Removing Body kit?
Old Apr 25, 2002
FlashFlood's Avatar
FlashFlood is an unknown quantity at this point
Removing Body kit?
The place that put my body kit in addtion to useing other parts to install it used double sided tape whats the easiest and safest way to remove the tape?
Old Apr 25, 2002
2k2civicballer's Avatar
2k2civicballer is an unknown quantity at this point
pull slowly, and use water mixed with dish soap to help loosen the grip from the tape
Old Apr 25, 2002
Crashoveride's Avatar
Crashoveride is an unknown quantity at this point
Might want to try giving it a bit of heat too to soften it up first, something like a hair dryer or if you have it a space heater would work in your garage, just put it in front of the car for a bit till the room heats up and the bumpers / sides just dont put it too close to the car.
Old Apr 25, 2002
mwwhonda's Avatar
mwwhonda is an unknown quantity at this point
two words: goo gone
Old Apr 25, 2002
bzrollin's Avatar
bzrollin is an unknown quantity at this point
Rub the thick parts off with your thumb, then use something like goo gone to get whats left.
Old Apr 25, 2002
DcatStylee's Avatar
DcatStylee is an unknown quantity at this point
Hrm... I work at an auto detailing shop, and we use something called Hot Solvent. It smells, feels, and burns just about like lighter fluid, but I wouldn't try lighter fluid. Check your local... chemicals store. Investing in a bottle is really worth it. It can get anything off of a car that isn't supposed to be there. Just remember to go back over the spot with water, for the hot solvent will eat paint when given time.
Old Apr 26, 2002
JBlazeVA's Avatar
JBlazeVA is an unknown quantity at this point
why taking it off?
Old Apr 26, 2002
Tony's Avatar
Tony is an unknown quantity at this point
take a piece of fishing line, double it up and run it between the body kit and the car. this should essentially "cut" through the tape which will allow you to take the kit off. then, use some goo-gone or adhesive remover to get the remaining tape off. you might need to use some heat to soften the tape up before you use the fishing line but, if you do this, be extremely carefull not to heat up one single area long enough to damage the paint.
--tony
trellex
Electrical
Jul 9, 2015 12:01 PM
GaryFishell
Apr 24, 2015 06:49 PM
deception420
Mid West
Dec 9, 2001 04:35 AM
1slo2k1civic
Nov 21, 2001 11:07 AM
Micks2K1
Nov 14, 2001 09:33 PM
