Question about installing ecg o2 simulator
Old Jan 28, 2003
asdfasdf's Avatar
asdfasdf is an unknown quantity at this point
I went to an import shop to have my o2 simulator put in and the directions were wrong. They weren't able to put it in. I need your guys help to install the o2 simulator. the wire pattern on the directions are different then the ecu computer. Thanks
Old Jan 29, 2003
cwick187's Avatar
cwick187 is an unknown quantity at this point
o2 sim
Old Jan 29, 2003
zetaR's Avatar
zetaR is an unknown quantity at this point
Quote
[hr]Originally posted by: cwick187
o2 sim[hr]
Yeah, that thread will tell which wires to hook up where. Those are the same ones I used, and it works great.
Old Jan 29, 2003
IDQcivic's Avatar
IDQcivic should not be trusted
Yup I wrote it so it better work... the instructions that came with it are for previous gen cars, but its still pretty easy to figure out anyways... but yeah read that thread and follow what I wrote.
Later
Old Jan 29, 2003
triryche's Avatar
triryche is an unknown quantity at this point
Quote
[hr]Originally posted by: IDQcivic
Later[hr]
Hi IDQcivic!
The DIY that you posted is a short DIY. Could you post a detailed instructions w/pics or diagram?
I need to assure on this installation. Thanks
Old Jan 29, 2003
IDQcivic's Avatar
that DIY is about as straight forward as it gets... I told you where all the wires were and even colors, if you can't figure it out maybe you should let a professional do it!
Old Jan 30, 2003
triryche's Avatar
Only one question? I have the sim2 w/ me right now in my hand. The ECG have 5 wires, ok.
1) Black
2) red [IMG]i/expressions/face-icon-small-mad.gif[/IMG]
3) blue/white
4) green/white
5) white
You post:
ts just a 5 wire hook up
[IMG]i/expressions/face-icon-small-mad.gif[/IMG] red postive on battery
black negative on battery
RPM wire - [IMG]i/expressions/face-icon-small-nono.gif[/IMG]blue wire to left of battery under black boot
TPS wire - [IMG]i/expressions/demon.gif[/IMG] red/black wire in middle wire in group of 3 wires by throttle body
o2 sim wire - cut black wire off 2nd o2 sensor, tape end going to sensor, run the simulator back to the harness that plugs in the car. leave other 3 wires alone and wrap the sensor in foil. tie under car somewhere
the red and the black its ok. blue wire (RPM) goes to? Tps wire in throttle body, where's ? The O2 Sensor have only one cable and I need to cut off? In PR have no technicians that solve them.
Old Jan 30, 2003
IDQcivic's Avatar
You may have a different o2 sim... anyways, the one I have was from diablo auto sports, now I dont have the instructions with me. The instructions tell your the colors of the wire ON THE SIM ITSELF, now example if I say RPM wire, that is the RPM wire on the sim... now run that wire to the BLUE wire to the left of the battery, then look at the instructions and find the color of the TPS wire, now run that to the RED & BLACK wire buy the throttle body, just splice it in, don't cut it. Now look at the instructions for the color of the the O2 wire on the sim, now run that to the black wire of the 2nd o2 sensor going back to the harness under the car. you have to cut that wire, tape off the wire going to the sensor, and leave the sensor under the car and tie it down good with some zip ties, I wrapped mine in foil to protect it from the elements...
Many other people have followed by DIY and had no problems at all....
Good luck man and I hope you can figure it out!
Old Jan 30, 2003
triryche's Avatar
Thats the same that I have Red Box w/ 5 mires. red,black blu, green and white
Old Jan 30, 2003
IDQcivic's Avatar
well read the instructions, figure out which color wire is which, and then you should be all set!
Old Jan 30, 2003
spike's Avatar
spike is an unknown quantity at this point
I got my O2 Sim from diablo auto sports the other day. Today my friend and I tried to hook it up at the ecu. The directions listed the 01+ Civic, and gave the wiring diagram. We found the wires in the exact same spots as the directions said, and they were the same color. Once we got it hooked up though, my car wouldn't start. It sounded like the battery was dead. Then we disconnected it and my car ran fine. Do you think that we still have the wrong wires or maybe a loose connection? I'm going to the local audio store tomorrow to borrow their multimeter. Maybe that will help. Until then any guidance or help would be greatly appreciated.
PS- Did everyone else just have all these extra wires running through their engine bays?
Old Jan 31, 2003
triryche's Avatar
Quote
Good luck man and I hope you can figure it out![hr]
When you say "leave the sensor under the car " you try to say when I cut the black cable and tape off the wire going to sensor, then put paper(role) aluminium around o2 sensor and wires and remains connected to the test pipe?
If this is quite the instructions its perfect. Thank you thousand times for this DIY. They are clear and concise.
Old Jan 31, 2003
IDQcivic's Avatar
my test pipe only had one 02 bung below the header that I connected the first 02 sensor to, the 2nd o2 sensor is where it was connected to the cat, but now since you don't have a cat there shouldnt be a bung for the 2nd 02 sensor, so I just ued some zipties and tied it under the car, sounds like you figured it out, as I have offered as much help as I can without actually being there and doing it for you, hehe....
Later
Old Jan 31, 2003
triryche's Avatar
my test pipe has a hole to conect the 2nd o2 sensor. I have to connect it to the test pipe or disconnect it and tied somewhere of the car?
p.d
sorry for my ignorance? I don't understand English well. I Speak Spanish only.
Old Jan 31, 2003
IDQcivic's Avatar
well if it has a hole for the 2nd o2 sensor then why did you even need the simulator? The only reason I had to buy the simulator was because mine had only 1 hole. What you can do is forget about wrapping it in foil and put the sensor in the hole so it is plugged, then cut the black wire and follow what you were gunna do before....
Old Feb 2, 2003
cvc2k2's Avatar
cvc2k2 is an unknown quantity at this point
so there isnt any success just hooking it up to the ECU?
jttegx
Nov 9, 2004 04:09 PM
Snakes
Feb 22, 2003 07:43 AM
asdfasdf
Feb 7, 2003 12:16 AM
PhilyStyle
Oct 21, 2002 12:31 AM
