Removing center piece of dash...
Old Dec 24, 2002
REDVIC's Avatar
One of few in the 13's
REDVIC is an unknown quantity at this point
I was wondering if to remove the center peice of the dash you just pull??? The centre piece where the head unit is... 4 way flashers, etc... So do you just pull or is there any screws??? thanks![IMG]i/expressions/beer_yum.gif[/IMG]
Old Dec 24, 2002
oblivious9's Avatar
oblivious9 is an unknown quantity at this point
Click on the DIY on the top of the page, then under Audio, click on removing the factory head unit in a 7thgen honda civic. Easy enough?
Old Dec 24, 2002
NaMjah's Avatar
NaMjah is an unknown quantity at this point
there isnt any screws, but there are a lot of clips that holds it
Old Dec 24, 2002
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
there are two screws on the center dash part, you have to pull off the plate with the power outlet on it, under there is 2 screws, then you gotta be really buff and pull the whole piece out
Old Dec 25, 2002
twizzx's Avatar
twizzx is an unknown quantity at this point
Yeah just follow the DIY for removing stock radio. However, I feel that they don't really show you all the steps. They miss some key points and make it seem way too easy. I'm guessing that this is your first time removing the dash piece. I can tell you that first time is not a great experince. Go slow and make sure you have the right tools because although the center dash is held by clips you need to remove some tough to reach screws first. You'll need to use some force in pushing the first clip out of the dash once you are done removing the center dash and the piece where the power outlet is. After that it is pretty easy as you now can use a flat piece of tool to pull out the rest of the clips. The key once again is to go slow though. Anywayz good luck!
ZILLA
Air Conditioning
Jul 11, 2015 08:35 PM
OptimisticWay
Jul 10, 2015 04:31 PM
ballmich
Jul 9, 2015 11:59 AM
Causemo
Jul 4, 2015 07:11 AM
