Attn: Boost.........Air/Flow Meter
Old Apr 25, 2002
JDQuikCivic's Avatar
JDQuikCivic is an unknown quantity at this point
Hey man, I'v been trying to find someone to help me out with installing my A/F meter but no one is responding back. All I need is where I can put all the the wires. I saw your set up and it looks pretty tricked out. Where can I hook up my Positive 12v wire from the a/f to the positive ignition of our car. Also, where did you hook up your signal wire, near the oxygen sensor or near your ECU. And one last thing, where did you route all your wiring? Thanks for your help[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Apr 25, 2002
Boost's Avatar
Boost is an unknown quantity at this point
i wired the positive directly to the engine so it is always on....i did this so that even when you have the engine off there is a little light on your dash that stays on....kinda like a mock security system...at least it would make the potential thief think twice. the signal wire was attached to the o2 sensor, i just ran it though the firewall...just make sure the wire dosnt rest on any moving parts of the car <TRUST ME! > at the 02 sensor there should be like 4 wires, so just try multiple guess....when i did it, it was at 12 at night and my flashlight went out, so i hooked it up with only my lighter and electrical tape, but i THINK it was a green wire <dont quote me> as far as routing it, you can do it two ways, first you can bring it through the firewall, recomend this one...jsut find the grommet and pull it through, or second and more ghetto, would be in the door, and bringing it though the seam between the fender and windshield piller, you can only see it when you open your door, and its quicker, but i recomend going through the firewall.
Old Apr 25, 2002
Hey, thanks alot for the info! I've been told that the signal wire for the O2 sensor is black w/ white stripe but I could be wrong
h4ldol
Apr 24, 2017 08:16 PM
jsmithe2010
Regular Maintenance
Sep 25, 2015 08:15 PM
Bruce2
Sep 21, 2015 08:01 PM
Civic720
Sep 10, 2015 10:06 AM
Bricoleur
Sep 9, 2015 12:23 PM
