PDA
View Full Version : General Honda Civic Forum Archive.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59
  1. EX transmission
  2. Head lights
  3. Constant Power Source for heated seats
  4. Dash Question!!!!
  5. OEM Spoiler: New Trunk Springs
  6. Sparco seat brackets-Somethings messed up
  7. Ignition,Ground kit, plugs/wires,coils...
  8. A/C removale
  9. Gauge cluster test
  10. Need help with removing a dash and dash pad
  11. dash lights are out!
  12. Help with Auto Tranny
  13. ub bulb placement
  14. my car is overheating, need help!!!
  15. Re Flash
  16. Is nitrous a mistake??
  17. What next???
  18. Arm rests
  19. Can't find Front Spindle ??
  20. Which should I get ??????
  21. sparco seat belt question
  22. Ground wire for amp
  23. camber question
  24. maintenance light question
  25. Safe?
  26. Online store for Denso Iridium?
  27. o2 wiring question
  28. Whats that black stuff ???????
  29. ex sway bar
  30. What is VTEC?
  31. DIY: oem switch for oem copy foglights
  32. Valve adjustment specs?
  33. intake detonation
  34. Well i found two diff sets of rsx seats so i got some Q's
  35. AEM CAI for 02
  36. Part # for tiny black nib that holds gas cap
  37. How much more HP?
  38. HELP!! Spun rod bearing
  39. Question about the coolant level on a warm engine...
  40. Need Help... Idle Control System Malfunction
  41. how to get the air out of gas tank
  42. NEED help fast
  43. Oil pressure gauge reading
  44. Questioning on A/C window circulation
  45. bypass valve doesnt fit...
  46. Adjusting throttle cable...
  47. Do our cars have a black box?
  48. Civic to Del Sol Seat Swap
  49. Replacing front let cv axle...
  50. bumper, grille removal DIY
  51. Will SAFC1 Work?
  52. Need To Remove rear Bumper Please
  53. how do you jack up the whole car?
  54. When removing the interior dash, do you have to disconnect the battery?
  55. what size is the gasket between the header and the highflow cat???
  56. Front Bumper on Majestic Honda
  57. adjustable cam gear explanation..
  58. How do you get the Front Fenders Off?
  59. SRI rubbing against hood
  60. Any Feedback on these Aftermarket OEM style Plastic Bumpers
  61. Help with Stock Strut Replacement
  62. Bad Gas milage
  63. reverse problem
  64. Block/Core Heater, Plugging In
  65. 98-01 Accord Trunk Opener with 04?
  66. Ignition key programming
  67. Help Install Turbo Timer
  68. VIS CF hood install
  69. ex and lx engine difference.
  70. Electrical Question
  71. Towing Capacity ?
  72. EXPLANATION to lack of response to mods
  73. Help needed
  74. diff. between lx and ex headers and cat
  75. Gauge light out......HELP
  76. SRI Intake mystery brackets (pic)
  77. does anyone have detailed instructions replacing cluster bulbs on 01 ex 5speed civic?
  78. Safc2
  79. diagrams
  80. The V2 Way
  81. D16 Clutch on a D17?
  82. A/C taken out?
  83. RPM and TPS (Throttle position sensor)
  84. need air filter for stock civic.
  85. Too Freakin Tall For 01 Civic EX Coupe / Back Problems
  86. how to remove ac vents?
  87. OFFICIAL: How Fuel Injectors Work | Truehonda.com and Overboost.com
  88. Question about tachometer
  89. Those with Revo SS and Grey's kit
  90. help with ABS and Traction Control
  91. Helpme....hp Header W/highflow Cat
  92. About time!!!!!!!!!
  93. Engine bay fuse box removal
  94. To buy or not to buy?
  95. Exhaust Rattle/Vibration
  96. M.i.l.
  97. Computer acting odd after header install?
  98. Mobil 1 EP 15K mile/1 Year Oil?
  99. 01 LX 4Dr Cracked Exhaust Man.
  100. Strut bar ...modification...
  101. paint remover on ABS plastic help omg
  102. Need some help/opinions........
  103. Cheap way to DIY poly motor mounts
  104. Fitting Tanabe SMR onto UKDM Civic EM2
  105. the car-puter is under way
  106. HP Racing header...lagging
  107. Broke Exhaust Manifold Bolt Help!!!!!!
  108. gauge cluster swap but in Canada...
  109. Did I mess up my car?
  110. Question about Trouble Code Detected?
  111. How to get this part off? (intake install)
  112. Help! I'm installing LEDs in my automatic floor shifter, and I can't remove...
  113. stock stereo and aftermarket harness diagram???
  114. EM2 Wiring diagrams
  115. Front bumper clip leftover
  116. Got Problems! IM NOT SURE IF IS THE NX OR THE EXHAUST!
  117. Quick Battery Question
  118. My Cluster burned, FUK!!!!!!!
  119. RSX type S axelback
  120. unhooking or dead battery
  121. Removing headlights on '05 LX
  122. Fuel Pressure
  123. To anyone that have 20" passenger side wipers
  124. CHECK ENGINE LIGHT Questions
  125. Civic won't start
  126. Anyone used one of these before for taillight tinting?
  127. Will 01-03 short ram intake fit 04 auto?
  128. ECU Harness
  129. my headlights switch is broken
  130. Wet Speakers
  131. Hella Supertone install with OEM foglights (with pics)
  132. RSX dash
  133. Can u install Cruise Control on an 05 Civic Sedan VP
  134. Wheel bearing replacement
  135. Price of timing belt change?
  136. ECU computer replaced
  137. anyone built a d17 before
  138. o2 sensor on 04 si
  139. what to buy
  140. RPM Signal wire?
  141. Question on Adjusting the Throttle Cable
  142. Reverb 6 disc replacement
  143. What is it?
  144. STUPID transmission question
  145. 04 DX headers??????
  146. I need some help guys *stuck at work right now*
  147. RPM question
  148. Didn't change the oil till 10K, now the MAINT. RQD light's on
  149. Spoon what?
  150. Removing Door Handle
  151. center console..
  152. Cargo net install? Omg help!
  153. I'm having a tough time finding a reputable speedometer shop x_X
  154. Help altenator
  155. Exaust / o2 Sensor
  156. So I took my car in for a new axle
  157. water pump problem?
  158. Pedal replacement
  159. abs light on
  160. key fob
  161. Best product for adhering Body kit
  162. HELP! wrist pins
  163. Pinouts
  164. tune up...
  165. Secondary O2 Sensor Wiring Help
  166. Parking Light Part #
  167. Return conversion fuel system +
  168. intake question
  169. M3 mirrors mounting problem
  170. short throw
  171. Speed Chip? Or pure shit?
  172. spark plugs
  173. So i blacked out my headlights
  174. Aiming Headlights
  175. rsx gauge cluster swap
  176. EX to LX Head Swap Emanage Question
  177. W T F!!!
  178. EX Exhaust on an LX?
  179. need help on tyc head lights
  180. Question bout taillights
  181. DIY: DEI (viper/clifford..) RStart/keyless/alarm INSTALL
  182. fillers for ABS plastic?? bondo?
  183. Water out tailpipe?
  184. High Compression?
  185. pics for clutch DIY
  186. DIY Stereo Install Problems
  187. Which oil filter wrench do I use for the small honda oil filters?
  188. My steering
  189. Driver's side airbag sensor
  190. Loving the RedZone! Internals to follow
  191. Removing Front Bumper... Airbag Danger?
  192. spark plugs
  193. SRS light
  194. advantage of a y8 manifold?
  195. 02 Fog Light Installation
  196. Short Shift Adapter
  197. mixing motor oil (by rating)
  198. handbrake issue
  199. Exhaust Diameters
  200. Fog install trouble
  201. new cd player in 7th gen
  202. ex exhaust to lx header
  203. Help! How do I adjust my windshield washer nozzles?
  204. Rattle problem
  205. Hyper Blinker on accident?
  206. LX to EX Exhaust??
  207. ? about carbon fiber
  208. Need help with rust on bolts on exhaust.
  209. How to change windshield wipers?
  210. air con on civic type R???
  211. Door lock problem
  212. New Member Help.
  213. Wiring Diagram
  214. problem with taking off door handle pc
  215. new key problems
  216. tape or glue?
  217. Window issues
  218. odd question
  219. Recommended oil change is every 3000... Why did Honda say 5000?
  220. valve seal change
  221. taillight smoking paint
  222. does anyone know???
  223. Head Gasket issue?
  224. spark plugs make a difference?
  225. Sorry, I know this has been asked over and over again, but are the sockets for the 03
  226. wiring a tv
  227. Heating system
  228. So i reset the ECU....
  229. Window modules
  230. led install
  231. Tunning Safc
  232. Transmission fluid
  233. Ported/Polished/Decked head is on. Now whats up?
  234. Install Alarm Scanner
  235. 2001 lx sway bar conversion
  236. Stolen
  237. Does anyone have a wiring diagram of gauge clusters for the 01 dx -> 03 ex?
  238. SOHC VTEC Explained
  239. vafc for 2001 civic lx
  240. aftermarket seats with srs system?
  241. Oil Change?
  242. Question About Installing Oil Pan???
  243. What's the difference btwn misfire, knock, detonation, pre-ignition?
  244. seatbelt reminder light
  245. AMSOil Drain interval and product
  246. Rearview Mirror Rattle?
  247. ABS light
  248. Injen SRI vs FIPK II
  249. Are my spark plugs okay looking like this??
  250. JDM: Stock Turbo Honda
