tune up...
Old Jan 6, 2005
AlienX's Avatar
AlienX will become famous soon enough
Question tune up...
hey hey,
I gotta go for a tune up and I was just wondering what i should do, and some parts that you guys would recommend.
Thx !
Old Jan 6, 2005
djmota's Avatar
how many miles on your car?
Old Jan 6, 2005
AlienX's Avatar
70 miles... live in Canada so im under the sever maintainace
Old Jan 6, 2005
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
Some things I would suggest are sparkplugs, transmission oil flush/change, coolant flush/change.. brake pad/rotor change? I dunno.. I think someone else would have some better suggestions
Old Jan 6, 2005
AlienX's Avatar
I already dida tranny flush, pads are still good for now..
I'm pretty sure I gotta change the timing belt also,
what kind of plugs do you guys think i should get ?
Old Jan 7, 2005
4jacks's Avatar
4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light
I don't have my manual on me, but I'm positive the timing belt is after 100k .
Old Jan 7, 2005
2K1Civic17"Gabe's Avatar
i believe timing belt is 110
Old Jan 7, 2005
Nameless's Avatar
TURTLEonK
I guess you can check ur belts to make sure they arent cracked or drying up.. everyone says you should go with the NGK Iridium IX?
Old Jan 7, 2005
AlienX's Avatar
well, i have 113 KM but thats bout 70 miles... and ya, i did check my manual. When they say change the brake fluid, where do I find the plug to flush it ?
NGK Iridium eh... is there a certin temp that I need them at ? My engine is bone stock.
Old Jan 7, 2005
NGK iridium IX stock replacements from sparkplugs.com
air filter
greased lightning fuel system cleaner
gas line antifreeze (do not combine with above)
4gauge ground wires to upgrade stock
brake fluid
tranny fluid
a/c service
cooling system service
oil change
timing belt (and crank pulley)
cabin filters
fuel filter
alignment
thermostat
compression check
and alot more.....
Old Jan 7, 2005
wait 70 miles? You don't do anything that's like a new car.
Old Jan 7, 2005
AlienX's Avatar
70k :P meep meep
Thx Gear !!! oh... and anyone have an answer to to flushing the brake fluid ?
air filter - Done already
greased lightning fuel system cleaner - I will pick some up
gas line antifreeze (do not combine with above) - there is antifreeze already added to canadian gas
4gauge ground wires to upgrade stock - I think I will go with 2g, stock grounds are all oxidizing Good recommendation
brake fluid - how do you flush ?
tranny fluid - did 5k ago.
a/c service - I will leave it for the summer
cooling system service - ??????
oil change - done
timing belt (and crank pulley) - I will done
cabin filters - wait for summer
fuel filter - Ive read that its not really that important. Ive only used premium brand name fuels.
alignment - did 4 months ago w/suspension upgrades
thermostat - since i'm gonna do a rad flush, might as well...
compression check - DIY of course... just gonna rent the guage.
Thx for everything guys...
Old Jan 7, 2005
cooling system basically drain/refill green antifreeze and replace thermostat (inside the flow of coolant).
Old Jan 8, 2005
AlienX's Avatar
:P rad flush... you should have just said that... you gearbox, making things all complicated
Old Jan 8, 2005
4jacks's Avatar
You have to bleed the brake fluid from each wheel... I'm suppose to be writing a DIY on that I have picture but hey i'm lazy ..
Anyway the There is a Bleeder screw on The caliper in the front, and on the drums in the back you stick a small piece of clear vinyl hose on that and loosen that. someone pushes the brake down, tighten the screw while brake is depressed all the way. and keep repeating the process for each wheel, and always checking to make certain the brake resiovoir is full.
Old Jan 8, 2005
AlienX's Avatar
hehe, would you mind sending me some pics on how u are bleeding them..
Old Jan 8, 2005
ya 4jacks is right. Just vacuum out the old cabin filters.
Old Jan 10, 2005
4jacks's Avatar
Sure, I'll see if I can dig em up when I get home. Can you post up your e-mail so I don't have to look it up...
I am lazy you know
Old Jan 10, 2005
AlienX's Avatar
patrykf@gmail.com or patryk@cogeco.ca
give them both a shoot...
Old Jan 11, 2005
4jacks's Avatar
will do , sorry haven't been home
Old Jan 11, 2005
AlienX's Avatar
np, no rush...
thx a million
UltraHDGames
Jun 8, 2016 05:16 PM
shadowfist
Oct 18, 2015 02:38 PM
Dawit Melese
Oct 4, 2015 08:02 PM
Zedoc
Engine Swaps
Sep 12, 2015 04:27 PM
NaturalSelectio
Sep 6, 2015 06:59 PM
