SuperCharger/Turbo
Old Apr 11, 2002
Toad's Avatar
Toad is an unknown quantity at this point
SuperCharger/Turbo
Okay, I did some searching on the forum and the general internet and couldn't find my answer...
I saw a car with BOTH a supercharger AND a t3/t4 turbotronics single turbo.
Now, its brought to my attention that it is IMPOSSIBLE to have both a supercharger and a turbocharger in a car.
My question is, can you have both? why or why not?
I'm asking this question because in the future...( I'm guessing in about 7 years after i finish college and have a stable job) ...I want to purchase a 99-01 Honda Prelude. My goal is to create a bad *** 4 cylinder import that can beat a stock v12 viper (or is it v10?) Anyway... 1 choice is a supercharger + NOS + other mods... another was turbo (or twin turbo, yes IT IS possible i've SEEN IT) + NOS + other mods.... now the turbos are the only chance ill have of reaching 500hp BUT if I can some how hook up a supercharger with a t3/t4 turbo and a nice shot of NOS...then i might have a good chance of pulling this off..
ANY COMMENTS WILL BE USEFUL!!!!
-Toad
Old Apr 11, 2002
mikalem's Avatar
mikalem is on a distinguished road
I guess technically it COULD be done (good luck doing it though) because the turbo runs off of the exhaust fumes where the supercharger would get it's power straight from the crank of the engine...... good luck getting all of that to fit in one of honda's tiny engine bays though! [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Apr 11, 2002
nochopstix's Avatar
nochopstix is an unknown quantity at this point
have fun blowing your engine
Old Apr 11, 2002
SuziQ's Avatar
SuziQ is an unknown quantity at this point
get the entire engine made of titanium and you'll be
Old Apr 11, 2002
black2k1vtec's Avatar
black2k1vtec is an unknown quantity at this point
you got a long expensive way to go to get a fat heavy lude into the low 12's.
Buy a 92 hatch, a B18C1 mildly built and a turbo kit, youll be there in less than half the price, plus you will look better too!
Old Apr 11, 2002
1973's Avatar
1973 is an unknown quantity at this point
.......ok toad, there are more cars than you think running a supercharger + turbo set-up....the ideal behind this kind of set-up is that the supercharger kicks in at a very low rpm giving you great low end power and helps spool the turbo a lot faster.....once the turbo reaches desired boost levels the Scharger shuts off and the turbo takes over....it's a complicated system that's obviously all programmed to work that way......nothing will happen to your engine as long as you do the proper internal work and of course, proper fuel management and spark......another, much less expensive way to get simular results is to use NOS to give a low end punch and spool the turbo faster.......no matter what form of forced induction you choose, you will have to prep your engine and engine management systems accordingly........if you want something that can keep up to a viper (v10)....you don't have to get so exotic in your buildup....the secret is really weight, buy the lightest civic you can, a 5th gen cx, which weighs in at around 2000lbs.....drop in the H22a from a 97+ prelude and your already in the 13's.......put the civic on a diet....add a good intercooled turbocharger running around 10-12psi of boost and you will hit 12's....go find a viper....
Old Apr 11, 2002
Duckor's Avatar
Duckor is an unknown quantity at this point
supercharger would run in place of the turbo lag since turbos are usualy more powerful than SC's.
but i've never seen this setup done before..
Old Apr 11, 2002
AFlyer's Avatar
AFlyer is an unknown quantity at this point
1973: a supercharger can never shut off in favor of a turbo if you are running both. the supercharger is run by a belt connected to the crankshaft, and there is no way to get all those mechanics to simply stop turning. there is a point, once the turbo spools, that both are providing boost, but the super can never shut off.
Old Apr 11, 2002
uicmedruss's Avatar
uicmedruss is an unknown quantity at this point
can you say...well beyond my pool of knowledge? hmmmmmmmm... yeah
Old Apr 11, 2002
toastyghosty's Avatar
toastyghosty is an unknown quantity at this point
as itterated by quite a few ... it is possible..and there are quite a numerous amount of cars out there running twincharger setups...
if you flip back to one of your old issues of SCC, i think it's one of those meanest street machines issue or something there's some dude in a very DIY'd up mr2...running a both a super/turbocharger although it's so makeshift that even SCC editors were dissing the dude hahah but it worked.
there are of course better examples of professional installs etc that run extremely well however...but i figure you could just look that up in your collection of SCC. =o)
edit
hahha wait a minute just realized your "TOAD" not "TURTLE" hahah okay i have no clue if you read SCC hahah
Old Apr 12, 2002
HP's Avatar
HP
HP is an unknown quantity at this point
Well anything is possible I guess you can have a pressure operated clutch on the supercharger so it shuts off when the turbo is spooled up. For example the Rotrex supercharger doesn't restrict airflow when it's not spinning. If it's an advantage of doing this I don't know but technically it IS possible.
Old Apr 13, 2002
dragoon's Avatar
what's the point of making a drag car like the ones everybody wants? i'd rather waste my money on a full-blown luxury sedan or a super sports car.
Old Apr 13, 2002
Mitch's Avatar
Mitch is an unknown quantity at this point
<< 1973: a supercharger can never shut off in favor of a turbo if you are running both. the supercharger is run by a belt connected to the crankshaft, and there is no way to get all those mechanics to simply stop turning. there is a point, once the turbo spools, that both are providing boost, but the super can never shut off. >>
Whatever!!! Dude have you ever heard of a electro-magnetic clutch. How do you think an A/C compressor cycles on and off? duh?
Old Mar 3, 2004
CelCUs's Avatar
CelCUs is an unknown quantity at this point
***Brings post back from the dead ****
Anyone know where I can get pics of a twincharger set up or info on one? Just curious to see it . . .
Old Mar 3, 2004
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
your going to college now and 7 years you want to build on what will be a piece of crap?
technology would be cheaper and faster 7 years from now.
MOst 4 cyls will be just as bad *** as a v10 of today.
Old Mar 3, 2004
CelCUs's Avatar
Yeah . . . ummmm . . . he posted that damn near 2 years ago. I was on my350z.com looking up stuff on superchargers and then did a search on this site and that thread came up. I'm just curious to see the twincharger set up.
I wouldn't expect him to respond anytime soon.
Old Mar 3, 2004
zachgeyer's Avatar
i am waiting a few year too
