SAFC2 Initial Setup??? (Update: Having Problems)
Old Aug 3, 2005
R3DL1N3's Avatar
Arrow SAFC2 Initial Setup??? (Update: Having Problems)
sup. i just installed my safc2 a little while ago and i was wondering about the initial setup. for anyone that has installed this, what did you put in for sensor type, warning mode, display scale, etc? do i need to change any of these values or leave them they way they are?
Old Aug 4, 2005
Tomola's Avatar
Tomola is an unknown quantity at this point
I would help you out dude - but my cars at the workshop getting Pnp/milled. Won't get it back till later next week.
Old Aug 4, 2005
allmotor's Avatar
nor cal 7thgens
lol i just got my safc installed too by knockturnal. For the display i just made it darker at night, day, dim because i am a ricer, and for everything else besides the monitor changes, i wouldnt touch it until i got on a dyno. Me and my friend were messing with it and i think we leaned it out too much, so i would wait and just get it dyno tuned.
Old Aug 4, 2005
wheamahm0n3yat's Avatar
wheamahm0n3yat is an unknown quantity at this point
i think all honda sensor type is pressure 6 in 6 out
Old Aug 4, 2005
R3DL1N3's Avatar
on the display scale where it shows revs should i turn that up to 7k or leave it at 6k? our
Old Aug 4, 2005
ummm..... not sure what to tell you, but i think you should just get your car dyno and let the professionals set it for you
Old Aug 5, 2005
R3DL1N3's Avatar
ARRRRRRGGGGGHAAAAA!!!!!!!!!!!!
ok. so i installed my safc and ran initial setup. everything seems to be running fine except that the real time RPMs showing on the safc2 screen dont match up with the ones that are on my tach. what could be wrong? it says its idling at around 500 when it really idles around 700 or 800.
Old Aug 5, 2005
KnocturnalEM2's Avatar
I am your Mom's Hero!!
Check the car select screen...it should say 4 cyl and throttle position should be in the NE position!
Old Aug 5, 2005
R3DL1N3's Avatar
for pressure sensor should i be using 6 in 6 out or 1 in 1 out?
Old Aug 5, 2005
I set-up allmotor's with 1 in 1 out...if it is wrong I need to know also...his RPM's were a little off but imo more accurate on the SAFC!!
Old Aug 5, 2005
i called apex about what to set it at, so they told meeh all honda is pressure 6 in 6 out. and for your rpm, there is be a selection of what kind of motor you have and u should set it at 4 cylinder since thats what we have.
Old Aug 5, 2005
R3DL1N3's Avatar
ill try that and we'll see what happens. my RPMs arent just a little off, theyre way off. sometimes they can be a whole 1k off.
Old Oct 10, 2006
CivicManDan's Avatar
CivicManDan is an unknown quantity at this point
when i put my cyl at 4, my rpms show like 122. if i set the cyl to 1, i get the correct value of 722; where is my error?
Old Nov 7, 2006
dbak123's Avatar
dbak123 is an unknown quantity at this point
what motor?
Tim1959
Jun 3, 2015 08:15 PM
mrohitredd
May 30, 2015 06:51 PM
Allecr3
May 22, 2015 01:24 PM
jc33312
May 12, 2015 03:17 PM
redej2
Apr 29, 2015 01:47 PM
