- [ Possible Motor-Swap ]
- Parking Lights Fuse
- 5 lug conversion?
- THE nitrous post
- in need of some help here
- Problem with AC after installing a CAI
- Custom Pulley
- Can I lower my civic manually?
- Tach for youre dx!!!!!
- 4DR and 2DR Spoiler ?
- Rear Wiper Conversion- possible?
- Pics of DIY lower grill after cutting out the black crap
- Civic Intake?
- Possible to DIY a rear lower tie bar?
- Does anyone know the average labor cost for installing lowering springs???
- All Venome users
- Rear strut bar or rear tie bar?
- Cleared Healights but still problems??
- Who has installed a remote trunk release?
- Strut Bar Help !
- 17's in front, 18's in rear?
- Factory Camber Adjustment?
- DIY: COILOVERS?
- So, what is happening with Htown's swap?
- pulley
- need carb sticker for aem intake
- Can you install a "memory device" for passenger seat walk-in feature?
- Hood light attached to OEM alarm
- Questions about 18's
- Connecting to the battery
- Gas Line Anti-freeze?
- Fuel Injector Cleaner?
- Rear upper strut bar... Does it fit in the trunk well?
- turbo 2002 civic ex?
- what's to be expected from a turbo?
- CAI for auto?
- Painting interior?
- clearing headlights harder than you think!!
- civic specs?
- When my tires shakes......
- diferences in the rsx suspension?
- diy:dash light
- I NEED MORE FUEL!!!
- RSX crap
- Fuel Delivery
- Exhaust on Sedan
- Fog Light Condensation
- Important recall//////seat belt latch
- Cat Converter
- Flange bolt question.
- exhaust's effect on gas mileage..
- Intake reset ECU
- fog light switch change for 2002?
- Found the Headlight Adjustment
- Light sizes
- D16 swap
- Springs for sedan. . .
- After SRI install....clock won't set
- installing new headlights...help please?
- brake pads????????????
- how to reset Maintenance reqd light
- DIY : Headlights
- Rear Bumper Alignment
- swap: long version
- Spinning Tires?
- I just crashed. Need help
- Shaved Door Handles for 4-door civic
- strobe light positioning
- Exhaust installation
- lug pattern
- DIY: Rotor and Brake Pad Install
- DOHC head swap?
- How many valves?
- LED Washer ?
- some questions on spring rates & coilovers
- LED BULB REPLACEMENT
- re-calibrating Speedometer
- 'nother neon question
- purple headlights
- HELP :)
- Anyone Have Problems With Eibach ProKit & Ingalls Kit?
- installing coilovers on 2k1 coupe?
- Intake Air Bypass Valve
- What miles is it best to change ur oil at?
- problem with interior neon
- stock spoiler add-on
- Spoiler Question
- Prelude Engines?
- installing fuel press., volt meter and H2O temp gauges
- where 2 buy REVERSE INDIGLO??
- OBX Type-R Racing pedal problems
- are jackstands really needed to remove ft bumper cover?
- Struts
- 03 si head
- Help!! With lower grill installation
- Info on head swap
- Turning off trunk light - the solution
- indiglo installation..
- FOR THOSE INTERESTED IN A SWAP FOR THEIR 2K1
- what upper strut bar will fit with injen short ram?
- Skunk2 front bar fit?
- man do i have a problem!!!!!!
- new brakes?
- help on taking out trim parts
- Compustar Alarm
- HELP ME
- Need mod suggestions - not just bolt ons
- turbo and gas mileage
- Airbag question - SRS
- help on removing
- How does hood Locks work?
- How do i take off the trim around the window control??
- DIY: Lower Grill Anyone???
- DIY: Painted Winshield Wipers???
- whats so good about carbon fiber hoods?
- Relay Under Stearing Wheel (DIY: HyperBlinker???)
- throttle cable went nuts on me!
- whistling noise from cold air intake
- total Plans for 2002
- Calibrating Speedometer?
- DIY install of moonroof visor - not as easy as it looks
- Headlight Clearing Complete :)
- Throttle Cable Pics
- Headlight Clearing!!!!!!!!!!!!!!
- install vtec controller
- Anyone with alarm, please help!
- TEXAS LAW?
- AEM and warranty
- z3fenders, can you see in the slits>?"
- 2002 foglight installation
- Quick Intake Question
- interior neon wired to dome??
- Resonator
- battery tie down
- skunk2 upper strut fit?
- HELP Clearing Headlights!
- anyone have OEM body kit??
- Clearing Head Lights
- Wiring in a couple of neons
- PIAA 1900X are not working, is it the FUSE OR BULBS?
- Removing Dashboard Cluster??????
- install a remote starter...
- ZEX nitrous
- Fuel system
- How Do You Remove The Headliner?
- changing the interior dome light (front and rear)
- Projector/Bulb Problems
- People with Black Projectors
- Anyone know if I can........ ??
- what r some good struts to buy?
- CAI's Q
- DIY Color Dash Guages
- Shaving the "Civic" and "EX" embelum
- revo technica and dc adapter
- Coolant
- shunk2 good?
- Interior Horn for Stock Honda Alarm
- DIY: Amp Install With Pics
- What is this?!
- Headlight bulbs
- AEM vs Injen CAI's
- Good news!
- Altezza Sedan Installation
- 5 lug conversion?
- Wheres the fuel line?
- YELLOW REVERSE GAUGES
- tires?
- do i need camber kit?
- DIY: Clear needles for gauges
- red bulb legal for rear turn signal
- some info on rear disc swaps
- Q on DIY Led washers
- newbie to suspension mods
- RSX Front End Swap
- DIY BACK DASH?
- accord wheels??
- honda parts for 2002
- Help me out...taking out the interior door handles...
- ??on installing Liteglow Proseries underbody neons
- Weird tire wear?
- Nokya Xenon Plasma lights
- Bad news on removing speed limiter
- Missing AEM CAI DIY!
- Another Question about turbo's with stock exhaust
- Help with gauges
- NEON LIGHTS DONT FIT......
- Springs after body kit?
- Oil Change Q...
- Difference in Coupe Vs. Sedan Headlights
- AEM Pully installation
- Oil Change
- when installing injen sri....
- Altezza's
- Spoiler->Wing
- exhaust ideas.....
- Advice needed on cleaning inside windows.
- Diameter of Stock Throttle body ?
- a q about my grill
- Oil filter cooler.
- DIY: Alarm and remote start
- DIY Clear HEADLIGHTS PROBLEM!?!?!
- Help me fast...
- DIY Heaven
- NOS INSTALL
- Automatic gears?
- Turbo question: enligten me
- Turbo suggestions from the wrong person
- AHHHHH I need help =) hehe
- Making body kit more secure?
- will a grill scratch my paint?
- Nitrous Q.(allready searched)
- I Need Your opinion on Coil over
- Computer Chip?
- Best way to shift?
- Change remote all unlock to SINGLE press
- Swapping Engines in 2k1 Civic EX
- ? on headlights
- reverse lights
- ? about torque converter
- INJEN CAI to INJEN SRI....
- Altezza/Tpye R grill installed!!!
- Found this article explaining exhaust, backpressure, and shockwave tuning
- HELP - need info on matrix coilovers QUICK!!
- Integra Type-r wing (need answers?¿?)
- Removing Stock exhaust???
- Re: New Pistons and rods...
- Different Sized tires/Speed O
- CAN YOU PUT ON A DOHC HEAT AND REPLACE SOHC?
- Exhaust Header Help!!!
- How To Adjust A Camber Kit Installation?
- ??Rear Discs??
- VAFC WILL NOT WORK ON CIVIC EX 2K1!!!!!
- Removing coil springs for coilover install
- 2002 center trim
- Neuspeed Upper strut tie bar
- AEM CAI and gas mileage
- Injen Race division cold air install?
- grill
- How do you get at your gauges?
- stock spark plug model
- Exhaust Resonator??
- Lowering affect intake??
- AT door lock Remotes
- Wanna shave the rear "H", but are there holes under it?
- porting the intake
- can i get my cam gears ajusted, to add more HPs
- Adding Vetec ???????
- DIY Shaving
- book on 2k1 civic..?
