PDA
View Full Version : General Honda Civic Forum Archive.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 [31] 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59
  1. help on removing pocket under stock headunit
  2. DIY: Red Gauge Needles (PICS!)
  3. Stripped Header Bolt
  4. cant get to bulb on projectors
  5. Aftermarket Security Antenna
  6. Noisy Belt
  7. Change in Clutch feather after street racing
  8. Civic Upgrades?? What comes first??
  9. Broken temp gauge!
  10. Anybody have Civic Si seats in their 7th gen?
  11. So Cal Performance Garage
  12. getting rust stains off of plastic bumper?
  13. !!!!header question!!!!
  14. Painting valve cover/fuse box cover
  15. adhesive to use for emblems?
  16. weird grinding noise when shifting
  17. performance chip?
  18. painting body kit?
  19. How to reset the ABS light
  20. 4DR owners! HELP@!!!
  21. ECG O2 Sim Diagram
  22. 03 Rear Upper Strut bar?
  23. Removing interior
  24. my intake knocks on my strut bar
  25. change spark plugs? Pic
  26. Revo Ss
  27. Universal seat brackets and sliders (for those with aftermarket seats)
  28. Factory Stereo Code
  29. Trouble installing headlight for projector
  30. Fenders Same On 01 & 02?
  31. How do I install Grill?
  32. sunroof concerns
  33. Wow! Awesome info on 7th gen...
  34. ground points rusting up
  35. Header Gascket...
  36. Seat swapping/adjusting
  37. does any1 knows how to do hyper blinks in DIY?
  38. 7G CAI for 5spd Cpe fit a 7G Auto Sedan?
  39. alternating lights?
  40. Interior what to do.
  41. how to install lip kit????
  42. How do you remove....
  43. how to install ebay intake?
  44. Aero kit + Tanabe RSpec
  45. crush washer size?
  46. has anyone done a DIY for .....
  47. my battery shorted
  48. lowering the 2001 civic
  49. Ne'one here with Honda Club of the PI
  50. Front wheel alignment SPC camber bolt
  51. rvm crank pulley & aem pulley
  52. o2 simulator HELP
  53. 2000 Civic DX Hatchback - alarm install
  54. Check Engine Light
  55. Headers help
  56. I need info on painting my body kit...
  57. Angel Eye FINAL PICS (DIY soon)
  58. interior vinyl seating
  59. Strut bar and AEM?
  60. Removing trunk lid
  61. Rsx type R engine Swap Air/fuel ratio sensor wiring.
  62. typeS ecu in 01 civic
  63. how bad is this? intake question
  64. xenon and goldlines..
  65. Neuspeed Race...Does it matter
  66. Tyc + Hid
  67. Ceramic headers Vs Stainless
  68. em2 tranny
  69. Hooking up PS2 to LCD
  70. Angel Eye Projector parking light prob..
  71. Help with Decision with exhaust.
  72. My 2001 civic EX sedan
  73. doing 2003 Cluster swap to 2001 Car help: pin out needed
  74. Slow Acceleration..
  75. RS Version Projector Headlights
  76. help!high beam not working
  77. Whitest parking and turn signal lights
  78. Installing a REVO . .question?
  79. Civic 2003 EX
  80. adjusting headlamps
  81. sidemarker DIY (UPDATE!)
  82. sidemarker help (wiring)
  83. o2 sensor replacement.
  84. Should I be cautious of grounding kit?
  85. Anything other than hood pins?
  86. Trunk Light?
  87. Overhauling Tranny...
  88. Will cluster from auto tran fit manual tran car?
  89. Wheel Bearings?
  90. 2004 rear bumper on a 2002 civic???
  91. what's this? B-Series?
  92. Step 7 on Removing Rear Deck help ASAP
  93. seamless speaker box diy
  94. door handles?
  95. rsx fuel pump in a 7th gen?
  96. Need Help Fast!!!!
  97. Help from anyone with Helms manual
  98. k20a4 info needed
  99. New air filter shows big improvements
  100. changing rear brake shoes
  101. Is it a resistor problem
  102. mandrel vs crush bending?
  103. gas question...
  104. Need help working on halo projectors
  105. Intake Sounds and AEM V2 ?
  106. Throttle Cable Help
  107. painted pinstripe?
  108. WTF is this Damn sound!
  109. Aem Short Ram Intake Install
  110. AEM Pulley install
  111. Oil filter issue
  112. Fuel System
  113. IN TANK or IN LINE FUEL PUMP for RETURN Conversion
  114. Help with K&N FIPK II installation
  115. Car won't start
  116. Painted chrome?
  117. rear emblem removal and replacement .. easy?
  118. door panel DIY (new pics)
  119. Is your oil doing its job?
  120. immobilizer bypas module???
  121. Progress rear sway + Grey's endlinks problems
  122. Endyn Port and Polish info - PLUS camshaft question / info!
  123. autometer gauges..
  124. Poor gas milage new 2003 civic
  125. Help w\ Hondawerx UKDM Folding Mirrors
  126. Key lock pushed in?WTF
  127. D16 intake manifold bolt up to a D17?
  128. what would i need to do to push more POWER outta my D17a2
  129. D17A Bore over
  130. Installing Tsunami Front Bumper
  131. EG Hatch Question..
  132. a question about the Apex VAFC2 question (100 point thing)
  133. Broken speedometer
  134. who has a crank pulley ?
  135. Sideskirt Tab
  136. neuspeed strut bar for manuals
  137. How can something decrease torque but increase hp?
  138. which iridium spark plugs ?
  139. Ex header on Lx fit?
  140. Removing center console "?"
  141. Car Service...
  142. Intakes and hydrolocking
  143. arguement against tinted windows
  144. a/f gauge how often is it suppose to....
  145. What are these red wires?
  146. Halo connection? Yes I searched
  147. racing harness in a sedan?
  148. engine swap
  149. painting emblems
  150. What is REAL carbon fiber?
  151. Weird annoying squeaking from tail light...
  152. What does a vaccuum gauge do?
  153. Plug in my engine compartment? whats it for
  154. strange plug on my dx in the engine compartment
  155. Autometer Tach hook-up question!
  156. Antenna
  157. Intake came apart
  158. JDM b18c in 99 EX?
  159. oem fog light switch
  160. Heat Shield Removal???
  161. Inyectors
  162. clutch/trans problem? maybe not
  163. hp 4-1 header for sale
  164. Intake and header dynamics
  165. Black Headlights problem
  166. Weight Loss?
  167. what cars are slower then our civic
  168. speedo help
  169. I need help with SRS light DIY
  170. autometer a/f gauge ?
  171. OEM air filter box part #?
  172. Blue light bulbs...
  173. How to remove sedan rear bumper?
  174. which hose is this?
  175. ok how much crap am i gonna get?
  176. a/c compressor ???
  177. Update On The Apex-i Vafc 2
  178. What parts do you take off/leave in the winter?
  179. engine diagram needed
  180. Alchohol injection?
  181. Kamikaze install problems
  182. Reupholstering seats?
  183. Naxos Xenon Blue
  184. 2003 headunit
  185. anyone want to help on a diy project with rear seat?
  186. ebay scam +20 hp
  187. Need a DIY:gauge cluster removal
  188. Z1 module
  189. Question on valve cover painting
  190. odometer!
  191. hid headlights
  192. Driver Window
  193. For those of you who have Plasma Coils - I need some info from the coil itself...
  194. V-AFC II settings
  195. Exhaust diameter vs Volume
  196. Installing tenzo seats
  197. DC Sports 4-1 1 piece stainless header... and gasket...?
  198. gsr motor
  199. installing RSX rear sway bar question
  200. 6000 Miles on Synthetic
  201. milage
  202. Aem Pulleys
  203. Mounting an XBOX in the trunk.
  204. DIY: Power Steering fluid change
  205. cutting perfect circles for sub box
  206. DIY flaming exhaust?
  207. Auto Down Passenger Window (Coupe)???
  208. Touch Window Switch
  209. Oil presure gauge sending unit.
  210. Stock exhaust question
  211. question about interior lighting...
  212. would revo short shifter solve popping out of 2nd gear?
  213. warming up engine!
  214. Headers
  215. High compression
  216. HID + Projectors = POSSIBLE?!?
  217. clutch problem
  218. Need a good parts supplier tell me yours
  219. Fixed the play in my revo SS
  220. auto to manual look conviersion
  221. Just installed vtec indicator led...
  222. engine surging
  223. Mileage and Wheel Size?
  224. Does The vtec controller actully work?
  225. Help!!!!!
  226. AEM Cold Air Intake question
  227. cam shaft ?
  228. intake manifold vs stock port and polish
  229. DH-Racing crank pulley question?
  230. Does modifying the engine affect the longevity of the car?
  231. IAT sensor question
  232. laptop into the ecu?
  233. Streetglow DIY (UPDATED PICS)
  234. Question about tightening suspension around turns
  235. Painting Altezza's
  236. DIY: Return Style Fuel System Conversion
  237. Glasspack as a resonator?
  238. fuel pressure regulator vacuum line ?
  239. 7thGEN civic conversions!
  240. Reset ecu = bad gas mileage
  241. HALO ALTEZZA's
  242. Blown bulbs *weird*
  243. techy question
  244. Cluster Upgrade
  245. plasma booster for 7thgen ?
  246. weight reduction ?
  247. Replacing Axle
  248. weird noise when driving
  249. aem pulleys HELP!!!!!
  250. stock battery life
