Jdm H22a or JDMB18c Gsr for civic hb??
i just bought a used civc hb without engine in there, the guy sold it to me for 4 hundred dollar!!! cash!!!
now i want to start my project...and start doing some research..just wondering which one better?? h22 or b18?? guys please give me some opinion..and i dont like someone talk shxt about my english...i just want u guys give me some opinion...peace~~
Personally, I prefer the B's. But the difference is more or less nominal. However, I know you gotta start slicing the bay with the H22. I dunno if it's the same with the B18, but I don't think so. I'm not an engine expert, so you might want to just ignore me.
I wish I was asian
i'd do a B20c swap instead... all the glory of the b-series vtec, with the potential of more displacement than the GSR
BTW: b series parts will probably be cheaper than the h series parts.....i think...
info on B20 swap
B18c swap info
generally will be a good reference for you.
info on B20 swap
B18c swap info
I wish I was asian
Quote
[hr]Originally posted by: phlipsidez
I'd go with the prelude's H22. just to be different from all the B swappers.[hr]
me..none so far
JDM B18C would be the B18C with 210hp with 138 lb-ft of torque, Diplacement: 1797cc, redline 8900, JDM H22A would have 220hp i think not to sure about the all specs though. I would say JDM B18C.
i have two friends that have done this swap, the guy that did this into his hb had to cut away some parts of his frame to keep ac and powersteering. But man that thing hauls AZZZ in a hb. My friend that owns a shop acutally did it to a civic cpe, his prelude motor is stroked to a 3.0l hes got it in his race car but the motor is still being worked on right now. I say go with the h22, no one can tell its a prelude motor unless they look at the engine code. Other than that just tell everyone its an si motor.
First of all... what year is it? I'll assume it's a 5th or 6th gen. I would say B because there's tons of parts. You could also look at a B18B and boost the hell out of it. The Non-VTEC engine is better for turbocharging. But it depends which way you want to go.
From: San Diego, California, USA, Northern Hemisphere, Earth, Sol System, Spiral arm of the Milkey Way
H22 is too big for a daily driver.
and to answer your question: Neither.
http://www.importbuilders.com/block.html
http://www.importbuilders.com/cratedmotors.html
Example:
Description: "I want the best." This is Import Builders favorite block. It revs higher and has slower piston speed, slightly than its B18A/B cousin. This block features the following details:
Iron Sleeves for total strength and durability
IB Spec Wiseco Pistons, JE pistons, or Arias Pistons. You choose!
Eagle Rods or Probe Rods
Bore, Hone, Hot tank, Deck (if nec)
Balanced Crank
Polished Crank
All new Bearings & Thrusts
All new seals, and Oil pan Gasket
New VTEC oil pump
New VTEC water pump
LS/VTEC Oil line Kit with all fittings
Compressions come in 9:1, 9.4:1, 10.5:1, 11.8:1, 12:1, 12.5:1. 12.8:1, 13:1
Price: $3950 Shipped. Want to rev it to 9600 RPM all motor? Pick this one.
Example:
Balanced Crank
Polished Crank
New VTEC oil pump
New VTEC water pump
well that depends on how much aftermarket modification you intend on doing?.... H22a's have oil burning and are historically not as reliable of bullet proof as the B series engines...it's also a fair chunk heavier and will cause your car to be too front heavy..(great fro dragging.. kind of negtive for handling)..
If you plan on adding a turbo.. definately a B18B 1.8 non vtec..it's the most bulletproof honda engine on the market. and vtec is of no advantage when you have boost and all that torque low down anyhow...
If you wanna be one of the few....get a B20z and B16 heads and a GSR computer but don't think of boosting it or running nitrous because the B20 blocks can't handle F/I all too well...
in a hatch, you will have to chuck the AC and power steering. ie no good for a daily driver, less your super harcore... which i dont believe to be the case here. dont get me wrong, my friend has a 92 Si hatch with an all motor H22A that pulls high 12s, but against, its not his only car. He has a turbo GSR for that.
Quote
[hr]Originally posted by: XxJDMCivicxX
JDM B18C would be the B18C with 210hp with 138 lb-ft of torque, Diplacement: 1797cc, redline 8900, JDM H22A would have 220hp i think not to sure about the all specs though. I would say JDM B18C.[hr]
Quote
[hr]Originally posted by: HondaGuru
in case i was too subtle in my previous approach... GETTING A JDM ENGINE IS A WASTE OF MONEY.
that is all.[hr]
that is all.[hr]
N/A.. B20 Frankenstein..
Turbo B18b [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Quote
[hr]Originally posted by: mohawkboom
Bigtime.. most yes MOST JDM engines are high mileage beaten to hell engines..often with mish mash parts and part number sequences that don't match.. for the price you can take a USDM engine *** a few bolt-ons and have more power for less money.
Turbo B18b [IMG]i/expressions/face-icon-small-smile.gif[/IMG][hr]
Quote
that is all.[hr]
that is all.[hr]
Balanced Crank
Polished Crank
New VTEC oil pump
New VTEC water pump
Price: $3650 Shipped.
Description: "I have a LS/VTEC." A saying that is now associated with "my car is fast." Hopefully, because of Import Builders. This block features the following details:
Balanced Crank
Polished Crank
New VTEC oil pump
New VTEC water pump
Price: $2500 Shipped.
Description: Annihilator Block Packages are out! These are what we believe to be the most reliable, strongest blocks in the industry. These blocks are built to take punishment. The blocks include these features in addition to all the normal block features..
Race Coated IB Spec pistons. Not just a top ceramic coating...no way! This is the REAL DEAL. Just like TOP FUEL does to their pistons, from the same people! This block can take the heat folks. Let there be no doubt.
Eagle Rods or Probe Rods with upgraded ARP bolts
A new sleeving process featuring a closed deck that is vented. This is the ultimate in block strength. Go ahead! Turn up the BOOST!
Price: ADD $850 to the price of any block package that is already sleeved. This is noted by this sign: (**) ADD $1780 to any block that is not already sleeved. There is no ** next to these blocks...
first member with a d16 swap
first off if u are gonna do a b motor you go with a b20 bottom end with a type r head. thats the best combo.
and if you go with a h22 you should find a h23 bottom end with a h22 head. if you use the h motor you will have to carry lead bags in your back hatch to keep the back end down with turning. and it will run mid to low 13's stock! u could go with the b motor and run a lot of boost thro it i have seen them running mid 11's.
Lead bags?!
Shut the hell up. I trust anything you say about as far as you’d get with a seized piston.
Why dont you go ahead and reccomend a 24K gold plated valve cover while you are at it? Talk about a waste of money.
Quote
Lead bags?!
Why dont you go ahead and reccomend a 24K gold plated valve cover while you are at it? Talk about a waste of money.[hr]
Lead bags?!
i gaurentee you that the h22 motor is to heavy for that car and it will cause the back end to kick out when u turn. thats why u put the lead bags over each tire in the back. my friend has the swap done to his hb
If that’s the case (and in case you aren’t lying like you do with everything else) then kick him in the nuts for being a moron. Either for thinking he needs lead bags or for screwing up the car so much during the swap that he actually DOES need them.
Please die slowly
Please die slowly
Quote
LOL, instead of a 24k just get a chromed out one save urself some money [IMG]i/expressions/laugh2.gif[/IMG][hr]
Quote
Lead bags?!
Lead bags?!
Quote
the usdm B18C1 is more than enough for me however it woulda been better with a C5
dont bother with the H22 unless you know what your doing (which you obviously dont if your asking this question) unless you want your car to have major suspension problems
Quote
[hr]Originally posted by: NeoMagus
dont bother with the H22 unless you know what your doing (which you obviously dont if your asking this question) unless you want your car to have major suspension problems[hr]
