Front wheel alignment SPC camber bolt
Old Nov 11, 2003
cdmx's Avatar
I dont know what i did wrong, all i did was try to alighn the wheels straight and now my steering wheel is crooked. The H symbol is cooked to the left (steering wheel is slightly turned left when wheels are straight)
What did i do wrong. and i tried to take the camber bolts out and put the stock bolts out and i CANT. Ahh....i dont want to spend More money. i just called ntb and they want 59.99 to do alignment.
Old Nov 11, 2003
PunkingCivic's Avatar
I need TP for my bunghole
look above the pedals and you can adjust the steering wheel after to have the wheels straight.
Old Nov 11, 2003
Here is a diagram of the steering colume
Old Nov 11, 2003
BlackIce's Avatar
BlackIce is an unknown quantity at this point
I thought you had to get an alignment once you installed the camber kit. Wouldnt it be a good thing to do anyway...?
Old Nov 11, 2003
IDQcivic's Avatar
IDQcivic should not be trusted
yeah definitly go to a shop and get it done right, preferably with a computerized alignment... don't just try guessing....
Old Nov 11, 2003
Kairi's Avatar
Kairi is an unknown quantity at this point
what's the specific process to aligning the steering wheel straight? My car is aligned proper but the steering wheel aint, and the damn dealership said "we can't make it straight, sir."
Old Nov 11, 2003
it appears in the diagram that it a clamp type tightener
with a groved patter in the clamp and on the shaft.
just unbolt pry it open a little
get it where you want it
and bolt tight I would guess.
Old Nov 11, 2003
cdmx's Avatar
my steering wheel is ok, i just fixed the R side camber bolt and it rides much better. As soon as i have the time im going to take it to a shop and get it done right.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
Tedverseti
Apr 23, 2020 01:45 PM
edspyhill09
Jun 12, 2016 02:45 PM
bsmiley
Apr 27, 2015 01:27 PM
crazydragon
Nov 7, 2001 05:13 PM
