Brake Booster line!
Old May 20, 2005
midnightblueEX's Avatar
midnightblueEX has a little shameless behaviour in the past
Brake Booster line!
Im trying to get the brake booster line disconnected but its so far back, how do you get it off? and with what tool.. thanks
Old May 20, 2005
chinaman's Avatar
chinaman is an unknown quantity at this point
may i just ask why you need to get your brake booster line off?
Old May 20, 2005
streetglower's Avatar
yea what are you trying to do now?
Old May 20, 2005
Seafoam lol, why u think seafoam will be bad?
Old May 20, 2005
i finally got that little metal clip off,, then went to pull the line, and its stuck, im like wtf,, i dont want to yank it to hard i might break the line.. anyone have this problem?
Old May 20, 2005
first off what yr and how many miles do you have?
Next just cut the line off and buy a new one, it is only a vacuum line.
Old May 20, 2005
Skunk2ner's Avatar
Skunk2ner is an unknown quantity at this point
to remove the brake booster:
1. remove the brake master cylinder. if you have ABS, remove the master cylinder brake lines from the ABS hydraulic unit.
2. disconnect the hose leading from the engine to the booster. be careful not to damage the hose when removing it from the booster fitting.
3. remove the bolts securing the throttle cable bracket, then remove the power steering and air conditioner lines from their holders.
4. locate the pushrod clevis pins connecting the booster to the brake pedal. remove the clevis pin retaining clip with pliers and pull out the pin.
5. remove the four nuts holding the brake booster to the firewall.
6. slide the booster straight out from the firewall until the studs clear the holes and pull the booster, brackets and gaskets from the engine compartment area.
f575gtc
Transmission
Jul 13, 2015 09:16 PM
OptimisticWay
Jul 10, 2015 04:31 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
General 7th Gen
Jul 9, 2015 10:17 PM
Causemo
Jul 5, 2015 06:42 AM
