Help! I'm installing LEDs in my automatic floor shifter, and I can't remove...
1 Post
Rep Power: 269 Help! I'm installing LEDs in my automatic floor shifter, and I can't remove...
the top plastic bezel.
http://ledautomotive.com/HowToGuides...ifterHowTo.asp
For some reason, I can't find how you can do that. Are those instructions correct?
1 Post
Rep Power: 269 I even got pissed, and tried prying the black piece of plastic around the gold-silver shift bezel with a flat-head screwdriver, but that wouldnt work well either.
Rep Power: 346 Ok... I'm not quite sure where you're stuck but I'm guessing it's the first step
Like this
^^that step is correct. Grap the corners with your fingers and pull up. They're held in with self locking tabs... when you pull on them... it should pop off...
Like this
1 Post
Rep Power: 269 Thing is, my fingers doesnt even fit there. There is no way any persons fingers can fit. And that is not my shifter
Rep Power: 0 Follow the DIY on this site for center console removal. Skip the first 3 pics and instructions on LEDautomotive.com. Then proceed from the 4th pic and instruction.
my civic has no boost
Rep Power: 0 yeah u need to take the entire center console out which when u know where the bolts are takes just a few minutes. then push in 4 separate tabs and pop it out, and you need to take hte shift **** off, which is held on by 2 screws.
1 Post
Rep Power: 269 All done. All I have to do now is scratch or alcoholize that white paint on the little shifter piece.
97-DX-Lover
06-14-2015 06:07 PM
MamaBear2015
06-12-2015 12:00 PM
MamaBear2015
06-11-2015 07:33 PM
eorlando1
05-17-2015 11:16 AM
