Replacing Axle
Old Oct 15, 2003
xblkcivicx's Avatar
xblkcivicx is an unknown quantity at this point
Question Replacing Axle
I need to replace the drivers front axle on my 01 civic ex coupe and was wondering if anyone has replaced any axles yet. More importantly is there anything unusual or any tricks to replacing it. If it's the same as the previous gens then it's all good, just wondering if honda messed with anything with the 7th gen. Thanks
Old Oct 15, 2003
C2i0v0i1C's Avatar
SuperMODrizd
ask them (honda), also what did u do to need one
Old Oct 15, 2003
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
mines were starting to click from all the street racing... so i replaced mines, there is a bolt that connects the axel to the brake disk, that is a bitch to removed, you need like a 22mm socket to remove it, i forgot what size, just call honda to ask em or take it to an auto shop to size it up the bolt, then you need a straight bar to remove it, or a large rachet, i broke a half inch rachet bar and bent a 3 corter inch rachet trying to remove mines, so they are on pretty tight, it took one person standing on the rachet bar and one pulling on it just to remove the bolts, after you remove the bolts stick a standart screw drive between the axel and the tranny case to separate them, after you put the new ones back tap them in at the end of the axel with a hammer, a few light taps and you will here em pop back in place, they cost me like 180 all together for the axles, when you remove them be sure you are not in the way because transmission fluid will spill out the axel holes, but not that much to worry about, it took only like 30mins to change out, if you have any other questions pm me or hit me up on yahoo SODJAZERO
Old Oct 15, 2003
xblkcivicx's Avatar
So basicly the same as any other honda...I've pulled the axle from the hub before to replace a lug bolt, but i didn't pull it from the tranny...that was my question... DAMN! where did you get "them" for 180!? around here (RI) they are 300.00 each. (247) was a deal i got from majestic. Thanks for the info!
Old Oct 15, 2003
xblkcivicx's Avatar
civic: The CV boot ripped..I tried to keep it greased. I can't stand the tie up replacement boots, so i just let it ride and now it's clickin like a motha-fka.. time to replace...not a biggie..i was just wonderin if there were any "surprises" that honda liked to throw at the 7th gen heh...
Old Oct 16, 2003
acidbaby's Avatar
The Beez Kneez
im getting a cliking noise when i take turns left or right is that the sam ething you are talking about? i thought it was chassis flex or bad springs?
Old Oct 16, 2003
Elite's Avatar
Elite is an unknown quantity at this point
yeah me too I only get like a smooth clicking but not that noticable when I brake hard, or like it starts at 20 to around 5 mph and it stops what is it? I did get in an accident also.
Old Oct 16, 2003
Elite's Avatar
you can't actually hear it but you can feel it when you brake, I've told my friends if they can hear it but they can hardly hear it.
Old Oct 16, 2003
xblkcivicx's Avatar
Acidbaby, yes that is what happens...it clicks around corners and during accell and decelleration. If you tap the gas and get out tap and get out it will go click...click click...click click...click It will click when the front end lifts and when it noses over...And MORE around corners, especially if your stopped and just turning your wheel...I hate it..
Good luck
Old Oct 16, 2003
xblkcivicx's Avatar
Elite, im not sure what a smooth clicking is, and if it happens during braking, during a certain mph i doubt it is the axle...it would be doing what i described above (IF its the CV joint that is...) You might have a brake problem.
I got a clicking during braking after i did my suspension, it turned out to be the shield plate behind the rotor was bent a little toward the rotor and would click almost exactly as you described it...Something to check out if its comming from only one side of the car and you just did brakes or well could be from your accident...
Not much else i could tell ya..i dont really understand smooth clicking.
good luck!
Old Oct 16, 2003
SODJAZERO's Avatar
usualy you can get your axels rebuilt with a life time warrenty, at least thats what ALTERNATIVE MOTORSPORTS promisses!! but the axles on the new civic are week, i can only imagine what civics wit fi are going thru..... 1
Old Oct 17, 2003
Em2Guy's Avatar
Em2Guy is an unknown quantity at this point
i have some that id sell if u guys need some pm with an offer
Old Oct 17, 2003
xblkcivicx's Avatar
Brand new? Rebuilt? Used w/ how many miles?
hans.pcguy
May 16, 2015 09:54 PM
R3KogHyZe
May 13, 2015 01:22 PM
Jigee
May 9, 2015 11:18 AM
thesushiboy
Apr 12, 2015 02:54 AM
0100010
Feb 1, 2002 10:26 PM
