Log In
View Full Version : General Honda Civic Forum Archive.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 [53] 54 55 56 57 58 59
  1. One big mod question...
  2. wheel/tire weight comparison
  3. Please read!-Static or Dynamic wheel balancing?
  4. Help:Check engine light on after stalling
  5. Clear headlights
  6. Mirrors...
  7. NEED ECM Wiring Diagram ASAP
  8. wheel queston PLZ HELP!~
  9. Lowering Car?
  10. 2.25 or 2.50 PIPING?????????????????
  11. DIY Alarm/Remote Start (Wire Colors/Tips)
  12. RSX Rear Brakes Fit?!?!?!?!?
  13. HOW DO YOU MAKE SPEEDO BLUE?
  14. lowering fun
  15. dyno testing
  16. 195/70/R14 snow catch went lowered
  17. How Do You Remove Superglue?
  18. to antidote or whoever else can solve sqeaky springs
  19. Help with installing door handles
  20. Indiglo Type R knob
  21. HELP WITH COILOVER INSTALL ASAP
  22. Wire Loom Question...........
  23. HELP!!! Anybody who's had condensation in tail lights?
  24. Possible DIY for Injen CAI problem.
  25. Dash Lights in Blue!!!
  26. Attn: Technically/mechanically inclined people
  27. The cvt query
  28. Civic SI Suspension
  29. Clutch, Nobody really did say........
  30. Correct me if I am wrong...
  31. Somethings wrong with my Indiglo Gauges...
  32. Scratch remover that works along with factory touch up paint???
  33. Removing Body kit?
  34. ONCE AND FOR ALL...NITROUS OXIDE 101 FOR NEWBIES AND EXPERIENCED RACERS! THIS IS A MUST READ
  35. Greddy Turbo'd RSX info that pertains to us...
  36. Help with sedan light install
  37. Installing trunk release
  38. Attn: Boost.........Air/Flow Meter
  39. Headlight bulbs, H4?
  40. power outlet removal
  41. DIY: tricked out trunk
  42. Program Keyless entry
  43. offsets..42 or 45
  44. rims and putting them on my ride
  45. Timing?
  46. PLEASE READ: Tachometer REV Limiter Question?
  47. ATTN SEDAN OWNERS: where did you put your ..
  48. Where can I get a red leather steering wheel cover??
  49. has any one had trouble installing.....
  50. Painting and re-finishing
  51. holding the grill?
  52. Do we have a DIY on an front upper strut bar??
  53. Big Brake Kits for 2k1+ Civic?
  54. Disable Clutch Start?
  55. Newbie question from a member-Rims
  56. ECU chip
  57. PLEASE HELP!!! SRI Installation; Malfunction Light on?!
  58. Fog Light Help................
  59. Magnaflow on DX/LX vibration
  60. Installed Alteeza Grill
  61. quick question on offset
  62. Shim the front?
  63. BRAKE PADS!!!
  64. Just got car back... Ground strap on spark plug?
  65. DIY Koni Stuts
  66. Attention RiceBurnrEX
  67. resetting srs light?????
  68. who has installed...
  69. has anybody combined
  70. Man't Required light is going off..?
  71. Wireing a black light?
  72. honda maintenance
  73. I have 2 newbie ?'s :)
  74. drill hole in headlights...
  75. car level
  76. Everybody who painted their interior and it is peeling...
  77. Installing a strut bar in a manual LX
  78. 2002 dx question
  79. Fog light switch -Help!
  80. Tint Question
  81. TECH heads: Wet or Dry NOS?
  82. SideMarker Q!! please reply
  83. DIYers ?....How to change the Wiper BLADES?!?!
  84. HELP: check engine light came on!
  85. ? about dash illumination
  86. Air/fuel meter by Auto METER
  87. autometer question
  88. How do you remove the dash?
  89. When do u change ur oil?
  90. Auto tranny Q
  91. Stock Airbox?
  92. summer tires ok for winter?
  93. Power Window Not Working!
  94. Update on compustar alarm!!!please read!!!
  95. Simple solution to shift boot hanging
  96. Question about compustar alarm Please read!!
  97. grinding gears....how bad is it!?
  98. someone with prolonged use of 17s on their 2k1 please respond
  99. Brake Pad Install Help.. Quick..
  100. Spring Installation
  101. wiring interior neonz... WHODUNNIT???
  102. monster truck konis
  103. backup fuse question
  104. RPM GUAGE NOT WORKING HELP!!!!
  105. 3M Scotch Gard rocks!!!!!!!!!!!
  106. switching from gc's to neuspeed springs
  107. SUSPENSION
  108. How 2 Remove....
  109. Where is(are) the power windows fuse(s)?
  110. Mystery Metal Revealed!
  111. HELP with my stock alarm
  112. Wiring neon in trunk
  113. How do you install headlight bulbs?
  114. ~~Wiring Setup for 2k1-2k2 civic~~
  115. DIY Vinyl Car Seats
  116. Interesting Thread for the nOObs..
  117. Body coloured strip on boot lid
  118. Spark Plugs
  119. Can anyone let me know how exactly to shave my "Civic" emblem off?? DIY link is not workin
  120. Intruder ?
  121. Intake Resonator
  122. How Do you take pictures W/ neons
  123. Locking the Driver's Door Automatically
  124. scared of CAI!
  125. Gas Deductions for Using INTAKES
  126. where would you get illumination from???
  127. ATTN:Slam2k1civic....19s? ANYONE ANSWER
  128. just asking for a little help
  129. What kind of engine?
  130. Need Injen CAI install help fast!
  131. DIY Soon: Acura RSX Rear Sway Bar Conversion
  132. K20A Engine info...thought it was interesting.
  133. NOIZE IN PIPES
  134. this chip in the key business
  135. Long Awaited MagnaFlow DIY
  136. springs: tie rod
  137. Can someone please give me a DIY for upper grill
  138. **Re-adjust passenger seat**!!!
  139. HOW TO MAKE SPEEDO BLUE?
  140. Camber kits with coilovers?
  141. ECU wiring for AFC (pics)
  142. Where is the ecu located
  143. DIY mega thread problem
  144. Shop In Ohio????????????
  145. Anybody got an intake like me??
  146. anyone try this mod yet .. is it worth it???please give opinion
  147. Anybody know anything about this??
  148. drop with camber kit??
  149. musical intake?
  150. A'PEXi LOWERING SPRINGS: anyone?
  151. Wings West Avenger Front Bumper
  152. Wiring Diagram for ECU
  153. MagnaFlow Muffler
  154. lowering springs...
  155. autometer shift light
  156. Turbo possible after these mods?
  157. air turbulance under hood if add new vents???
  158. just installed hp
  159. recalibrate odometer
  160. How fast is the acceleration on Cruise Control?
  161. exhaust resonator?
  162. Help !! AEM Short Ram Intake Problem.
  163. Any ideas? Help please
  164. Coilover Controversy
  165. v-tec light
  166. New Cams
  167. solo/DC or Revo?
  168. Installing Mesh Grill?
  169. EGT Gauge
  170. ram air hood anyone??
  171. where can i get a bypass valve for my injen CAI?
  172. Gas cap and Check Engine Light
  173. brake conversions?
  174. poly camber kit
  175. Splash Gaurds
  176. Does ABS disable after dropping car?
  177. Does your e-brake suck?
  178. Hyper Whites ... and yes i searched
  179. info on the D17a2
  180. Differences of 2001 lx and 2002 lx
  181. sanding
  182. Idle Vibration
  183. removing trim piece
  184. Please help quick!!!
  185. That lil' clear reflector in the corner of the headlights...
  186. Side View mirror
  187. HURRY HELP...HOW DO I TAKE THIS OFF
  188. DIY Painting Trim Pieces
  189. My Altezza's are foging
  190. QUESTION ABOUT CHROME PROJECTORs AND BULBS~!~!~!
  191. WHY 17 WHY NOT 18inch
  192. CRAP! #)*&$
  193. Troubleshoot Wheel Vibration?
  194. reset check engine light
  195. What cars to T25 turbos come on???
  196. What to do w/Intake?
  197. custom 2.25" piping
  198. Can anyone supply pics of the rear lower arm where the endlink is?
  199. LOWERing problem!!!!!!
  200. DIY relocating HU
  201. trunk latch DIY
  202. front hood deflector....take it off or leave it on???
  203. (Ghetto-style) Turbo!
  204. ? 4 those of you w/ nitrous oxide
  205. Ghosty's New DIY
  206. hows the octane fiberglass kit look like???
  207. Intrusive or Resistance Engine?
  208. Anyone with a trick trunk??? I need help asap!!!
  209. super charger
  210. Anyone with the TYC Projectors installed......
  211. SuperCharger/Turbo
  212. Car Higher in Front than Rear
  213. Carbon fiber hood buffing? PLEASE HELP!!
  214. Should I bother with camber adjust??
  215. CAR REVING UP AND DOWN BY ITSELF
  216. bypass on Injen CAI
  217. Anyone install fuel pressure meter???
  218. Compartment/Switch Board Set-Ups
  219. Ebrake Button?
  220. shocks set-up
  221. what do you guys think
  222. diy springs
  223. Exhaust??
  224. Everybody else is doing it..
  225. Head light bulbs
  226. tanabe super racing medalion
  227. Rim Requirments!
  228. modified stock intake?????
  229. Washer fluid warning light
  230. Techs Plzzzz Answer...
  231. Clearing headlight same for 6th gen Civic?
  232. Where's that rear deck removal DIY that someone posted before?...
  233. QUICK ?
  234. cleared headlights but...
  235. DIY side markers
  236. Head Unit Relocation
  237. missing threads
  238. RSX shift mech.
  239. ATTN ALL: Steering wheel?!?!?!?
  240. 215 or 205?
  241. Tightening the Clutch
  242. RPM Level at 62mph
  243. turning off a/c when you turn on defroster
  244. D series exhast manifold????
  245. Why relocate tire....waste of energy!!!
  246. How Indiglo Works (TECH ARTICLE for you peeps w/ questions about how they worK)
  247. ATTN ALL: Plastic Parts behide Steering Wheel?!?!?
  248. 'The A Panel' removal help.
  249. Dash Lights: Cruise Ctrl, Pwr Mirror & Moonroof switches
  250. HELP: Streeing Wheel Removel?!?!?!?!
