M3 mirrors mounting problem
Old Jan 5, 2005
sta11ion's Avatar
sta11ion is an unknown quantity at this point
The M3 mirrors I got off ebay have these 3-one inch plastic cylinders that are on the spot where there should be some sort of stud or screw. On the stock mirrors there are 3 studs that are connected to the car by three bolts. On my new mirrors there are just three plastic cylinders with holes in them. I need help on how I could attach these mirrors to my car. I have a 2001 LX coupe.
Old Jan 5, 2005
nismostreets21's Avatar
nismostreets21 can only hope to improve
those plastic cylinders fit into the black triangle n then the triangle goes into those 3 bolt holes
Old Jan 5, 2005
Matulin407's Avatar
Matulin407 is an unknown quantity at this point
i think u need a base, but im not sure. it shoulda came with one i think, anyways goodluck, i still got my slr mirrors on BACKORDER!!!!!!!!!
Old Jan 5, 2005
QBoi's Avatar
Is it the one with LED or not?
Old Jan 5, 2005
_Viper_'s Avatar
Duct Tape i say
Old Jan 5, 2005
sta11ion's Avatar
With LED. Still cant fit them on. Still trying.
Old Jan 5, 2005
suthrninca's Avatar
suthrninca is an unknown quantity at this point
I ran in to that same problem when I installed my m3 mirrors (also ebay). I just took the mirror(base also) to auto zone and found some bolts that would thread into those 3 cylinders. The shorter the bolt, the better, as long as you have a 3/8's of an inch or so threaded into the cylinder(mounting point). I used some nuts as spacers on the bottom 2. I think I had to drill out the holes in the door a little, not a big deal though. Here's what mine looks like:
Old Jan 5, 2005
do they sell mirrors without the led light in em?
Old Jan 5, 2005
suthrninca's Avatar
Yes they do sell them without the LEDs. I forgot to mention you will have to take the door panel off to get to those bottom 2 bolts.
Old Jan 5, 2005
any links?
Old Jan 5, 2005
suthrninca's Avatar
yep.
http://www.streetstyler.com/ArospeedM3Mirrors.htm
http://www.itsrealstuff.com/html/m3_..._non_led_.html
Old Jan 6, 2005
sta11ion's Avatar
Thank You very much. What you said worked very well. Thanks to everyone who left feedback.
Old Jan 6, 2005
QBoi's Avatar
You should take some pics with them painted and mounted. Hope it looks good
Old Feb 3, 2005
Echelon04's Avatar
The one and only....
Echelon04 is an unknown quantity at this point
My car is Magnessium Metalic color...Do you think the carbon fiber ones would be tight? Also, I am stupid how do you wire the led?
Old Feb 3, 2005
chicohonda02's Avatar
Since 2002 Baby!
ok i'll post pics later, but i ran into this the other day. Use screws with washers and screw the screw on the holes that match up. 3 screws total. hope that helps. Pics up later today.
Erndog81
Oct 31, 2015 03:01 PM
reqy
Jun 1, 2015 07:05 AM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
GH04si
Apr 15, 2015 08:13 PM
Tamron143brr
Dec 14, 2001 08:11 AM
