Once you go black, you never go back
you want to paint your rear and headlight housings black? or do you want to paint your rear and headlight bulbs black? either way after painting them you can't go back to stock without buying new or used stock replacement parts.
im sure you can use a paint thinner or something that removes paint without harming the material. but its just a lot of work. mainly the headlights... bake them in oven to get heated, paint, reseal...then its reopen/rebake, spend hours removing paint on the housing, and reseal. im not sure if the chrome housing would peel or not using paint thinner
for tails, it should be easy. its just a spray on with coatings
4 cyllinders are good but 5 is better!
yeah the chrome plating on the headlamps will rub off with paint thinner. It happened to me! Make sure this is what you want to do unless you want to cop an extra set of lamps in case you mess up.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
cmart1209
May 29, 2015 04:52 AM
Touge
May 20, 2015 10:53 PM
drhawkinz
May 16, 2015 11:39 AM
cdt12271
Apr 23, 2015 11:36 AM
