Intake Breather Hose
Powered by Honda
well today i got my intake, so i installed it.it was really easy and this was my first time. however, when i got the intake, it didnt come with a breather hose, so i thought i could use the stock one..Well the stock one was half an inch short so i clamped it at the ends so it could hold till tom..
my question is:
1. what is the purpose of this breather hose and what will be the consequences if i drove without it...i just want to know..thanks.
my question is:
If you leave the hose off dirt can get in the head and intake. The crank case outlet allows the cylinder head to breath, I personally used a crank case breather element, it's a small filter on the cyl. head side, and pluged the intake side.
if you're talking about the hose that goes into the valve cover, that is the PCV fresh air inlet hose. it's purpose is the reduce hydrocarbon emissions by scavenging the crankcase vapors. it circulates fresh air from the air intake duct into the crankcase where it mixes with the blow-by gases before being drawn iby intake manifold vacuum through a pcv valve to the intake manifold.
if you don't mind hydrocabons and a cat that wears out faster, just put a small air filter over the intake piping's outlet.
Originally Posted by mr_fobster
ok sorry for a little thread jacking here but would any auto part store carry those crank case breather filters? like can i get the filter from pepboys or NAPA?
i thought hot air comes out of that breather and goes back into throttle body, i disconnected it and i felt hot air coming from it i left it off and the car felt better, i was lookinf for a filter to fit it but its kinda kit the regular breather filters wont fit, should i reconnected back the hose to it will it damagae anything or can i leave it off its been off for about 40,000 miles now and i havent had a problem
The CCB I bought had a rubber piece that went into the actual filter cone, i just pulled that rubber piece off, since it only has a small opening, and stuck the huge hose that came with my CAI directly in the filter, then plugged the TB side.
I hope that helps...
see evryone here uses a breather the negitive fall from that is that the valve cover shoots out oil cause it happen to me so I invested in getting a NRG oil cathch can from a local race store and that my friend work better that the breather fillter
Sep 27, 2015 11:33 AM
BJB
Sep 14, 2015 11:16 PM
slammed925
Sep 13, 2015 11:27 PM
thaler4cuse
Sep 7, 2015 08:25 PM
