- exhaust pipe hits sway bar! HELP!
- Synthetic ATF ??
- Diy grouping question
- v2 intake
- high/low beam
- Dropped a washer in my engine..
- can stock air box get hydroflooded?
- cat back flanges clearance?
- smoothing out trim pieces?
- FIPK 2 help
- PROBLEM with my car...HELP!
- 01+ Si hatch steering wheel
- check engine light?????
- maintence light.....how serious?
- aftermarket intake "INJEn"
- ECU and OBD version?
- Air Intake Owners! Ppl With Bad Gas Mileage..cel Wont Turn Off?check This!
- which chasis is the lightest? (EG, EK, ES)
- Anyone have an old fuel rail laying around? I think I am going custom!
- door switch wires
- Shaved rear "H"
- HELP! Rotor Install
- bottle heater
- TYC - Low/High beam help
- Please help!!!!!
- silencer removal methods
- question about DIY
- Adjusting TYC low beam...
- why bulb filters don't work
- help!! need a solution to an srs issue quick
- Parts list, and instructions + pics to install K-series in 2k1 coupe/sedan
- monitor in the rear view mirror?
- Help! Quick Style! Anyone With Zex Nitrous
- Note To All Regarding Gauge Calibrating!
- Holy Crap... my gauges
- Ecu
- VAFC 2 settings
- Clutch noise
- 2k1Civic Engine Rattling Noise, Please HELP!!!
- Question about throttle bodies
- cam gear belt?
- DIY for tranny removal
- Lost FM reception all of a sudden.
- About to Clean the Throttle Body..
- exhaust setup...
- Intake Manifolds??????
- VTM wire?
- installing jdm grill
- need wiring dig. for fog light switch
- removing passenger/driver side window
- Ebrake removal from a 2003
- washer nozzle question
- securing car for the holidays
- how hard do you think this install would be?
- LOssing the AC
- Need help quick!!
- Applying Body Decal, how to around door handle etc
- who said removing the dash was impossible?
- Gas door adjustment
- Headers on an LX
- DIY: Power Windows for DX/HX...now with pics!
- help on door panel removal ! plz!
- Removing Cemented on Bodykit lol...
- Article on oil -- frequent change is bad??
- Need Help Fast!!!
- How to put stock intake back on?
- throttle body question???
- uniwiper diy?
- Dracing PNP flow rate before and after?
- 04 Gauges in an 02 Civic?
- arias pistons
- DIY: Making Dash lights brighter
- bolt pattern conversion
- EP3 Rear seats in a EM2
- How do u make the clutch softer?
- Attention Everyone With BODYKITS!
- HKS Hi Power exhaust, Will it touch body kit?
- check engine light HELP
- Side moldings
- Newbie DIY for Replacing Air Filter Box...?
- gauge wireing
- JET V-FORCE not working right
- Possible mounting positions for your VAFC...Pics...
- Megan Racing Hi Flow Cat
- what bulb size are in the OEM heads
- Turn off Seatbelt Beeping
- VTEC Controller
- Powder coating Question
- Pin out for Factory Alarm Plug (Green)
- OEM Part #
- Where to mount gauges?? pls post pics
- well now im looking for an alarm
- Intake Manifold and Throttle Body removal DIY
- Thermal R&D ST system Specs.
- Our 5spds compared to the old b-series 5spds...?
- Driver's side floor is wet??
- CIVIC 96-00 AEM PULLEYS New
- Gas Milage w/ 205/50/16 Tire?!?
- Need Help From Sedan Owners...
- Those with grey's endlinks...post some pics
- Does the inside of your intake look like this?
- VAFC II problem has been solved!!!!
- Hella 90MM projectors... where to get them?
- Convert from H4 (oem) to H1 (tyc) headlights.. good results?
- Question on Gauge Pods
- Looking for DIY to hold stuff in place in trunk
- the governer
- wires connected to seat?
- apexi safc be used on a na car ?
- Help with Crimestopper CS880S Wiring
- Blue gauge needles and hyper amber interior!!
- Broken Air Filter box.
- Auto Transmission Question
- what kind of engine mods will affect (not pass) emission test?
- Need a quick answer for a quick question
- Could VTEC being disabled hurt me?
- 01 Eclipse
- vtec, what exactly happens with ours?
- vafc2
- Throttle Cable Question
- question about heat shields
- 2001 lx brake pads fit ex ?
- help hp racing 4-1 header questions?
- New interior DIY
- short ram vs cold air intake
- Power mods...good or bad for resale?
- Lower Bottom Brace DIY
- check engine light flashing when i start car
- auto shift sounds like manual sometimes
- Push button switch question
- horn
- Straight Header
- EX headers
- where to connect to o2 sensor?
- O2 Sim Question
- E-manage VTEC wiring
- Automatic Transmission
- P n P job vs. re-sleeving
- Gel coat and fiberglass
- Car Rattle?
- question on zex nitrous bottle placement
- where to install turbo goodies
- Road raged Corolla; help me out guys.
- How hard is it to install an aftermarket TACH?
- aem cai vs ebay cai
- aem pulley kit worth it ?
- DIY: weight reduction question
- Shave
- weight difference between k20 and d17?
- Will my front air bags deploy?
- steering wheel shake...
- problem w/gauge light DIY
- strange idle and cel
- removing bottom seat cover
- Exhaust bolt breaks
- left hand drive swap for and 01 civic 2 door ex
- garage opener inside the car..
- fogged
- Driving light glass paint?
- Turbo Plus Extras?
- creative sidemarker help (PICS)
- o2 sensor question
- Need speed ideas
- Need Help Check Engine Plug
- SRS light
- integra seats
- 30 thousand mile checkup
- Fuel Filter Replacement...?
- Dash Harness?
- Alternator
- All of the sudden...my CEL turns OFF!!
- Injen CAI install on auto
- Auto to Manual Conversion question
- Changing LEDs for shift indicator?
- help me get my endlink bolts off
- FiberGlass Interiors.
- Flip Flop Trunk
- Magnaflow cat-back clamp ? air leaks
- cam gear tuning
- Steering Wheel Vibrations
- Will it fit?
- first gear selection in civic auto?
- Help me spend $2000 to go faster
- o2 censor on straight pipe taking Cat. converter off
- rsx auto tranny swap???
- V 2 Lowering springs
- irritating noise?????
- Semi-DIY Water Temp Gauge (PICS)
- Lowering springs
- Need some help from alarm PRO!
- My experiences with installing the E-Manage....
- Dash Wire Harness?
- How To Improve Acceleration?
- Maintenance Tips needed
- wher is the coil on these 7th Gens?
- Hmm....I wonder....
- VAFC2/SAFC2 piggy back system?
- help painting headlights
- Invidia exhaust
- whats wrong with my b+g?
- Radiator Fan Switch
- which high flow cat ?
- d17a2 engine swap into 95 hb
- ARE these spark plugs worth it????
- weird noise?
- Lingering minor problem...(acceleration wise)
- Service Light WTF
- Interior DIYs! lights, voltmeter (Tons of Pics)
- HELP........aem cai.......... help with bypass valve
- Installed water temp gauge...
- A/C and defrost on an EP3
- remove maint required light ?
- air intake sensor ?
- LED load equalizer install?
- why is my car bad on gas?
- coupe front speakers
- Aftermarket lip fitment????
- Denso Iridium Spark Plugs...
- Taking off a few pieces for painting
- gauge cluster mileage memory
- removing shifter console?
- Suggestions on how to mold a panel?
- abs light in ex cluster?
- Does 03 center console fit 01 and 02?
- RSX rear bench latch?
- cam gear settings ?
- Who using VAFC II or AFC II in RSX Type S.
- Need some quick help with cooling system
- Signs of bad gas?
- VIS CF OEM hood
- Gauge mounted in air vent?
- HID lights
- My cf hood is changing colors?
- NOS ~ Whats Best for me??
- 2001 EM to 2004 EM front conversion
- Air Conditioning ??
- pinging - help!
- replacement bulbs and touching?
- m3 mirrors
- TYC Projectors finally got moisture in them, suggestions?
- Cam Gear Question
- DIY: Angel Eye Repair
- Replacing the fuse??
- vafc-2
- every honda part you need...MUST SEE!!
- How often to bleed clutch?
- good place to buy short ram injen intake?
- When jacking your car up...
