- Turbo question?
- Help with Platinum White Bulbs
- power windows
- Remote Start
- noise from exhaust
- Installation of OEM body kit?
- PSI range for oil pressure guage
- Urgent help please - Taking Instrument cluster off
- mental property theft aka "he is gonna copy me!"
- bad smell
- Got into a small accident, please help
- Cruise Control button constantly on???
- Do we have a OBDII diagnostic connector for our cars?
- how much horsepower could...
- DIY on Installing Chrome E-Brake Handle Please
- OBX strutbar+ OBX intake....
- Installed revo ss
- How easy would it be... [shift light question]
- O2 sensor....What wire is the signal wire
- Do i chip or put on my V-AFC, relating to Nitrous
- need suggestions on painting interior
- Cleared headlights painted black and blacked out tails
- size of in-dash TV??
- Nail in tire
- Head Work
- VAFC settings...
- Help! Split in one of my stock firestones!
- Inverter don't work
- Intercoolers
- Wiring diagram PLEASE!
- anyone have pics of FIPK in our car?
- Quick exhaust question.
- Light Question...
- Throttle Plate Edging
- cutting shifter vs purchasing short shifter?
- Has your car ever farted? (backfired?)
- lx or ex gauge cluster
- hybrid piston/rod combo
- HELP! How can I make RSX seats fit in my EX coupe
- grey - explain the whole return fuel system to me
- VTEC-E / cam --- Q's for the experts
- Lowest 2k1
- Computer Reset
- Headers
- HELP!!!!!!..I broke my needle:(
- Injen cai
- best place to bolt down...
- possible to replace new bulb 4 low beam without removing fender?
- lx head swap
- radio still flashing!!!!!!!!
- crx engine swap
- Damnit! Messed up my air filter!
- wiring question
- Flywheel theory...
- How do I fix the horn contact
- Need help?
- Torque Specs for Strut Tower Bar Needed!!
- How do you remove the rear seat in a coupe?? Help quick
- HONDA TECH please help w/tach
- **Making a Custom Intake manifold**
- Cam specs
- CHANGING THE STEERING WHEEL ??
- RSX cluster?>
- 02 EX coupe pass. door window install.. tips?
- What brand and model of aftermarket clutch is anyone using?
- indiglo reverse gauge info...
- Standalone
- urgent maintenance questions
- removing door edge guards?
- header heater shield
- jet ecu upgrade and nitrous
- What is the Impedance of Stock Speakers?
- CAI and reverse light sensor?
- 03 gauges in an 02?
- click me please!!!!!
- OBDI versus OBDII
- Intake question: upper-pipe bend angle ?
- Up or Down ????
- speeding up the blinker
- Question when you hit a year or 15,000 miles
- where does most road noise come from?
- want to install cobra eyes....
- head gasket?
- My Gauge Lights Wont Work??
- Need help finding a wire
- Did you have to cut your back bumper to clear your magnaflow cat-back on your sedan?
- Gauge cluster swop?
- Removed intake resonator...no sound difference.
- Strut Tower Brace? [I'm new so bear with me]
- Problem with ignition solutions coil (pics)
- side impact molding on sedan
- sidemarker help!!!
- what do you use to pump up your tires?
- water pump= hp?
- need opinion on obx axleback exhaust
- u turn it or what. trying to install new bulbs in head lights
- K&N FIPK???
- apexi SAFC tuning tips
- for those who have H1 in your projectors...help!
- Sandpaper??
- trunk struts
- ..so what is it?
- Mandrel bent or Crushed bent?
- Just changed air cleaner - what's the large...
- itrous help needed
- Auto Meter Vac Gauge
- 2002 ex coupe dashboard removal HELP!
- '03 civic
- Where to find aftermarket Clutch for LX
- ROD, SUBFRAME PERFORMANCE in 01 LX
- WTF - "H" Emblem
- aluminum dash trim....
- MID PIPE
- Another Indiglo Guages Question
- want to turn your auto into a stick?
- GTI VR6 vs Honda Civic Dx
- I need help THIS INSTANT: THIS IS VERY VERY IMPORTANT! (about s-afc and ecu wiring)
- Changing Front Upper Grill
- 1993 Del Sol Clear Corners?
- 7440 to fit into 7443
- Buildin' the Block
- quick engine swap question
- M3 Wires into Fuse Box
- fuel rail...
- How to bleed brake fluid?
- aem cam gear
- 3 Replaced Valves...will it be the same?
- Swap EX gauges to LX gauges??
- Roof Rattle
- Blown Motor...Does Honda Replace it??
- Installing headers
- Intake prices and results
- removing/installing side view mirror?? help
- DX GLOW GAUGES
- help with a cf hood
- front upper strut
- tie-bar installation?
- indiglos question
- Dual Turbo's?
- poll: Does your driver's seat rock?
- can i put EX exhaust system from header to tip in my LX
- can i get this to fit?
- supercharger?
- good service place in OC
- painting m3 style mirrors
- ACK!! Another warning!!
- Angel Eye Headlights
- outside black pannel?
- Codes for Auto A/C on/off
- nx kit installation
- Turn signal bulbs
- Oil Pressure/Temp 2" Guages install??...
- K20 Engine Pricing
- Interior Trim Prob?????
- D17 performance parts?
- colored dome lights -info needed
- Guage Bezel
- might be a really stupid question... which wire is 12V
- dry nitous system
- installing nitrous
- where can i find the parts number???
- engine swap
- HELP!!! AIR/FUEL gauge Question!?!?
- rubbing or thumping?
- LX guage cluster
- Shift light install help...
- Sidemarkers
- Splash Guards Paint keeps chipping off...
- HELP! SPEEDO NOT WORKING!!!
- ohmysac, trunk popper
- Angel Eye headlight problems.
- Anyone know how to install M3 mirrors ?? instructions and pics
- lower tie bar & upper rear strut bar
- If i change my header what abouot my O2 sensor ???
- can i put coupe 2 doors OEM headlight into my 4doors civic
- After CAI install
- anyone want swaybar endlink brackets for LX/DX? ((UPDATED))
- sedan crome grill piece
- Does Helms manual have dash removal stuff?
- I NEED TO KNOW THE BEST WAY TO MOLD A....
- tightening the ebrake cable
- AUTOMATIC TRANSMISSION EXTENDED WARRENTY
- Car won't start up when..............
- Door Handle Trim?
- Clutch ?
- Installing Help
- What would give me more power??
- side marker install?
- lx to ex exhaust conversion question
- Installing Subs, need help
- Need Help With my Angel Eyes
- Turbo Kit Parts List
- how do you....?
- Help! How do I put on my new m3 side mirrors?!....
- where to get oil changed?
- HELP!!!: REVO SS!!!
- Port & Polish
- Ultra Start/Alarm
- LX with cam gear???
- Just a theory
- DIY: K&N FIPK install
- Coupe and Sedan Springs The Same?
- sub question...
- metal bracket on injen cai
- Does this Turbo Really work?
- replacing the camshaft
- Question about Cup holder cover for 2k2 civics
- Fog In projectors!
- got my car back after two days...
- Modifications for EX header?
- Need Help....
- GrillCraft
- ruined gauge needles instaling indiglo gauges-help
- Daytime Running Lights
- Headers....i know i know its been talked about before
- header making funny sound
- racing seats...
- Camber Kits
- some q's on block guards
- Just installed my rsx sway bar I love it.
- D17 engine map
- Blinkers dont work
- Hi! I'm blonde :D
- To remove my DRL's or not...that is the question?
- REMOVING THE CENTER CONSOLE!!!
- question about waste gates
- Start Up Trick???
- APEXI VTEC CONTOLLER
- DX to EX rear sway conversion
- Need help please, 6 color indiglo, Z3 fenders
- map sensor how to keep it from seeing boost??
- Power Windows
- Mex's Headlight Mod, DIY, PICS...
- Shifter Help
- Does the 2003 guage cluster work with 2k1/2k2's?
- correct me if i'm wrong
- Springy noise when closing doors....
- Stut bar and CAI
- Rear Lower Tie
- Is that IAT Sensor Trick safe?
- RSX Rear Sway Bar
- Rear seat question
- o2 simulator install?
- plastic thing
- turbo theory
- Honda techs please help
- MSD??
- Interior question
- turbo and computer???
