Throttle body
Guest
Posts: n/a
Throttle body
Any of you guys know any places that sell throttle bodies for a D17? I've been lookin all day and i can only find one but they don't even give the TPS sensor on it, says " Use the one from your car" but little they know it doesnt come off. Anything feedback is appreciated thanks
Well as for the TPS you can drill out the fasteners and use screws of the same size and thread type with a lil low strength locktight. Make sure you adjusts it to honda specs. Check the voltages before you take the old one off at wot and closed positions and set them to the same on the new one.
If you cant buy just the sensor from the dealership the get a whole TB from the junkyard. I got one for 30 bucks so its a lot to spend on one sensor but cheaper than buying a TB from honda(like $150)
send stock to www.maxbore.com he will even put screws on the tps. Very good work. He also fixes damaged ones. Just send him an e-mail.
Originally Posted by GoNeIn60
I need a new TPS sensor though, do you know where to get any?
the tps is held on by rivets. So you need to break them off and use screws. Its possible, but you're gonna have a hard time aligning the sensor so the ecu matches the rpms.
all you need is a multimeter to check voltages with the key on and the engine off. Check full closed and full open. or get a manual they will tell you the specs and just adjust them to that, its no big deal really. full closed is more important than the full open voltage because after a certain amount of voltage the car goes into open loop mode anyways i think its like 80-90% TP but not positive
i think im probably gonna try to find a junkyard that has one i dont have that much time to work on it as i would like to and the idle thing is driving me crazy when im stopped at a light or w/e. I appreciate all the help guys
Good find Gearbox. I may have this done when I'm installing my new head.
Bruce2
Sep 27, 2015 08:45 PM
Bricoleur
Sep 9, 2015 12:30 PM
