need help on this, car only has 9,000KM only 6 months old
thanks
sean
Old Jan 25, 2004
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
sounds to me like your alignment is messed up even though its been in 6 times. but it could be your suspension.
Injen
Old Jan 25, 2004
Philip's Avatar
Philip is an unknown quantity at this point
hmm....which dealership did you buy your ride at? Kingston Rd? I got it from there and same thing happened, at first i thought it was torque steer cause our ridez are FWD. but than again i found that my wheels weren't balanced from the factory. than i just got a 4 weel align. + balancing from warranty + my is a 01 SI, so there were a call back for front struts....and i got those fixed too.
Old Jan 25, 2004
Lek's Avatar
Lek
Lek is an unknown quantity at this point
I had a problem like this for a long time and it drove me crazy. It turned out to be defective bearings on the tops of the struts. They're very cheap to replace if you have someone to fit them.
Point this out to your technicaian.
Old Jan 25, 2004
Exclamation Pulling
Really, so struts can cause the car to pull?, the funny thing is I took my car to formula Honda on more then one occasion where they had my car for more then 2 days inspecting the front end. I got my car from Parkway Honda. I also had one rim replaced as there was a round out. I have given up.. The people at Honda keep telling me it’s the nature of the car. And I tell them so you’re telling me that Honda now has a new feature.....buy a civic because it will pull to the right without you having to steer??? Give me a break. Do you think it’s the tires? What kind of tires do you have on your civic?
Old Jan 25, 2004
WhiteCastle's Avatar
yes this is true I brok my struts in the crash and had to have them replaced
Old Jan 26, 2004
tfnaaf's Avatar
BLDNPSI Mod
I would have to lean more towards its the nature of the beast. You say it only pulls under HARD acceleration? Well like someone pointed out something would have to be worn out Or its just good old torque steer.
Old Jan 26, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
1. Check your tire pressure, make sure they're even.
2. Under hard acceleration the car will pull, its an open diff., thats just what happens.
3. Yes, if your struts are blown or the bearings are bad, it will pull to the opposite side from the bad one (if its going right, your left front may be bad).
Old Jan 26, 2004
gizcivic's Avatar
gizcivic is an unknown quantity at this point
my boy has the same prblm he had all 4 rims and tires replaced and
balanced all 4 aligned and still has the prblm
SimpleUser
Apr 24, 2021 02:54 AM
juror
Suspension DIY
Jul 30, 2019 03:28 AM
mrohitredd
Aug 12, 2015 11:36 AM
tattedlariat
Aug 4, 2015 06:35 PM
Green02civic
Jul 27, 2015 10:48 PM
