Slow Acceleration..
Old Nov 9, 2003
Dticalman01's Avatar
Dticalman01 is an unknown quantity at this point
Slow Acceleration..
Recently, I've been getting slower acceleration and lower gas mileage.. I only have about 24,000 Miles on my 02 Civic...and I don't know what is causing this. I don't know much about cars, but I do get my oil changes done every 5,000 miles... What things can contribute to this....Fuel Injectors, Bad Sparkplugs.? At 16,000 i accidentally had put diesel in my car..but I got it fixed immediately...Does the fact that I put diesel earlier have an effect on the way my car is performing right now?
This Monday I AM planning to go to the Honda Dealer and hopefully get it fixed under warranty. I have never done any warranty work before, so I'm Hoping they will cover this...
..I only have 24,000 miles on this car with 2 yrs of ownership..and acceleration doesn't seem to be as strong..it's just sorta stiff and doesn't punch as much...and gas mileage seems to be lower....Are these problems covered by Warranty... and what would they do on my car to clear up the problems....?
Old Nov 9, 2003
miklovo's Avatar
miklovo is an unknown quantity at this point
Well first off, you should have your car serviced every 3000 miles. Thats just good maintainence of your car. And when you put diesel in your car did you have your tank and fuel lines flushed or did they just run the pump through it? BC that would make a difference...definately. as long as they can't find any sign of customer abuse these things are usually covered by warranty.
Old Nov 9, 2003
If they only ran the Pump through it...what would I manually have to change..? Would changing the transmission fluid be needed at this point?
Old Nov 9, 2003
hoho's Avatar
hoho is an unknown quantity at this point
my car also seems like it has slow acceleration and lower gas mileage....i dunno if it's jus me but my car doesnt seem to save much gas....even my bro's v6 maxima sometimes saves more gas than me....and i dont beat the gas that much either
Old Nov 9, 2003
Stop double posting! I already told you what to do. Take it to the dealer first, then do a DIY tuneup.
-new plugs
-air filter
-tranny fluid
-tire pressure
fuel injector cleaner
Old Nov 9, 2003
SMURF_KILLER's Avatar
SMURF_KILLER is an unknown quantity at this point
you need to go to the dealer and get a major tune up on your car. They do the full service and its a good one too. I felt a difference in performance when I did this and you need to do OIL changes every 3000 miles like most people do it will prolong your motor than doing it all the time at 5000 miles. About the Diesel, how did you do that????
Old Nov 9, 2003
Repair..
How much did it cost you...? how much does it cost w/out warranty...
Old Nov 9, 2003
YS's Avatar
YS
YS is an unknown quantity at this point
i do:
- oil change every 3500 miles
- fuel injection cleaner every 5000 miles
- re-Charge my KN&N drop-in filter every 5000 or whenever dirty
- oil filter every 7000 miles
- Tranny fluid flush @ 15000 miles
- i haven't change my spark plug (NGK Laser Platinum) since 1500 miles (now 25000)
- use 89 gasoline everyday and 91 gasoline once every year for my car b'day
- major maintenance ever year for my car b'day
and my car still get 375 - 425 miles per tank, smooth engine
Old Nov 9, 2003
JDMTUNED01's Avatar
JDMTUNED01 is an unknown quantity at this point
Originally posted by YS
i do:
you change your oil without changing your oil filter? what kinda sense does that make? clean honey colored oil and a dirty *** filter. come on man......
Old Nov 10, 2003
I took it to the dealer..and they said there's nothing wrong with the car except that the transmission fluid may be dirty.....
It costs $140 to flush the transmission...if I cleaned that out..will that fix my acceleration problem..?
Old Nov 10, 2003
HustleLikeMOFO's Avatar
HustleLikeMOFO is an unknown quantity at this point
exactly how many miles do you get out of of a full tank of gas?
Old Nov 10, 2003
22-25
Old Nov 10, 2003
^^ Me too! But 25 is pretty rare.
Old Nov 10, 2003
Old Nov 11, 2003
Tranny fluid will make the auto tranny shift smoother and maybe improve acceleration. It's worth a try, as are new plugs if the old ones are dirty. DIY and save the $$.
Old Nov 11, 2003
miklovo's Avatar
22-25 MPG right???
and yes you need to go and have Honda do the 30000 mile tune up on your car, it will make a difference. they quoted me at about $350 for the whole thing, but if you take it to a reliable non-honda shop most of them will do it for about $200-$225. just make sure they work on imports, cuase yoiu can get some of those guys that don't know what the hell theyn are doin and then you just wasted your 200 bucks!
Old Nov 11, 2003
What exactly do they do for the tune up?
Old Nov 14, 2003
03civicdx's Avatar
03civicdx is an unknown quantity at this point
tune it up and get the tranny flushed make sure they flush it and not just empty and refill alot of places do that it it doesnt help but if you get it fully flushed then that should help the shifting and the acceleration
Old Nov 14, 2003
Slow acceleration on a civic? impossible.
Old Nov 14, 2003
civic-king's Avatar
civic-king is an unknown quantity at this point
sorry to tell you, but there is no "flushing" of the transaxle on a honda.
if you use a machine, the chemical they pump into it can destroy the tranny.
they just drain and fill.
DIY = $29
Old Nov 14, 2003
DIY = $29
Is it a lot more efficient in performance wise to do ourselves?
And also..if i do a DIY...how does the cost come out to be $29
Old Nov 17, 2003
civic-king's Avatar
the fluid costs like 9.00 a bottle.
you need three...
2.00 for a soda to drink.
Old Nov 17, 2003
CivicsRdBest's Avatar
Yeah, you should change the oil more often and get the tune-ups @ Honda because they will check everything important and stuff that normal use will consume.
Old Nov 17, 2003
FuzzBeC00L's Avatar
Fuzzy Boy
use 89 gasoline everyday and 91 gasoline once every year for my car b'day Y ARE U PUT 91 IN OR CARS IT DONT DO ANYTHING
Old Nov 17, 2003
audioefx3's Avatar
audioefx3 is an unknown quantity at this point
91 octane might not make a difference in performance but it is better for your car. It is more refined than 87 and cleaner burning. In the long run 91 octane is better for your car.
Old Nov 17, 2003
SMX's Avatar
SMX
SMX is on a distinguished road
Using 91 octane in our cars is a waste of your hard earned money.
Old Nov 17, 2003
Zzyzx's Avatar
Autocross Junky
^^^ yup ^^^^
The octane rating of gasoline tells you how much the fuel can be compressed before it spontaneously ignites. Higher octane ratings can withstand Higher compression levels wich is why High compression engines and Forced induction cars need it. to prevent Knocking. that is the ONLY Reason!.
It is not refined better nor does it burn better/cleaner.
Since our cars are not High compression engines, runnig a high octane gas is more or less worthless.
The detergents that each brand use are added to ALL of their fuels (unless other wise specified).
Old Nov 17, 2003
When are you people gonna learn, 91 octane gas is a waste of money. If you want more performence and for your engines to last longer in the "long run", then you shouldnt put anything in your Civic besides Diesel. Trust me, Diesel is the way to go.
Old Nov 18, 2003
Renamazazo's Avatar
Renamazazo is an unknown quantity at this point
uh... Diesel in a 7thgen civic would really **** things up, all that lead will clog your catalytic converter then they'd have to replace it.
Old Nov 18, 2003
SMX's Avatar
SMX
I was thinking a 50/50 diesel and 91 Octane mix. That way I get all the benefits of a diesel engine (high torque off idle) with all the benefits of a high compression engine that needs 91 octane. And it would run clean thanks to the better refined 91 octane gas so the diesel wouldn't plug the cat. I could route exhaust gases out through a vertical exhuast riser on my rear bumper (5 ft tall or so) so during low rpm use to maximize torque. At high rpms it could switch to a twin can dual exhaust.
Is there a sticker I can put on my car to brag about this custom race mix???
