HELP! wrist pins
Old Jan 6, 2005
CrewChief's Avatar
Remebers the old days
CrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of light
Exclamation HELP! wrist pins
how do you remove the wrist pins so you can change the pistons and keep the same rod?.
Old Jan 6, 2005
CIVIC808's Avatar
CIVIC808 is an unknown quantity at this point
use a hydraulic press, pin and pin driver.
Old Jan 6, 2005
CrewChief's Avatar
so you don't have to heat then up to get the pin out?
Old Jan 6, 2005
CIVIC808's Avatar
according to the manual no heating required.
Old Jan 7, 2005
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
FYI:
You will not be able to reuse the piston after removing the pin.
The press distorts it to much to use.
To install the pin, you do have to heat the end of the rod. The manual may not say it, but any good shop will heat the end of the rod with a torch and slide it in.
jammer48
Oct 4, 2018 10:04 PM
JetsterDajet
52
May 8, 2016 12:11 AM
Bruce2
Sep 27, 2015 08:45 PM
badbaja
Sep 16, 2015 08:10 PM
nixyfior
Sep 14, 2015 08:32 PM
