Can anyone supply pics of the rear lower arm where the endlink is?
Old Apr 12, 2002
DriftR's Avatar
DriftR is an unknown quantity at this point
I need pics of an EX, 2002 LX. I have a 2001 LX and I have to fabricate the stupid metal projection that the endlinks for the sway bar attach to. You guys have it already molded into the arm. I would like as many angles and clear closups of the metal projectionas you guys an give. If all goes well, I'll post the DIY for 2001 DX/LX and 2002 DX for the RSX sway bar installation. Thanks.
Old Apr 12, 2002
slikor's Avatar
slikor is an unknown quantity at this point
i took some pics a little while ago for Grey when he wanted to see if 01 LX's had the mount req'd for anti-sway bar end links. hope they help ya[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
BTW: i have a 2001 EX Coupe
body mount (close)
end-link (close)
rear arm (wheel off)
rear end-link (close)
rear end-link (superclose)
rear suspension
rear suspension (full)
rear suspension (full, far)
rear sway-bar
Old Apr 12, 2002
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
The only thing I worry about is having to weld onto the factory trailing arm. For sure you will have to remove it, and then weld the tab in, and reinstall it. Plus with the tank right there on the left side, it may be an issue.
Me, I bought an EX, but I would seriously consider just buying the EX rear arms. The arms new would set you back 300, but maybe searching at a honda wrecking yard, you could easily find them, just a thought. Unless you have access to a good welder you are hacking on something that supports your car. I am not saying to not try it, just be sure of your willingness to do it correctly. The best is that the sway bar would come off and the car would lose control. The worst, a bad weld job cracks the rear arm and you fly off a cliff. Neither is a good bet. At least if you have the stock arms you would not have to worry.
Old Apr 13, 2002
DriftR's Avatar
Perfect. Machining that little metal piece and welding it in seems to be a simple job. Thanks for the pix.
Old Apr 13, 2002
slikor's Avatar
no problem
let us know if you ever do it, and im sure Grey would like to see too[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Apr 14, 2002
DriftR's Avatar
It will be done soon.
7thgensurvivor
38
Aug 29, 2015 11:50 AM
WKD DRGN
Jun 18, 2015 07:56 AM
Galvezj11
Jun 17, 2015 04:13 PM
bsmiley
Apr 27, 2015 01:27 PM
ImmortalEX
Nov 8, 2001 09:52 PM
