Stock modded intake
Old May 11, 2005
Killacamshaft's Avatar
G'z UP
Killacamshaft has a little shameless behaviour in the past
Stock modded intake
Since its not a good idea for us to get a sri or cai(wich i already have) Is ther eny way we can mod the stock one to be better or take ideas from it to some what make a better one just curious.
Old May 11, 2005
In Catalyst's Avatar
In Catalyst is an unknown quantity at this point
I sorta custom built an intake. With a blend of a cai AND an sri... I replaced the stock air filter with a k&n drop in filter, then removed stock resonator etc. I then built a pipe off the side of the airbox which goes down to a cooler air level.
Benefits of this are the placement of the filter being at top so I am not worrying about moisture, and I still get a cooler air, faster.
Old May 11, 2005
JesterMasque's Avatar
...ever grinning...
JesterMasque is an unknown quantity at this point
Got any pics? Also, there seems to be a controversy with the K&N drop in. What is involved with the oil etc?
Old May 11, 2005
Blahman240's Avatar
Touch it... He won't bite, He'll just come at you pretty quick.
Blahman240 is on a distinguished road
i wanna see pics too!
Old May 11, 2005
G'z UP
i need info and pics
Old May 11, 2005
Civicman1988's Avatar
I need more info and pics
Old May 11, 2005
xX03EXx's Avatar
Sweetest Dude on 7th Gen
Sounds kinda ghetto but I see how you were thinking. I dunno how or if that would improve over stock.
Old May 11, 2005
scatman's Avatar
Still in the game...
take off all of the plastic bullshit until you reach the little box that houses the actual filter. leave just that little box on....i did this for a long time when i had my 01 EX and tho it may suck in a little more hot air, it felt a tad bit more responsive.
Old May 11, 2005
...ever grinning...
Well, I did the coolant bypass which makes the air cooler, I suppose that would just take it another step further, or half step...
Old May 12, 2005
Big Rob's Avatar
I'm taking over!
Big Rob has a little shameless behaviour in the past
That's an interesting idea. Has anyone else tried this?
Old May 12, 2005
Pics coming soon... I've been talking to Farage on here and he said he basically did the same thing, but in the end made a switch over to the K&N FIPK II intake system... I'll let you guys know the difference. I did mine fore somewhat cheap tho, compared to the $200 for that intake.
*thanks for the info Farage
Old May 15, 2005
thecheat's Avatar
thecheat is an unknown quantity at this point
if you want an intake that is better then stock put a turbo in it, otherwise you are wasting your time
Old May 15, 2005
stepchild's Avatar
stepchild is an unknown quantity at this point
Just curious but besides moisture why should we NOT put these CAI's or SAI's on our cars? And speaking of problems with moisture is it that big of a problem and does an air bypass valve work at all?
Old May 15, 2005
Hayz's Avatar
I've had a Injen CAI for over a year and I have had no problems just drive smart and you'll be fine and as far as the bypass valve I think there is a thread about it you just need to search..
Old May 15, 2005
Diablo's Avatar
Diablo is an unknown quantity at this point
I have had my AEM CAI for about 2 years and no problems. the Honda dealer by me even sells them. i do have by pass valve just in case of water pudle. better safe than sorry
Old May 15, 2005
ashtonp's Avatar
ashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to behold
i removed my stock resonator, then attached the stock plastic intake pipe directly to the filter housing, and positioned it facing the wheel well. it worked well for a while, but then i got a AEM cold air intake, which is great. i dont know y so many ppl here are against them, they're a good cheap upgrade.
Old May 15, 2005
...ever grinning...
Well, they aren't that cheap and I'd rather have a custom modded stock for cheap than pay $200 for it.
Old May 15, 2005
orion_squall's Avatar
hi,
will the car be very noisy without the resonator?
thanks
Old May 15, 2005
Ashhole's Avatar
Ashho-san 7thgen Ninja
Ashhole will become famous soon enoughAshhole will become famous soon enough
ive had no probs with my CAI, and i did notice a small gain with it. no moisture issues or anything like that, but i did get the bypass just in case. i know some people that lost their motors to water, not wanting to be one of htem,
Old May 16, 2005
oc768's Avatar
oc768 is an unknown quantity at this point
Yep, just did it tonight finally...little bit louder then stock, feels like it pulls a bit more on the bottom, and breathes better up top. I'm sure some of that is placebo effect just from having the noisier engine so it 'sounds' faster...but it stands to reason if you take a flow impeding object out of the airstream then you would be able to get a smoother more constant flow.
I did this primarily because of the quest for better mpg and because I'm the only one that looks under my hood so I really don't care how bling it is
Old May 16, 2005
gagne123's Avatar
gagne123 is an unknown quantity at this point
Had My CAI on for a year now, see no problems with it. I even drove with it on all the way through the harsh Northern Minnesota winter. Not much road salt was on the flilter when I cleaned it last week.
Old May 16, 2005
G'z UP
pics of stock modded intakes??????
Old May 16, 2005
ashtonp's Avatar
Originally Posted by orion_squall
hi,
thanks
not really loud, just deep and very toney on the low end, but once u get upwards of 4000-6000 rpm it sounds pretty nice
I recommend just spending the money on a AEM CAI, its worth it
Old May 16, 2005
CuRiOuSfIsH's Avatar
Back From The Banned!
There were a few members on this board that posted up a pic of another person's Civic.... about a year ago. That person just took tubing that you find from a vacuum cleaner and stuffed it in the throttle body. He was inventive, but got flamed and left.
Old May 17, 2005
oc768's Avatar
Have no pics yet, but think like this...
-remove intake horn, resonator, all mtg. brackets, etc. Everything up to the boot that goes into pre-filter plenum. seperate all parts.
-take intake horn/tube that went into resonator, and the grommet from resonator to intake plenum, and put the intake into it at an angle facing downward and forward, now put a 3" pipe clamp on it. You'll have to be crafty as to how to support it, I used thick safety wire and tied it to two points asymmetrically.
done.
I realized today (4AT) that the car is MUCH more responsive then it was before, especially at low revs like sitting in traffic and the initial first gear pull. But it ain't rocket science, I'm sure a CAI does the same thing...just a few hun. more and it gets that high-psi cold air from that 3" of space to the right of where my intake is now.
I'm just cheap though, and prefer OE look to big blingy filter arrangement.
Old May 17, 2005
...ever grinning...
done.
I perfer the OE look as well... can you please post some pics so I know what you're talkin about?
Old May 18, 2005
Big Rob's Avatar
I'm taking over!
I did that today. It isn't any louder before, but it does have a deeper tone which sounds great. I'm still not sure as to how it affected my car performance wise. I'll test it more tomorrow and post pics.
Old May 18, 2005
...ever grinning...
Thank you! *bows down*
Old May 19, 2005
Big Rob's Avatar
I'm taking over!
Here are a few pics of my stock modded intake:
This is how I have the inake horn angled. If I were to angle it down any more, there would be engine components restricting airflow.
This is how the intake looks with the resonator gone.
This pic show how I have the horn tied down. I used some pretty heavy duty wire that I had laying around. I don't that that it will be going anywhere any time soon.
This is what my engine bay looks like with the finished product. I was pretty surprised at the amount of room I freed up. Now I have a way to smuggle Mexicans across the border.
Old May 19, 2005
PunkingCivic's Avatar
I need TP for my bunghole
LOL
I'll just stick with my 15 dollar ebay CAI
