Spring popping when turning (New suspension and mounts)
Old May 31, 2015
reqy's Avatar
reqy will become famous soon enoughreqy will become famous soon enough
I just installed new Tokico suspension and H-Tech Teins with new OEM Strut Mounts and bearings. Whenever I turn hard left, you can hear a distinct popping sound. Looking under the car, you can see that the springs aren't turning smoothly at that angle. They kind of do a slight tick at the top of the spring. The bottom part of the spring is seated fine and doesn't move.
Does this usually correct itself over time or is there a problem there I need to fix.
Maybe with an issue with how the spring is seated at the top?
2003 Honda Civic EX Coupe
Old May 31, 2015
Re: Spring popping when turning (New suspension and mounts)
Spring indexing
Old May 31, 2015
GolNat's Avatar
Prelude Owner
^ agree
Check here:
https://www.civicforums.com/forums/4...like-pics.html
Old May 31, 2015
reqy's Avatar
Thanks for the quick reply, guys.
The Tokico's should have a mark too where we can align it, right? It's kind of dark outside right now but I can take a look tomorrow when I get back under there.
When I was watching a videos and DIY's they talked about the rears lining up, but not the fronts.
Thanks again!
Old Jun 1, 2015
GolNat's Avatar
Prelude Owner
They should have a mark on them but if not you can tell the orientation of the bottom perch from where the tie rod arm is in the picture.
oneheadlight
Apr 29, 2015 11:30 PM
bsmiley
Apr 27, 2015 01:27 PM
GH04si
Apr 15, 2015 08:13 PM
supercivic01
South
Nov 30, 2001 11:27 AM
