installing nitrous
Old Nov 11, 2002
chefjnr's Avatar
chefjnr is an unknown quantity at this point
installing nitrous
I'm having a 50 shot kit installed (dry system), I think the brand is NEX (or Zex>??) ,I have a aem adj. cam, should I retard a few degrees or advance a few degrees witha nitrous kit??[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Nov 11, 2002
Ike's Avatar
Ike
Ike is an unknown quantity at this point
Its Zex, and I do believe a dry shot wont work in our cars. If I were you I would find out some info before you f**k somthing up.
Old Nov 11, 2002
Intruder's Avatar
Intruder is an unknown quantity at this point
ZEX does not work with our cars, which you will probably find out when the shop calls you up. We don't have a fuel return line, something that the zex kit (and just about any other dry system other than venom) requires. And you retard maybe 2 degrees if you are going to run a 50 shot, but it isn't necessary.
Old Nov 11, 2002
pothole's Avatar
pothole is an unknown quantity at this point
The Zex kit will not work with the 7thGens. You need to purchase a Wet kit. Zex is coming out with a wet kit soon. I don't know the exact date, but at NOPI Nationals they told me they would be releasing it.
Pablo
Old Nov 11, 2002
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
ZEX and VENOM do not work.
You must get a "wet kit" NX Express makes one or good old NOS makes one.
Yes there are others, but these are the most common. I'd go with the NX express
Old Nov 11, 2002
SMX's Avatar
SMX
SMX is on a distinguished road
For a 50 hp shot, use 92 octane and don't worry about the retard. Most manufacturers like 2 degrees retard per 50 hp shot, but the first 50 can be without any retard in most cases. You want the retard only when you're squeezing. I know how to set it all up for vintge iron using MSD, but don't know how to program it for our 7th gens. One of these guru's should be able to help if you need it. But heck with only 50 hp, I wouldn't worry about it.
Old Nov 11, 2002
Ike's Avatar
Ike
Venom does have a nitrous kit for our cars. Moocow had one before the turbo.
Old Nov 12, 2002
chefjnr's Avatar
sorry about the confusion on the brand, I went with a nitrous express stage 1 kit, (50 shot nozzles), remote bottle opener and bottle warmer, is anything else needed that the kit does not come with or the other items i mentioned???
Old Nov 12, 2002
APS's Avatar
APS
APS is an unknown quantity at this point
Venom does have a kit for our cars...the VC-1000 works well...in fact I installed it yesterday...50 shot...I post apicture before it was installed....IT IS SO MUCH FUN!!
Old Dec 11, 2002
kjgracing's Avatar
Nice books.
you go to ITT or something?
Old Dec 11, 2002
PlatCruiser's Avatar
PlatCruiser is an unknown quantity at this point
Quote
[hr] have a aem adj. cam, should I retard a few degrees or advance a few degrees witha nitrous kit?? [hr]
ignition timing and cam timing are too totally different things. you cant adjust your cam gear to retard IGNITION timing
Old Dec 11, 2002
BeefMan's Avatar
BeefMan is an unknown quantity at this point
You are gonna enjoy it, too bad the bottle runs out so quickly. My engine sounds nuts when I spray in 2nd, and the car pulls pretty hard. 3rd and 4th still pull harder but nothing like 2nd, anyone else feel the same? Maybe I should change spark plugs or retard the timing or maybe its just bad gearing.
Old Dec 11, 2002
its the ratio of each gear and the final drive
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
mrwhos
Aug 11, 2015 02:03 AM
17
Jul 23, 2015 11:48 PM
EM_WON
Jul 22, 2015 06:49 PM
