Speedo Help
Old Oct 7, 2005
WarrioR6's Avatar
WarrioR6 is an unknown quantity at this point
Speedo Help
Okay, so last night I installed some reverse indiglo gauges! I followed all of the instructions from the DIY. I grounded the black wire, and tapped the red wire into the proper wire. All of the other gauges work fine, (RPMs, Temp, and Fuel) except now my speedo doesn't work, or it just jumps to 20mph.
Can anyone tell me what I did wrong, or if there is a way that I can fix this? Thanks in advance....
Old Oct 7, 2005
streetglower's Avatar
sounds like your speedometer needle is sticking to the gauge iteself. pull the cluster back out and physically look above and see if the needle is laying or touching the gauge. Sounds like it is because if it jumps around, then that is usually the cause. Just slightly pull it away. It should fix the problem.
KikAzz
Sep 4, 2015 12:36 PM
bsmiley
31
Sep 1, 2015 06:11 PM
WD40
Aug 10, 2002 01:39 PM
crazybluehonda
Canada West
Aug 8, 2002 10:42 AM
