Turn Signal Problem
Old May 13, 2005
Htowncivic's Avatar
Htowncivic is an unknown quantity at this point
Turn Signal Problem
I had angel eye projectors on my car and the turn signals were working fine. I just took them out yesterday and put back in the stock headlights, and now the turn signals don't work. The bulbs light up, they work. I can't even get the in car turn indicator to come on though. I know if the bulbs were out, the in dash indicator would just blink fast, but now that's not even coming on. It's happening on both sides, and I checked the fuse, that's fine too. PLEASE HELP!! WTF IS GOING ON?
Old May 13, 2005
bamb00's Avatar
check the conductor (metal part) on both the bulb and the socket. do the rear ones work at all? check the rear ones and if they are blinking like crazy then that means either your front turn signal bulbs are burnt out or the connection is bad.
Old May 13, 2005
Htowncivic's Avatar
The rear ones work, and I don't think there is a problem with the conductor because the lights come on as parking lights and when I have my headlights on, they just don't blink. Nothing in my car blinks. None of the turn signals, not even the in dash indicators. The in dash indicators don't even light up.
Old May 13, 2005
pnoyster2k1cvic's Avatar
Balut Eating Champ
check fuse my friend
Old May 13, 2005
CraigW's Avatar
So the front and rear turn signals light up but won't flash ??
How about the 4 way flashers ??
Old May 13, 2005
Htowncivic's Avatar
I checked the fuse...it's fine. If I turn on my headlights, the corner lights come on with them, and they flash when I disable/enable my alarm, but they do not blink, the rears do not blink, and the indicators in my dash do not blink.
Old May 13, 2005
streetglower's Avatar
ok if they flash with the alarm, but not with the turn signal lever, I would suspect that lever as the problem. Test it to find out. But first, hit the emergency flasher, do they work then? If so, most likely it is the signal switch. It is only a $35 item from honda, but test it to make sure. If you need instuctions on how to test and get to it, let me know. I have the manaul
steveneddy
May 19, 2015 02:39 PM
Fastfebur
Apr 22, 2015 01:37 PM
blackbullet
Dec 1, 2001 03:44 PM
civicPRODIGY
Nov 12, 2001 09:32 PM
GhettoCivic
Nov 12, 2001 03:15 PM
