Side View mirror
Old Apr 13, 2002
ThUgGiNAzN's Avatar
ThUgGiNAzN is an unknown quantity at this point
Side View mirror
sumone broke mah side view mirror and i need to take it out can anyone tell how to do dis?
Old Apr 13, 2002
sevenincubus's Avatar
sevenincubus is an unknown quantity at this point
a member once mentioned he needed to install m3 mirrors but need a diy to remove the door panel to get to remove the side mirrors. the DIY section at the top of this site shows you how to remove the door panel. even though it doesnt show how to remove the side mirrors he may be of some help
Old Apr 13, 2002
JBlazeVA's Avatar
JBlazeVA is an unknown quantity at this point
ryan ask jason...he might know somethin because he gots m3 mirrors, why not jus upgrade to those anywyas?
Old Apr 13, 2002
Sampsonite's Avatar
Sampsonite is an unknown quantity at this point
It makes it really easy if you take of the door panel...Then there are three bolts in a triangle pattern...yeah...take those out and disconnect any wires...you can get Power m3 Signals off of eBay for 150.00...that's what i did....i had the same problem you do...there's a diy for taking off the door panel here!
Old Apr 13, 2002
avenger's Avatar
avenger is an unknown quantity at this point
can't you just remove the sail panel???
Old Apr 14, 2002
Sampsonite's Avatar
I just removed the tweeter on the passenger side, and the bolts were nestled behind the door panel, so i took it off when i did the driver side...a lot less hassle...just don't break the panel like pseudochrist....good luck
Old Apr 14, 2002
Grey's Avatar
DIY King
Yeah, all you do is remove the tweeter panel in an EX, or that little triangular piece of plastic in all other models on the inside of the car near the mirrors. Just pull and it'll come off. Be somewhat gentle though. Then you'll see some bolts. Roll down your window and hold the mirror from the outside while you unbolt it from the inside. I think the plug for power mirrors terminates near that triangular piece of plastic, so un-hooking it and hooking up the new plug will be easy. If not, then you'll have to remove the whole door panel to access the terminating point of the wire harness. I think they're plug and plug type connectors like the speakers have. If not, then you'll need to get busy with the wiring. Anyway, just spewing out what I know...
igorbogu
Jul 10, 2015 09:29 PM
671civicLX
Jul 9, 2015 03:22 PM
ballmich
Jul 9, 2015 11:59 AM
Dean Walker
Jul 7, 2015 02:27 PM
SLeePeR012
Jan 7, 2002 12:24 AM
