abs light in ex cluster?
Old Nov 19, 2003
guamcivic2k1's Avatar
YoUnG N SuXsExFul
i just a 2001 ex cluster for my dx...i was wondering where the abs light was cuz if i put it in the light will always be on...the cluster is just a direct swap right? no need to modify?
Old Nov 19, 2003
Vinh's Avatar
yes....direct swap
just take out the bulb and you will be fine
Old Nov 19, 2003
YoUnG N SuXsExFul
which one is the abs light?
Old Nov 19, 2003
Vinh's Avatar
just eyeball....
Old Nov 19, 2003
skipbarber's Avatar
remove the clear panel and the black bezel from your cluster and you will be left with the bare gagues...lift up the top of the cluster, it just peels, and hold it up to light..you will see the ABS icon. grab a small piece of electrical tape and cover up that LED. its not a light bulb.
Old Nov 19, 2003
YoUnG N SuXsExFul
it's not a light bulb? so who's right? vinh or skip barber?
Old Nov 20, 2003
Vinh's Avatar
obviously vinh
Old Nov 20, 2003
skipbarber's Avatar
well, i know first hand because i had to do it. i have DX and i put EX cluster in my car. i tried to help, what you decide to do is completely up to you.
Old Nov 20, 2003
XxSoVeReiGNxX's Avatar
Skippo's right. I told him about the easy fix-that-abs light method. A lot of the things that light up inside the car are LEDs. I did it myself
why risk breaking your cluster trying to remove that abs light, when you can just cover that bish up? The leds aren't exposed either (not sticking out like keys on your keyboard); it's stuck deep in plastic parts of the clusters frame
Old Nov 20, 2003
YoUnG N SuXsExFul
yeah..i just took out the bulbs and put it near light..and it's not a bulb...thanks for the help guys..now i just need to open it up...it's just clips right?
Old Nov 20, 2003
YoUnG N SuXsExFul
nvm just..just took it apart right now..wonder if i should get gauges
Old Nov 20, 2003
skipbarber's Avatar
i did.
Old Nov 21, 2003
i just wanted a tachometer
Old Jan 27, 2010
sohjonn's Avatar
sohjonn is an unknown quantity at this point
Re: abs light in ex cluster?
do you need to remove the needles? thanx
Old Jan 27, 2010
TRIZ's Avatar
^ I dont believe so- I think the white plastic back removes from the black face and you have access.
Old Jan 27, 2010
skipbarber's Avatar
nice thread revival. removing needles is not necessary.
trellex
May 24, 2015 04:39 PM
jimmyfloyd
May 20, 2015 07:06 PM
Ma213802
May 18, 2015 07:01 AM
One_PeeJay
May 17, 2015 05:31 PM
bahena08
Apr 11, 2015 05:09 PM
