PDA
View Full Version : General Honda Civic Forum Archive.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 [41] 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59
  1. Neon Electrical Source
  2. fuse question
  3. This is the Part needed for installing altezza grill or RS grill
  4. AEM Tru Time Cam Gears
  5. Possible?
  6. short shifter vs. adapter
  7. resetting ECU
  8. Installed AEM SRI and check engine light.....
  9. HELP QUICK weird fuzzy stuff in engine bay
  10. 03 Center console really sucks!
  11. RSX shift knob in 2001 civ coupe..
  12. Valve Cover painting
  13. Where to buy upgraded H4 wiring harness?
  14. ECG o2 SIM at ECU CONNECTION
  15. AEM CAI FILTER QUESTION
  16. remote lock
  17. custom cat back exhaust!
  18. changing oil
  19. after market shift knob
  20. another koni question lol
  21. Inaccurate Tachometer
  22. Best oil????
  23. who did custom internals on their D17?
  24. what are these
  25. DIY M3 Mirrors???
  26. need help! need wiring diagram!
  27. cutting shocks?
  28. struts poping
  29. MoReEe TuRbO QuEsStiOnS
  30. magnet fuel saver
  31. Throttle body Spacer
  32. NEED help I/H/E 2002 DX
  33. I know we are all sick of this, with the lx to ex switch does the check engine light come on!
  34. engine internal help needed
  35. SRS light on
  36. resetting ECU ?
  37. Where's the Gas Cap DIY?
  38. Maintenance Light. Turn it Off DIY
  39. Rx-7 Motor
  40. where is the water pump?
  41. Turbo oil lines!
  42. Header
  43. Custom Exhaust Project, could use some help...
  44. What should I use to clean air filter?
  45. Quick question on lights, dont have time to search
  46. dual intake?
  47. Do these Projectors have to be resealed......
  48. MaintReq light on!
  49. auto tranny reliablilty?
  50. cleaning mositure in head lights
  51. Front indicators on when headlights are switched on
  52. High flow cat and emission test
  53. Which Valve cover?
  54. Car Won't Start
  55. Sound coming form wheels???
  56. Important question about TYC Projectors.
  57. will urethane kit fit better after painting it?
  58. Question about molding and Fiberglass vs. Urethane
  59. new transmission...
  60. Fiberglass Help/DIY/Info
  61. modifying stock tail lights
  62. Using lift with Xenon kit?
  63. O2 Sim at ECU
  64. DIY on installing Alteeza Tail Lights?
  65. injen loose cast head....
  66. Racing Seats and SRS light
  67. HP 4-1 Racing Header w/High Flow Cat Help Please. Need It in a Hurry. In the middle of the install!!
  68. WIRING DIAGRAM
  69. Put in my RSX 19mm Rear Sway today...
  70. HEADLIGHT DIFFUSER??
  71. How to Remove Console with the metal trim?
  72. Where does EX get its extra 12 HP from?
  73. 03 center console removal help! *searched...
  74. Beating a dead horse: 7440 LED's
  75. BODY KIT question!!!
  76. How to gap spark plugs?
  77. AF gauge problem...
  78. Which Intake Brand should I go with?
  79. DIY: Disable Daytime Running Lights (Canada Only )
  80. Will a D16 header fit my D17?
  81. power door locks question
  82. MISSING LINK VALVE Q
  83. Problem after hard braking.
  84. converting amber to white
  85. GROUND CONTROL,SKUNK2 OR GR MATRIX COILOVERS
  86. is the turbo performance kit all inclusive?
  87. Spare tire relocation
  88. DC to AC convertor Question....
  89. Door Handle Install?
  90. Tach Question
  91. rotor screws
  92. Jacking up car, jack stands, hi-lift, etc
  93. Quick questions about Nitrous
  94. Hyper blinker.
  95. Any ideas? PLEASE!!!
  96. ODD Swap
  97. JET ECU vs AEM Cam Gear
  98. Power door lock question...
  99. Exhaust Size If Turbo'd Up To 8psi
  100. Sedan Headlights into Coupe
  101. How Stuff Works
  102. Apexi' VAFC update
  103. Question about installing ecg o2 simulator
  104. anyone take off their fenders?
  105. Hood Trim Piece Removal Help
  106. installing neon rods
  107. CF hood pins question?
  108. Fitting new seats
  109. anyone know how to remove the rear bumper? any help would be appreciated.
  110. Someone w/ pic of APEX'i V-AFC installed (NOT S-AFC)
  111. Making a custom intake mainfold...questions
  112. K series motor #s?
  113. Speedo, and Tach Calibration?
  114. is ur car as low as mine
  115. tranny swap
  116. Speed Calibration
  117. DelSol seats in a 7th gen Coupe
  118. more turbo Q's and weight reduction?
  119. H&R Sport in sedan - Why not?
  120. HID Conversion in an '03
  121. question about **FOCUS** door panels
  122. exhaust help
  123. So what is the correct bulb size for reverse?
  124. will this exhaust fit 02 civic??
  125. 2003 guage cluster in a 2001+2002...nice!
  126. help with door actuators
  127. Custom interior ?'s
  128. Final Turbo Parts List
  129. muffler silencers
  130. what is best glue/cement to use to bond skirts to paint(w/o stripping paint)
  131. will coupe lights fit sedan
  132. swaybar attachment measurements?
  133. Crankcase breather & AEM CAI
  134. Dead DIY link
  135. Need Help!!! Problem with my face gauges
  136. What K&N replacment filter for AEM CAI?
  137. Oil pressure gauge install...
  138. d16 question
  139. Xenon kit installation?
  140. question about our heads
  141. fram oil filter
  142. i need help on a blow off valve.
  143. Help with Intake
  144. Code # P1456.......
  145. relay question
  146. Rear Camber Kit/Toe/alignment angle Questions; *not n00b*
  147. full length header
  148. can i run a 5psi turbo with no fuel mods ?
  149. Removed stock intake resonator
  150. PAINT FOR HEADERS
  151. Help installing air horns...
  152. To: Black99CivicEx regarding fuel reg
  153. Question on ignition
  154. Engine Check Light, PLEASE HELP....
  155. Seat Help
  156. put back in place, TPS HELP!!!!
  157. Lamborghini doors 6/7 gen
  158. Need some help???
  159. Convert Stick to Auto
  160. convert an auto to stick
  161. WIPER ARMS...
  162. relocating a/c controls
  163. grills!
  164. DIY: Blacked out headlights
  165. Wiring power windows into dx???
  166. No cat?
  167. how to get rid of shut off
  168. Where is the PCM?
  169. quick question, car feels like it lags
  170. Nitrous Systems
  171. lx ex Intake manifold
  172. Radio code help
  173. Is there any difference?
  174. vinyl seats
  175. Need Input on Exhaust
  176. Injen SRI installation - Tools required?
  177. Guage Cluster/Mileage Differences
  178. in car pc monitor??? electrical engineers welcome ;)
  179. My temperature needle is at H
  180. diy/installing underbody neon?
  181. Adding AUX input to HU.
  182. throttle position sensor...
  183. Apexi AFC controller not work on 2001 ex civ?
  184. where to put Racing Harness?
  185. help: HP RACING HEADER
  186. Floor Brace...help
  187. how to measure for trunk gas struts?
  188. quick question...help
  189. PIAA 1700x replacement bulb help!!!
  190. Reverse Indiglo Problem
  191. <<Anyone that knows engine numbers HELP!>>
  192. anybody kno about DIS ignitions?
  193. complete interior panel removal guide
  194. 2001 civic ecu??
  195. Popping from suspension?
  196. I thought it was easy?
  197. Additional Injectors for Turbo (RiceBurnerEX??)
  198. Silly Question wanting a serious answer
  199. my car dont drive
  200. Turbo Wishlist
  201. Location of Fuel Pressure Regulator?
  202. what's the diameter of stock piping?
  203. H22 engine??
  204. For all yah monkeys who think that Japan runs on 100 octane gas and such . . .
  205. Reverse Indiglo Problem...
  206. Re-Progamming Immobilizer / Keys ?
  207. How do i swap auto for manual tranny??
  208. pulleys
  209. Trim around window switches?
  210. how to install altezza grill
  211. DIY: CapYoda's PreciseShift Shifter Progress Kit
  212. just need to know
  213. how much for a manual swap?
  214. help---reverse indiglo gauges
  215. Side Marker light installation?
  216. hood struts
  217. ground wire install help?
  218. AEM INTAKE HELP!!!
  219. idn't come wshort ram install
  220. PEOPLE WITH BODY KITS
  221. Transmission
  222. Crank Pully?
  223. about the HP header and Race cat w/downpipe
  224. Adjusting headlight aim after clearing
  225. Maintenance Light
  226. amp mounting on rear seatbacks?
  227. Painting the kit...
  228. installing door panel lights- electrical help plz
  229. Jdm H22a or JDMB18c Gsr for civic hb??
  230. DIY: Throttle Plate Edging / Throttle Plate Screw Countersinking
  231. Gauge Lights blew? After Installing Bezel
  232. 5 Speed PC - In-Vehicle PC Forum!
  233. DIY : Installing the ZETA Wide Arm Rest
  234. Unorthdox racing Pullies and light weight flywheel
  235. Springs creak in cold weather???????
  236. 450cc DSM injectors? Good deal?
  237. venom nos fit for our car?
  238. DIY computer in the car?!!?!?
  239. Alternator?
  240. Any way to recalibrate Gauges?
  241. Throttle Body
  242. Stock Airbox.....
  243. Anyone taken apart TYC projectors?
  244. Nitrous in an automatic?
  245. Backseat Removal...Please Help
  246. srs warning labels
  247. Clutch Pedal Question
  248. Need Help DIY Headlights
  249. trunk mounted tool kit
  250. Dry nitrous system?
