- Headlight Question
- Car shuts off when driving?
- Stock washer nozzels wont fit CF hood
- PCM ECU Codes CEL BLINK Code ...and Rant
- How much whp?
- WTF is Backpressure???
- ex header on a HX
- ex header on a 01 HX
- Carpet Taken Out?
- Leaky Trunk
- Clutch Peddle
- kamikaze header
- Tranny
- f-1 engine
- Moving the AC
- Im getting p1607
- Help Overheating
- shakey stiring wheel
- A/C question....
- wireing a remote start on manual
- A/C Recharge Question
- Immobalizer
- safc 2
- srs light
- What does this code mean...
- Project: Hater-aid
- maintance light blinks
- Weight of the "Si" alloy OEM Wheel?
- Where to find certain parts
- Fogs only on iwith lights?
- D17 rocks!
- Fixing scratches on door panels
- P1361 TDC Sensor Intermittent Interruption
- New Springs...
- clutch and flywheel
- Do you really need to have the bushings for short shift?
- Anyone Have A Diy Rsx Injector Install?
- Anyone Have Diy Rsx Injector Install?
- HELP need to recalibrate gauges
- Brake vibration
- Stock Paint (other than touch up bottles)
- Caliper...
- 4 dr. diet
- 01-03 coupe taillight trick
- Putting on S-Tech's, do i need shocks too?
- just a question
- Normal for radiator fan to turn on much?
- Car shakes when reachin speeds of 60MPH and more!?!?
- Remote entry problem
- Drivetrain shudder in 2002 Civic
- Random Tech. on an LX
- breaking in my new clutch
- please help if you have service manual
- Need to find...
- warrenty - CV Joint
- Need Help Asap
- Will the Apex VAFC 1 or FIELDS VAFC work with the 2001 civics??
- Problem with a accord
- Installing Volt Meter
- VTM wire
- Very Serious braking problem..Help..
- clutch pedal question
- Displacement
- flywheel bolts...
- engine light need help!!!!
- Changed oil help...
- WHat you guys use for gaskets
- Ignition key programming on Honda Civic
- tinting/tail light cover?
- Fixed my sunroof rattle
- wheres my ecu?
- Sparco seats/steering wheel & SRS system?
- short shifter install help
- Rattling at rear driver's side
- amp cuting out
- regrind from Gude?
- Is it possible to re-calibrate speedo/odometer?
- HELP...its getting dark and i cant get my mirror apart
- o2 sensor question
- Another stupid VAFC question
- Another Cold Air Intake Question
- power window fuses blowing
- o2 sensor problem
- Crazy Tech stuff with CLuster and Comp.
- To get SRS light reset?
- air conditioning...
- Air conditioning...
- taillight bolt broken-help!
- Anyone with Arizen seats?
- o2 sensor pulled a check engine light!
- Proper cold tire pressure for 04-05 Ex coupe?
- Ipod to Factory Radio Without Adapter
- ECU help
- Shitty start up after rain
- car cuts off and on radomly
- Problem my car bogs
- lost steering last night
- Pleae help? I need cluster wiring diagram 02 civic ex coupe
- Tenzo R Rallye-2 Seats
- custom intake heat shield
- grounding TB to chassis or neg post
- Fog Lights
- intake heat shield--need ideas
- Converting center console to 01-02
- 6 grand what to do?
- seat belt colors
- Need A1 regrind spec sheet
- intake temp and rpms?
- Smoke out of exhaust?
- HELP with headlights
- aftermarket header and stock downpipe
- air fuel
- Details on DIY blacking out headlights on 04+
- MoMo DIY Install Help!
- Thermostat? Pump? ehatever, its a major issue now!
- Throttle body
- Head Porting Questions
- A Few Issues, may have heard of some already
- Exhaust Install
- dual halo projector bulb fitment problem
- I would like to install a lap belt.
- Can sedan seat belts fit in a coupe?
- D17a1 bottom end
- High Reving Engine?
- blacked out my headlights!! (updated with pics!!!)
- Projector TYC HID problem
- solutions to muffler moving around on rear bumper
- i lost power from my evo 2 exhaust!help!
- New Header
- check engine light question
- dry ice
- altenator
- third brake light flash issue
- Rear RSX Seats
- taking out airbag
- New cat..loud and o2 went boom HELP
- vtec setting for ex with vafc 2?
- need help asap !!!!
- Windshield Seal Fix?
- weird running problem
- 02 wire color? quick help please!!!
- Anyone know how to remove side molding on an '03 sedan?
- Do they make JDM parts for our cars???
- cruise control wiring
- What size are the threads on the shift knob?
- Car putters on start-up and I've seen white smoke coming out of tailpipe
- car suddenly won't start... rapid clicking noise
- DIY request: coin/change department
- scratch marks on dash
- Is it hard to get into the outside door panel??
- What would be the best way to "move" The EX HP to lower end?
- Exhaust for sale! (AGAIN)
- rsx injectors into fuel rail
- Removed seats, now SRS light is on!
- Gauge cluster swap
- Fuel Line?????where Is It?
- To those who have driven both EX and LX..
- Smoked Tails
- srs light stays on
- question?
- Check engine light help
- using window tint on taillights
- dropping to D2 from D in auto
- clicking sound when starting
- What it take to make a JDM smog?
- Changing plugs
- Tach Install for DX
- Auto Gauges
- What is the best oil filter wrench/tool out there?
- spc camber kits
- pic of part
- D17 VTEC head swap
- D16 valve cover
- Question on fuel filter
- Stock airbox + curiosity= interesting conclusions *update*
- Brake Booster line!
- Mysterious smoke from the column...
- Isn't there any chip tunning for our engines??
- clearing headlights
- A/C Expansion Valve
- Pictures of under dash and behind dash, please help point out FUel pump relay
- Please help with the fuel pump relay
- Help Yal! Unnecessary Vibration
- Average cost to replace alternator?
- New 05 EX starts hard
- hand brake
- Size of seat belt bolts
- Where to find OEM parts?
- Shorter clutch pedal throw?
- Only a few N/A mods to go! Will post Dyno Pics
- WIll an ex aftercat o2 sensor work for dx?
- LED #'s In Dash
- Fuel Pump Fuse Location
- Sway And Strut Help Alot Or Not
- Hole in radiator
- Has anyone been successful in DIY power door lock (replace actuator)?
- 05 Civic Head Unit
- OEM crank pulley
- RPM Limiting
- replacing headlight bulbs
- Question about Headers?
- brakes
- dual a/f guages
- Side skirts wont stay up help!!!!
- exhaust size
- Cam/Spark Timing questions
- crank pulley problems
- emissions
- oil problems
- k20 or k24
- Installing spoiler
- 97 cluster red lights
- turbo or supercharge
- PLEASE HELP! Wiring Diagram for Stock Fuel Pump Harness
- Self tighten crank pulley bolt?
- mods
- D17 Crank Bolt
- SAFC and SAFC2 wiring instructions
- Just Installed HO Alternator, Voltage reg. Prob??
- Headlights.
- emmision light is on
- Anyone running nitrous and a turbo?
- Turn Signal Problem
- NOS: what kind for pre throttle body? FOG kind?
- Question regarding Fumoto Oil Drain Vavle
- Vibrating idle with 17,000 miles. HELP!
- taking off the tailight on a coupe
- Need help! Problem on 05 LX
- Sticky Stuff On Rims...Help...
- Spring Compressor Help!
- Stock modded intake
- Fuel correction on vafc2
- Intake
- K&N Drop-In Air Filter
- Converting to Right Hand Drive
- Spoiler
- Automatic to Manual Conversion
- body
- Does anyone know the gains when swaping out the injectors to RSX ones?!?
- 2003 civic coupe hood fit a civic sedan?
- sun grounding kit vs DIY kit
- What material?
- Intake Breather Hose
- Whisle noise when AC is on???
- Problem with ex header?
- Speedometer Drop Out
- Exhaust Installation
- Squeek! Squeek! I'm fvckin tired of it!!! FIXED!!!
- Speedometer ?'s
