PDA
View Full Version : General Honda Civic Forum Archive.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59
  1. Hks Sld
  2. transmission conversion
  3. Where does the rear strut bar go?
  4. Quicky on exhaust coupe vs sedan
  5. Speedo Help
  6. 04 Projector Headlights
  7. another one!!! d16y8 manifold on d17!!!
  8. Primering your car for paint
  9. Is it possible to tweak urethane body kits?
  10. Aem Ems 30-1030 Released Today!!!
  11. Ep3 sport seat fitment !!??
  12. VTEC light, having some problems
  13. Header Install Problem
  14. a good way to check codes?
  15. quick question
  16. Wiper Arm Removal
  17. Is There A Diy For The Electrical Wiring For 01-03 Fog Lights?
  18. changing the lights on tone
  19. Difference Between 2dr and 4dr...
  20. INJEN IS intake
  21. need help
  22. WTF Grill wont come off HELP
  23. Any installing spoiler DIY here?
  24. How to add led blinkers?
  25. My Auxillary Port
  26. Dumb question
  27. Help With ECU Piggy back PLEASE
  28. EX Headers on an HX MT!
  29. How to split the tranny case?
  30. why not put air filter over the TB? just thought
  31. I should make another DIY: Hood Prop
  32. Fogs from eBay?
  33. anyone with front air intake?
  34. how to remove front bumper?
  35. how to remove rubber that attached to air filter housing mount?
  36. THOR Two-Way LCD Display Alarm System with Remote Engine Start
  37. Im about to get this Thor Alarm System for my Honda
  38. Debadging Front H emblem
  39. 00-05 DX same engine?
  40. shaving side moldings
  41. Sqeaky clutch? fix it then..
  42. DIY: get your car rain-ready
  43. PnP: NA vs Turbo
  44. DIY Fender Removal?
  45. Intake Performance (Gas Mileage)
  46. slipping into gear... bad?
  47. RS Grilll...
  48. Best headers for an lx
  49. VAFC2 help.
  50. Under drive pulleys
  51. new exhaust
  52. LoL, stupid dent..
  53. How to take crankshaft out?
  54. Shift light connection???
  55. Engine stand bolts
  56. EX header on DX (again....)
  57. Will they fit my car?
  58. need intake help
  59. adding a 12v dc socket
  60. Rear seat removal?
  61. Civic Top Hose Adapter
  62. Question about Sideskirts!! Need Help!!
  63. 93 Civic Ex temp
  64. Stupid question but... where is the distributor??
  65. Changing breaks on a '96 Honda Civic
  66. Drive by Wire
  67. Stock Spark plug?
  68. short shifter help
  69. stripped screw?
  70. spring problem?
  71. compression ratio...
  72. Trouble bolting RandomTech cat to Kamikaze Shorty
  73. 06 civic ex swap into 01 ex....
  74. Removing sound deadening material from trunk?
  75. 1540 bracket, L Bracket
  76. Rsx type-s injectors
  77. 05-EX-4D Parking Light + Wire Access
  78. Calculation of R/S Ratio
  79. 05-EX-4D Bumper Remove, Plastic Fasteners?
  80. coilover DIY
  81. taking off catalytic converter, hp gain?
  82. Did anyone try this? (DC adapter + viscous side-side adapter)
  83. Tips on driving manual?
  84. Center Console Armrest Removal
  85. DIY, timing belt / Valve adjustment
  86. fogs wont turn on ?
  87. Rod knock?
  88. 05 Sedan Headlight Blackout....
  89. VAFC2 and E-manage
  90. 05-EX-4DR Fog Light Installation Instructions
  91. Painting rear rotors
  92. Custom red glow cluster *DONE* pics pics pics!!!
  93. wire harness
  94. e-manage versus vafc-2 for vtec and fuel control.
  95. DX upgrade?
  96. DIY 5 Bolt Conversion
  97. RSX Interior Question
  98. Stock airbox question
  99. Problem with slave cylinder.
  100. Milled Head
  101. Adjusting Coupe Bumpers to Fit Sedan
  102. Valve Lash / Head Gasket
  103. 05 CIVIC EX OR 05 CIVIC SI(CANADA) Intake and strut bar
  104. I should know this, but I dont....lil help needed
  105. Peeps who have redid their door panels...
  106. esmm
  107. headlight conversion
  108. open ended or closed
  109. Mechanical water temp gauge install
  110. Intake Manifold R&D
  111. setting the clock.
  112. Spark plug wires...
  113. cbr throttle bodies on a civic
  114. using lx tranny in ex model
  115. for those with sidemarkers... do you have rust problems?
  116. RSX front conversion on 7th gen Civic?
  117. b16a1/b16a2
  118. Anyone using these ?
  119. LX header question?
  120. can someone explain a push start?
  121. Mounting front license place (after searched like millions forum post)
  122. quick & cheap ways to get some more power ?
  123. chair extension
  124. civic hx 02
  125. OBX Throttle body spacer and AEM CAI
  126. Need Help Quick!!!!
  127. 92-95 Civic m3 mirrors
  128. Points...Rep Whatever You Want...
  129. m3 mirrors
  130. Header Install
  131. hu relocation
  132. Trouble with A/C Compressor
  133. Removing Rear Bumper, '03 Civic EX Sedan!!!! HELP!!!!
  134. Adding cruise to a DX/VP?
  135. need help with hood latch?
  136. installing seat harnesses
  137. Honda Civic 2003 install tail lights
  138. Which Is The 4th Bolt That Doesnt Fit For Rsx Seats?
  139. Torque converter
  140. Lock and Alternator Question
  141. Altezza for 04-05?
  142. problem with black out headlight
  143. how would I be able to tell if trunk/hood/door shock sensors were installed on my car
  144. Need Help with lambo doors..
  145. Question about Altezzas
  146. Piston-rod specs
  147. Im installing automatic locks... how do I connect them to the alarm?
  148. Before I swap my gauge cluster.....
  149. Hood Shocks?
  150. WTB HELP: How to replace these parts?
  151. power windows 04 civic
  152. HP Racing
  153. A'PEXi Time?
  154. using different trannys
  155. Throttle Body Spacer ????
  156. Want power locks for my 05 Civic Vp
  157. transmission swap scam
  158. Dash painting Help!
  159. help me!
  160. rsx rear seat install question
  161. Wire Harness for Spoiler
  162. NA Injector
  163. ECU and Info it holds
  164. Shift lever disassembly?
  165. Putting a lip kit on?
  166. Anyone ever change a Cable Reel?
  167. changing the heater
  168. Switching headlight Bulbs
  169. HKS Hi-Power Rear-Section
  170. How to get through firewall
  171. bypass valve for injen RD1565
  172. Headgasket?
  173. 05 clear headlights?
  174. Clearing headlights!
  175. just random ???'s
  176. Headlight Installation?
  177. Got a question bout a tranny swap
  178. is this a good idea?
  179. supercharge anyone?
  180. constant 12v source....
  181. Auto Door Locks...
  182. Calling all automatics!
  183. 04-05 taillights
  184. D17 Info???
  185. Modified Power Windows...wtf?
  186. DIY: adjusting cruise control cable on an 01
  187. Once you go black, you never go back
  188. window/door issues
  189. if this is more DIY then move it please?
  190. What is a good (keyword) quiet after market exhaust?
  191. How to remove valve cover?
  192. fuel pump assy
  193. Question about Sandable Primer
  194. stupid diy but its free and my favorite.
  195. Re-Attaching Cruise Wiring
  196. DIY paint mirror /lip
  197. ***UPDATED***I really, REALLY need some help!!!
  198. Noob here with a new 2005 civic. What is the usaual order of mods?
  199. Changing Lights on dash for 2005 civic
  200. Adding Back up Camera
  201. DIY: My Red dash lights
  202. shaving
  203. Tech Chat and DIY's Forum Rules: Please Read Before Posting!!!
  204. painting your fog lights
  205. gauge installation
  206. Exhaust system upgrades and rear roll bar clearances
  207. leather steering wheel cover
  208. DIY: Taking Apart your M3 Mirrors
  209. I know what you re gonna say
  210. Coming Soon: DIY for painting M3 mirrors.
  211. intake exhaust general q
  212. Switching Headlight Bulbs
  213. whats the cut off
  214. installing a tach
  215. How to mount s/v-afc like this (pic)?
  216. front bumper cut outs
  217. Cleaning the Fuel Injectors
  218. anyone have an archive of greys diy pedals?
  219. Special Edition????
  220. Headlight cover swap.
  221. I'm searchin and searchin and I can't find any info on AC removal!
  222. What kind of OBDII scanner?
  223. FORUM RE-ALIGNMENT. confused? read here
  224. ex head swap..
  225. How Much do Rims affect?
  226. someone help me out
  227. Injectors causing 1-4 cylinder missfire?
  228. JDM Crank Pulley Different
  229. Main Fuse
  230. gauge question help!!
  231. Diy Adding Vinyal And Painting Trim Pieces
  232. What do headers do?
  233. m3 mirrors
  234. DIY for headliner removal with pics??? PLEASE!!!
  235. Tight clutch padel?
  236. *****I need some quick help*****
  237. Bashed up my car a bit...
  238. urgent question-03 gauge cluster
  239. DC Race Header Problem(Help Quick)
  240. Head light cover
  241. The second someone releases a D17A1 cam
  242. Is it worth putting performance in my civic?
  243. Trunk problem plz help!!
  244. oil change
  245. SAFC2 Initial Setup??? (Update: Having Problems)
  246. Where to plug in code reader?
  247. Grinding Stock Cam Shaft?
  248. Help, a dx cluster swap?
  249. HELP! HU reception sucks after keyless install
  250. Wideband????
