Unorthdox racing Pullies and light weight flywheel
Old Jan 14, 2003
MZ's Avatar
MZ
MZ is an unknown quantity at this point
I am looking to purchase the complete pulley set and the lightweight flywheel here soon. I was told by a friend that the resulting loss in wieght of those misc items would negatively effect my car. The pullies, crank, and flywheel lightened would cause to much of a loss of inertia or something to that effect I am not sure. I was curious because i do not want to put out $650 for these items and have one of them be wasted. I also have my head i bought in the shop getting a P&P, Valve Job, the Manifold P&P to match, and throttle body bored gonna cost me round $450-$500 with the hook up round here. Will these previously mentioned items with all this effect my car negatively??? I appreciate any help yall can give.
Old Jan 14, 2003
mikalem's Avatar
mikalem is on a distinguished road
It shouldn't at all! The lightened pulleys will make it easier for your engine to move your accessories, and the lightened flywheel helps because there's less weight for the engine to spin. Your friend is on crack.
Old Jan 14, 2003
triryche's Avatar
triryche is an unknown quantity at this point
Finally, this crankpulley is good for our engines? Where do I buy that?
Old Jan 14, 2003
Intruder's Avatar
Intruder is an unknown quantity at this point
the only negative effect is from the flywheel, which you will notice when you have to launch at a higher rpm and lose some torque on take-off... well worth that side effect though
Old Jan 14, 2003
ASWZero's Avatar
ASWZero is an unknown quantity at this point
While you are at it, you might as well get a street or racing clutch. That is my next set of upgrades, flywheel, clutch, pulleys, and cam gear. Get it all installed at once. Its alot cheaper(saves about 2 -3 hours of work).
Old Jan 14, 2003
blazed870's Avatar
blazed870 is on a distinguished road
Would the lightweight pulleys and flywheel help my car that much if I wasn't getting the other stuff done to my car? Which are better, the AEM or the Unorthodox? Are they hard to replace yourself or should it be done by a shop?
Old Jan 14, 2003
mykungfuisthebest's Avatar
mykungfuisthebest is an unknown quantity at this point
on realy high HP high rpm engines the lightened flywheel might cause rpm drops between gears but other than that im shure its all benefit
Old Jan 14, 2003
RedDragon333's Avatar
Quote
[hr]Originally posted by: blazed870
Would the lightweight pulleys and flywheel help my car that much if I wasn't getting the other stuff done to my car? Which are better, the AEM or the Unorthodox? Are they hard to replace yourself or should it be done by a shop?[hr]
i would go with UR they ive you the crank pully and AEM doesnt.
Old Jan 14, 2003
2001civ's Avatar
2001civ is an unknown quantity at this point
AEM has good intakes and fuelrails. Thats it!! anything else buy from a different company. With the pullies get unorthodox. groupbuycenter.com is the cheapest I found and where I got mine. $282 shipped. Install is easy IMO. I had to take out the p/s and alternator to take off the old pullies, thats not really a problem just be carefull when you unhook the p/s cuz the fluid will drain, that or just buy some extra fluid. Hardest part was taking the crank pulley off. That mother F***er wouldn't come off. Had to jam a screw driver in the flywheel to keep it from turning, but do that at your owe risk. All in all I wouldn't say it's that bad of an install more time consuming then anything.
Old Jan 14, 2003
blazed870's Avatar
Thanks for the help. Do you think changing the pullies and flywheel are worth it? Would I have to change my belts? Also I found this pulley in an old groupbuy thread made by RVMracing.com and I was wondering if anyone had tried it.
Old Jan 14, 2003
Quote
Thanks for the help. Do you think changing the pullies and flywheel are worth it? Would I have to change my belts? Also I found this pulley in an old groupbuy thread made by RVMracing.com and I was wondering if anyone had tried it.[hr]
the pullies i say go for it IMO i wouldnt do the flywheel. TOo many cons and not enough pros to even the amoount of money youll spend getting it done
Old Jan 14, 2003
PlatCruiser's Avatar
PlatCruiser is an unknown quantity at this point
pullies are definatly worth it
my brother started out (beginner at the time_ at 17.3 in his LX 4 mods later he is down to 15.6
mods are AEM CAI
TCS long tube header no cat
UR pullies
2.25 exhuast.
Old Jan 14, 2003
blazed870's Avatar
What are some cons to getting the flywheel replaced? Do you have to take it to a shop or can you do it yourself.[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Jan 14, 2003
CivicRicer02's Avatar
CivicRicer02 is an unknown quantity at this point
wow thats crazy
Old Jan 14, 2003
mrdan4548's Avatar
mrdan4548 is an unknown quantity at this point
hey buy the unorthodox ultra ss kit from me, i got it for 260$ shipped. its brand new in the box, tell me if anyone wants it. p/s alt and crank pullies!
Old Jan 14, 2003
Diemos's Avatar
Diemos is an unknown quantity at this point
Quote
What are some cons to getting the flywheel replaced? Do you have to take it to a shop or can you do it yourself.[IMG]i/expressions/face-icon-small-confused.gif[/IMG][hr]
What does it even do to get it lightened, I dont even know the benefits!
Old Jan 14, 2003
Quote
[hr]Originally posted by: Diemos
Quote
What does it even do to get it lightened, I dont even know the benefits![hr]
lighter the flywheel less Hp to turn it and better throttle response. Less low end torque and revs faster. One con is you have to rev higher for a launch and even for a start from a stop posisition. Do a search and youll find very helpful information
Old Jan 14, 2003
MZ's Avatar
MZ
Hey MR I am interested in it email me at mikezulu18@***.net we can talk
Old Jan 15, 2003
blazed870's Avatar
where did you get the the unorthodox ss kit and how much are you willing to sell it for MRDAN4548?
Old Jan 15, 2003
CivicRacer5's Avatar
CivicRacer5 is an unknown quantity at this point
Isnt it bad to change the crank pully?
Old Jan 15, 2003
I pretty sure if the motor is internaly balance you should be good to go....
if I'm wrong please correct thanks.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
Vaguexo
Jun 13, 2015 04:11 AM
Supramk3
Jun 11, 2015 11:13 AM
doncarbone
Jun 8, 2015 03:37 PM
oneheadlight
Apr 29, 2015 11:30 PM
