changing oil
Old Feb 4, 2003
angelswin's Avatar
angelswin is on a distinguished road
changing oil
This has probably been touched on before but does anyone like me change their own oil and find it is very hard to do on a 2002 lx.The filter is hidden behind the engine and tucked in so it is very hard to reach.I would like some ideas on how to change it without using ramps or jack stands.There is no room to squeeze under given the height of our cars.Is it possible to do without ramps or jackstands?Last time I had to remove the drivers side tire just to get an arm in there.I would like to here everybodies ideas on how they change their oil.
Old Feb 5, 2003
SOHC's Avatar
I spent 1425 points to do this.
SOHC is an unknown quantity at this point
[IMG]i/expressions/face-icon-small-confused.gif[/IMG] i dont know any shortcuts... i always use my ramps tho. u can use a latex glove to take the filter off by hand- its way to hard to try to fit any tools in there. they also sell a small little rubber cub that u can use to grab the tiny filter. Fram makes this little do-hicky that u attach to the oil pan drain- its like a quick change deal. all u do is attach the 6" hose it comes with to the special plug it comes with, the hose has a pin in the attachment that opens the valve in the plug to release the oil without using any tools. This can save u from getting hot oil all over your hands too
Old Feb 5, 2003
Collective's Avatar
Collective is an unknown quantity at this point
Quote
[hr]"I would like to here everybodies ideas on how they change their oil."[hr]
Ramps w/cheater boards.... and you know to do the rest. I can't believe you were able to change it yourself without ramps... or stands ! My hats off to you, but as SOHC said... there are no short cuts.
Old Feb 5, 2003
ZSKCivic01's Avatar
Extreme Member
ZSKCivic01 is an unknown quantity at this point
just out of curiousity, is the filter in the same place that an ex would have it?
Old Feb 5, 2003
solar's Avatar
solar is an unknown quantity at this point
I have a EX and the filter is easy to reach from under the car, I bought a $3 oil filter cap wrench from Discount Auto Parts, its the type that connects to your 3/8 rachet. It works wonderfully, I buy my oil filters from Handa Assories.com and just took one to the parts store and found a oil filter cap wrench take fit perfectly. Its just like the one Handa sells but about $15 cheaper.
RIPSAW
Nov 6, 2015 04:36 AM
MegaBassX
Jun 11, 2015 08:52 AM
BootyDo
May 7, 2015 04:46 PM
silverdevil
20
Jun 2, 2007 04:42 PM
Grey
16
Jan 27, 2002 11:34 PM
