cutting perfect circles for sub box
2k1civic.com O. G.
how would i go about cutting perfect circles for a sub box?
what tool do i use?
any special tips?
thanks, not sure if this should have went into TECH, or ICE.
what tool do i use?
any special tips?
will you make out with me
Just use a jigsaw and a compass. it's not that hard to cut a good line
If you want to get tricky, some jigsaws have a metal 'stick' on them that you can put in a hole and make a good circle...but I would just draw one out with a compass and cut it freehand.
2k1civic.com O. G.
was it a large 'plug in' dremel? becuase i have a small battery powered dremel. i dont think there is a circle attachment.
was it this thing?
http://www.dremel.com/productdisplay...5&Color=99CCFF
was it this thing?
Same dremel, different attachment..... you have to buy the attachment. It's just a small adjustable metal piece that attaches to the end.
this is what it looks like: http://www.toolpeddler.com/960-01.htm
2k1civic.com O. G.
oHHHHH
i see now
thanks
u rock!
but on the down sides.. seems like my dremel wont work with that. i need to get the 80 dollar drill
http://www.toolpeddler.com/9000-04.htm
i see now
thanks
u rock!
you could use a hand saw, the dremel is harder to cut than a jigsaw...you have trouble with a jigsaw!?
What you need to do is cut under the line and then file the rest of the circle to the line drawn with the compass
Originally posted by AzNmiKex215
oHHHHH
i see now
thanks
u rock!
oHHHHH
i see now
thanks
u rock!
EDIt: i never used a fansy circle cutting thing. I used a compass drew a line and dremeled the hole, and used that big drill, AND used a jigsaw...Jigsaw works best. Drill may cut a lil smoother but will take longer.
If you have a router, i recomend the Jasper Jig from Parts Express . Cuts Perfect circles from 2-1/4" to 18-3/16". Its a lil pricey though if your only gonna make one circle cut though, $35.95.
If you don't have a router, you can get something very similar made by dremel (that does a lot more than a router) called a roto-zip. They make a hole cutting attachment for it, which goes up to 12" in diameter I think. I used it to make my box last time, makes dead on perfect circles that are clean cut. The rotozip usually sells for about $90 at Home Depot - its a tool that everyone should have!
juror
Suspension DIY
Jul 30, 2019 03:28 AM
Causemo
Jul 5, 2015 06:42 AM
