do i need camber kit?
Old Jan 8, 2002
joefufu419's Avatar
joefufu419 is an unknown quantity at this point
i have a new set of coilover for my civic, and i want to drop it pretty low, since i have 16 rims. Do i also have to get the camber kit as well?
Old Jan 8, 2002
01civicboi's Avatar
01civicboi is an unknown quantity at this point
if ur dropping ur car pretty low, go with the camber kit.
Old Jan 8, 2002
mohawkboom's Avatar
Anything more than a 1.6" drop in the rear requires a Camber kit.. anything more then 1.9" drop in front requires one.. Answer.. Yes.. you need the caber correction kit.. I would highly reccomend the kit from Eibach.. the Ingalls kit is not as well made nor as durable.
Cheers
Mohawk
Old Jan 8, 2002
1973's Avatar
1973 is an unknown quantity at this point
i hope you got shocks because they will blow fast if you go under a 2 inch drop, and yes you will need a camber kit..........
Old Jan 8, 2002
htowncivicEX's Avatar
htowncivicEX is an unknown quantity at this point
I've heard good things about the Ingalls kits. Ground Control uses them almost exclusively for all of their alignment work.
Old Jan 8, 2002
mohawkboom's Avatar
<< I've heard good things about the Ingalls kits. Ground Control uses them almost exclusively for all of their alignment work. >>
Yup true.. but also Ingall does not reccomend Heavy duty/Race usage with their Camber kits..
Cheers
Mohawk
Old Jan 8, 2002
0100010's Avatar
0100010 is an unknown quantity at this point
Yeah, I went with the Ingalls after talking to GC, and other people I know with camber kits. It don't matter for me though, I don't race.
Old Jan 18, 2002
younggotti's Avatar
younggotti is an unknown quantity at this point
go with koni shocks and get the ingalls camber kit
Old Jan 19, 2002
TexazMane's Avatar
TexazMane is an unknown quantity at this point
my ride is dropped lower than 1.9 and i don't have a camber kit
Old Jan 19, 2002
joefufu's Avatar
joefufu is an unknown quantity at this point
but anything happens to your tires? i heard that if you don't use a camber kit, then the tires trend will be uneven
Old Jan 19, 2002
JackTripper's Avatar
JackTripper is an unknown quantity at this point
i have a friend with a 3 in drop. you can tell the camber in off but shock and struts in tack. Tire with wear quicker though
Old Jan 19, 2002
GTekCiViC's Avatar
GTekCiViC is an unknown quantity at this point
yea..... you need a camber kit to align your car......
Your wheels are aligned into a square box...... if you drop it will tend to slighty move your
alignment off by milimeters of an inch..... and if you don't adjust it your tire will wear faster.
But the wear will only be gradual.... but than it's still be more wear so I guess a camber kit is
well worth it cause it will save you money on tires.
Dave Brabant
20
Oct 6, 2015 12:44 AM
Tedverseti
Sep 29, 2015 05:41 PM
Hutch1051
Sep 29, 2015 09:20 AM
anubis62
Sep 27, 2015 12:56 AM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
