Wiring Diagram
Old Dec 24, 2004
MrWong's Avatar
Bushido
MrWong is an unknown quantity at this point
Question Wiring Diagram
Does anyone know where it went? I cannot find it anymore, not even a search brings it up.
Old Dec 24, 2004
R1Style's Avatar
Wiring diagram for what exactly? LINK
Old Dec 24, 2004
MrWong's Avatar
Bushido
The wiring diagram that allows to you select any car manufacturer and and year and it will tell you what wire does what. I visited the link you posted but did not find what I needed.
Old Dec 24, 2004
TeLLy's Avatar
Yes, it's an Acura EL
What exactly are you looking for MrWong? the12volt.com has a wiring diagram right up till 2000...
Old Dec 26, 2004
MrWong's Avatar
Bushido
i need the entire wiring diagram (stereo, power locks and windows, etc...) for the 2001 Honda Civic Coupe Si (cdn) EX (US) model.
There used to be a really good one on this site called the Wiring Database or something.
Old Dec 26, 2004
profuse007's Avatar
Senior Member
profuse007 is an unknown quantity at this point
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|white |+ |ignition harness |
| STARTER|black/white |+ |ignition harness |
| IGNITION|black/yellow |+ |ignition harness |
| ACCESSORY|black/red |+ |ignition harness |
| SECOND ACCESSORY|white/red |+ |ignition harness |
| POWER LOCK|white/blue |- |gray plug above drivers kick|
| POWER UNLOCK|white/green |- |gray plug above drivers kick|
| PARKING LIGHTS +|red/black | |back of the fusebox |
| HEADLIGHTS|blue/red |- |headlight switch |
| DOOR TRIGGER|*2 |- |factory alarm plug *1 |
| DOME SUPERVISION|comes on with unlock| | |
| TRUNK/HATCH PIN|red |- |factory alarm plug *1 |
| TACHOMETER|blue | |test connector *4 |
| SPEED SENSE|white/green | |PCM *5 |
| BRAKE WIRE|white/black |+ |brake pedal switch |
| HORN TRIGGER|orange |- |steering column |
| LF WINDOW UP/DN|red/blk - red/yel |A |drivers window switch |
| RF WINDOW UP/DN|blu/red - blu/wht |A |drivers kick panel |
| LR WINDOW UP/DN|brn/wht - brown |A |drivers kick panel |
| RR WINDOW UP/DN|blu/org - brn/yel |A |drivers kick panel |
| RADIO 12V|white/red |+ |radio |
| RADIO GROUND|black |- |radio |
| RADIO SWITCH|yellow/red |+ |radio |
| RADIO ILLUMINATE|red/black |+ |radio |
| POWER ANTENNA| | | |
| LF SPEAKER|grn/blk - lt green | |radio |
| RF SPEAKER|grn/yel - gry/red | |radio |
| LR SPEAKER|blu/wht - blu/blk | |radio |
| RR SPEAKER|pink - blu/yel | |radio |
Notes:
NOTE: This vehicle has an immobilizer system that needs to be bypassed when adding remote start. Use DEI part number 555I or 555U. *1 The factory alarm plug is a green plug above the drivers kick panel. *2 The drivers door trigger is green, front passenger door trigger is lt. green/red, and the rear door trigger is green/white. *3 In the top left plug. *4 It is a 2 pin plug to the passenger side of the battery. *5 The PCM is behind the glove box. The vss is in a connector A (31 pins), pin 18. The vss is also blue/white at the cruise control module to the left of the steering column.
Old Dec 26, 2004
MrWong's Avatar
Bushido
nice thanks
juror
Suspension DIY
Jul 30, 2019 03:28 AM
rman1900
21
Sep 10, 2018 04:52 PM
sch2cm
Jul 21, 2015 09:58 PM
Bounddyy
19
Jul 20, 2015 02:42 PM
robbie374
Jul 7, 2015 02:56 AM
