PDA
View Full Version : General Honda Civic Forum Archive.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 [42] 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59
  1. IMPORTANT Question for my Car!!!
  2. Tranny Work: Clutch and Flywheel
  3. Computer in your car -----
  4. Where can I ground my fog lights?
  5. Need help with throttle cable adjustment
  6. DESPERATLY need v-afc help
  7. Best alarm
  8. Alarm siren for horn
  9. cant take front bumper off to clear headlights HELP!
  10. HID Question
  11. Black Box?
  12. Note: To guy who complained about DIM headlights
  13. question on tach install
  14. help!!!!! guage question
  15. head light short prob
  16. headlight wattage?
  17. cleared headlight problems
  18. sneaky pete NOS nitrous question
  19. Lower tie bar question
  20. Springs upside down?????
  21. angel eye wiring question
  22. fuel setup for turbo?
  23. anyone have any idea where I can find engine info?
  24. removal of OEM front lip??
  25. Painted tail lights
  26. REAR BUMPER REMOVAL
  27. tyc projector ?
  28. Sticky tape underneath pinstrips&badge?
  29. Nighthawk black paint....
  30. I WANT THIS.. How can i do it to a sedan?
  31. Pondering about something...
  32. Supercharger?
  33. I need some brakes, where should I look?
  34. How often should you clean your intake filter?
  35. headlight clearing
  36. doesnt anyone SEARCH?!
  37. Got a question about the motor...
  38. Great Big Problem....VAFC...Help fast!!
  39. Shift Boot Question Part 2!
  40. 02 EX 2 door engine #
  41. Body kit question.
  42. Pistons meltdown...
  43. Will this work?
  44. Gas Milage
  45. turbo performance
  46. Painting My Tail Lights
  47. Injen CAI & Air Horns DIY/Pictures?
  48. 4-1 hp header w/ high flo cat
  49. Highflow cat/dp
  50. I need some help
  51. has anyone attempted governor removal
  52. integra b series swaps
  53. Best bang for the buck?
  54. wher'd you mount your bottle poll?
  55. How to remove stock spark plug?
  56. alarm options
  57. 9003 = H4??
  58. WTF (tail light question)
  59. Little screw on the door?
  60. Need Help!!! Sun Visor Question
  61. The $1500 question!!!
  62. Intercooler: Top-to-Bottom -OR- Side-to-Side?
  63. Si Instrument Cluster?
  64. sub box carpet
  65. 30K Scheduled Maintenance - How Much?
  66. Vtec light install questions
  67. rear disc brakes suspension sqeaks
  68. Sucessful headlight clearing, but.......
  69. homemade turbo w/MSD ignition questions???
  70. help please
  71. Custom Turbo -- Bill of materials...
  72. Fast and the Furious Supra Paint Code
  73. what is?
  74. Panic add-on?
  75. Camber Plates
  76. DIY building a custom trunk ?
  77. someone on this site has done it
  78. Has anyone done Manual Conversion
  79. blue dashlight question
  80. Auto to Manual Conversion
  81. maintenance required light
  82. Side Skirts
  83. I NEED HELP!!!! ASAP!!!!!
  84. Need Major HELP with CIVIC ASAP!!!!!!
  85. anyone replaced timing belt and spark plugs yet?
  86. Aftermarket fogs with stock switch?????
  87. Torque specs for rear sway bar?
  88. 2 1/4" resonator
  89. Turbo questions?
  90. resetting Maintenance Light?
  91. Somethings in the way?
  92. has any one ever
  93. DIY Custom LED needles
  94. supercharger
  95. Do larger rims make your car slower?
  96. Nitrous from a ford probe?
  97. Chipped center ring or alignment?
  98. Vortech supercharger?
  99. Tightening the handbrake
  100. Ground wires.... please
  101. M3 Power mirrors
  102. CHECK THIS OUT!!!! LOW PRICE
  103. Installing Ground Wires
  104. Compression on d17
  105. Nos shot
  106. ECU for Turbocharging... (Grey?)
  107. Installing Map Lights in DX?
  108. AEM Intake question
  109. vafc check engine light
  110. Oil Leaking... need suggestions
  111. Helix Power Tower
  112. Why the D16 manifold won't work (pic works now)
  113. Front Bumper Removal Q?
  114. wiring subs, need help
  115. blue angle eyes
  116. Calculating pressure coming out of compressor
  117. a/f gauge help
  118. is it ok to disconnect the intake sensor ?
  119. plug wires
  120. Installation of a Varad LED scanner
  121. Adjusting Cam Gear for Optimal Gains...
  122. d16 manifold
  123. ADVANCE TIMING ANYONE???
  124. Pistons/Rods? Intake Manifold?
  125. How do I remove back seat panels?
  126. Scratched interior
  127. has anyone thought of this?
  128. Pros & Cons; Revo SS
  129. HELP!!!
  130. REVO help
  131. SI seats
  132. power for fogs?
  133. Check engine light
  134. tranny vibration
  135. need advice on my ignition setup
  136. Lamborghini doors a.k.a. paper cutters
  137. the next engine for swaping in the civic....maybe my red coupe????
  138. Fog Light DIY
  139. Any one with an auto tran remove there resonator?
  140. Downpipe Question
  141. Exhaust step by step
  142. new day, new problem
  143. hp header problem
  144. 1/4 mile times
  145. need help finding?
  146. 195/60/15
  147. Headlight Bulb Out, But High Beams Work?
  148. battery
  149. Turbo Questions...
  150. Anyone bought an Alarm online?
  151. aem intake
  152. Car keeps dying, looking for insight.
  153. Is this possible?
  154. removing rear tail lights on 7g sedan
  155. would anyone buy/use a Racing intake type headlight housing for the civic if i made one??
  156. Heat sheild
  157. For those who have changed or removed dash
  158. nitrous oxide
  159. Color burned off bulbs!
  160. How long does it take for Stainless or Chrome headers to change color?
  161. Painting Interior and Needs help ASAP
  162. got vafc installed 2day
  163. Rear window Defrost...
  164. p/s and ac removal
  165. Gauge Problem
  166. whos got a car alarm...just got an Aladdin
  167. Steering noise
  168. H22 engine swap
  169. Does here have DIY to install new fenders?
  170. Change Odometer Color?
  171. For those with burning smell...FIXED!!!!
  172. 01 EX manual transmition ECU and Automatic Transmition ECU the same?
  173. Indiglo Burnout....
  174. Windows UP Module
  175. I Need Help Fast!!!!!
  176. AEM Pulleys = No Beats?
  177. I hate dealers...burning smell.
  178. Power Steering Fluid
  179. _HELP_sqeak coming from somewhere under the car
  180. Rear 6x9 install?
  181. DIY dash light (sort of) help
  182. diy painted headlight
  183. DIY Alarm Q
  184. help with gas door
  185. Sedan rear seat removal
  186. 02 Parking light wire....
  187. Window Roll Up
  188. HELP QUICK!!! REMOTE START
  189. Not your typical tranny swap question...
  190. GSR engine?
  191. cold air intake work for hx coupe?
  192. Remote Start Pictures...help
  193. Are all transmitions comparable with V-tech and non V-Tech engine, can you swap?
  194. fog light problems...
  195. "Back up" fuse???
  196. I did a search But...Shocks/struts
  197. Dummy asking warranty question
  198. transmission?
  199. What is the "BG Service Kit" needed at 30K mi?
  200. Showoff Krypton White/Purple Bulbs....
  201. Getting 19's and need some Spring advise
  202. THOSE with HID, how did you adjust your beam?
  203. Cruise Control for 2k1 Civic EX
  204. 5 Psi boost EX
  205. need help with sealing new projectors
  206. Sorry, another clearing quesion
  207. 7G civic engine swaps...
  208. Connecting iPod to stock HU
  209. Help me install Remote Start/Keyless Entry please =)
  210. DIY Oil Gauges (with Pics)
  211. Blue Dash Light DIY???
  212. interior color?
  213. headlight adjustment
  214. Removing Gauge Cluster - Advice
  215. Painted exterior parts...
  216. How to tell what is draining the battery?
  217. door panels *help*
  218. hyperblinkers
  219. Cheapie Oil Cooler Idea...
  220. painting the brake capliers
  221. euro tails
  222. NOS in a bottle
  223. AEM Short Ram installation...
  224. blue headlights
  225. v-afc help needed
  226. Denso Iridium Sparks
  227. help please!
  228. How to turn off maintenance light???
  229. ATTN: CivicPunker17
  230. dont need any parts or anything you just need to remount it with the stock screws or something if an
  231. v-afc (people that have them please read)
  232. Removing center piece of dash...
  233. Engine in 7th gen Ex or Si (canada) is H17a? or..
  234. Strut Bar Problems
  235. Oil?
  236. installing tie bar, help!
  237. Advanced timing?
  238. running lean
  239. I NEED THE TORQUE SPECS. ASAP
  240. ? about DIY Angel Rings
  241. DYI installation of O2 Simulator in 7th Gen EX
  242. Carpet Removal
  243. Compression Ratio -- S2000Man or anyone else...
  244. REVO SS HELP!!!
  245. how to remove front pillars? att*beamer and other DIY'ers
  246. Seat install question
  247. How to get wires through firewall?
  248. Help Quike please
  249. the science of destroking an engine.... any questions?
  250. Washington Civic Owners: Where'd you get tinted at?
