O2 Sim Question
Old Dec 3, 2003
pjcivic's Avatar
pjcivic is an unknown quantity at this point
O2 Sim Question
Has anyone put an HP Racing Header on there car without the O2 Sim? I recently had the HP Racing Header installed and now my car is shaking. I was wondering if it could be because I have not installed the O2 sim yet. I thought that the sim only prevented the check engine light from coming on.
Old Dec 3, 2003
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
yes it is because you have no O2 sim....you need it for HP racing downpipe,
or you can get a bung adapder and weld it on the down pipe, plug in the O2 sensor and
have someone like hondata tweak the ECu untill it gives correct readings.
Old Dec 3, 2003
pjcivic's Avatar
I used an old O2 sensor to plug the third hole. (That sounds really bad) I have the O2 sim from Wannabefast. Will that work if I get it installed?
Old Dec 4, 2003
thiscrackerntam's Avatar
thiscrackerntam will become famous soon enoughthiscrackerntam will become famous soon enough
Is it bad to leave the check engine light on if you know its from the O2 sensor? This was caused from a new high flow cat.
Old Dec 4, 2003
pjcivic's Avatar
My light didn't even come on when I put on the new high flow cat. Hey cracker, did you have the HP Header too? You having any problems?
Old Dec 4, 2003
No I have a DC header with a Megan Racing high flow cat
Old Dec 4, 2003
WannaBFast's Avatar
Prowlin' with a Purpose
did u tap into the right wires?
also, did you reset the ecu?
double check the header to make sure every thing is tightened
Old Dec 4, 2003
I took it to a muffler shop to have it installed. I watched the guy do it. He just did a simple swap of the cats, nothing surgical done to the wires or anything like that. I had reset the ecu as soon as I brought it home from the muffler shop and the light didnt come on for the first time until 2 days later. I havent reset the ecu again since this happened.
Old Dec 5, 2003
big_daddy_b_99's Avatar
big_daddy_b_99 is an unknown quantity at this point
where can i get the hp 4-1 header and high flow cat for my 02 lx auto sedan?
Old Dec 6, 2003
Having the cel come on after putting these high flow cats onto our cars doesnt negatively affect our vtec switching on and off does it?
Old Dec 8, 2003
I'm concerned with wether or not the cel light caused by our O2 sensor is affecting us in peformance in any way at all actually.
Tedverseti
Apr 23, 2020 01:45 PM
robjcivic
Mar 12, 2017 12:10 PM
JMKendrick
Sep 16, 2015 06:17 PM
Bricoleur
Sep 9, 2015 12:23 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
