IN TANK or IN LINE FUEL PUMP for RETURN Conversion
Old Nov 3, 2003
SpdRcrChk's Avatar
BOOST JUNKY
SpdRcrChk is an unknown quantity at this point
Hey there people.
Techies, please help.
I'm planning on converting to a RETURN fuel system on my 2k1 Coupe. I was about to order the WALBORO 255lph, when I thought....is it an IN TANK F/P that I need...or an IN LINE F/P that I need to order? Can anyone help with this??
Also....if some1 can get me a part # it would be awesome.
Old Nov 3, 2003
jwalker87's Avatar
Bodacious Member
jwalker87 is an unknown quantity at this point
i know im not really heping, but consider just buying the SF fuel kit. From what I've heard, its one of the best out there, and extremely simple to install. Just a thought.
Old Nov 3, 2003
SpdRcrChk's Avatar
BOOST JUNKY
I"m not sure what the SF Fuel kit includes. But if it has anythin' to do with an FMU, I'm going to skip on that.
What I'm trying to accomplish here is converting to a return fuel system utilizing a walbro fuel pump and managing fuel via the v-afc and using some aftermarket injectors. Build your own.....kinda deal.
Thanks for the suggestion though. I will look into it.
Old Nov 3, 2003
atl01's Avatar
this has been an atl01 production..
atl01 will become famous soon enough
I dont think that they make the walboro in-tank pump for our year civics. At least they didnt when i bought mine. I bought the one for the 99 Si and made it work .
Old Nov 3, 2003
KingTorq's Avatar
KingTorq is an unknown quantity at this point
wallboro has two 255 pumps available, one of them provides much higher pressure and is the same price. I think that would be more than sufficient for even a radical civic. Personally i would always shop around for an intank to do the job, rather then an inline (just for the noise factor)
Old Nov 3, 2003
SpdRcrChk's Avatar
BOOST JUNKY
Well When we called earlier they only offered an in line pump for my application. Can you tell me how you made the 99 Si one work for you??
Old Nov 4, 2003
opto_isolator's Avatar
The SF kit is fine - it is an inline pump setup. But it has limitations. For one it is "custom tuned" for their boost setup. Every car / turbo setup is different. If you want to push your car / hp / etc - get the return system and tune it. If you want to just slap it in and go, get the SF kit.
I personallly am going the semi-custom route. From what I have heard and read on here, doing the return conversion isn't all that hard - the hardest part is the fuel rail, which has to be modified since AEM doesn't have their rail released for our cars yet (if ever).
The Walbro 255 in take pump is supposed to fit our cars like a glove (again, from what I've read). But there are some other modifications that need to be performed in the tank - such as disabling the in tank regulator.....
Old Nov 4, 2003
robbclark1's Avatar
Retired suspension supermod.
PM boosted2k2. He converted his to a return fuel system.
Old Nov 4, 2003
SpdRcrChk's Avatar
BOOST JUNKY
I've already PM'd Boosted2k2 and he's been extremely helpful. As have been alot of people on the boards.
FYI...the IN TANK pump to use is the one for 92-00 civics. It takes some modification, as some1 else mentioned in this thread.... I will keep you all posted.
Old Nov 5, 2003
atl01's Avatar
the walboro pump is a little longer than the stock one, so its hard to get it to fit into the shell.
Old Nov 5, 2003
What did you do to make it fit than? Force it?
Old Nov 6, 2003
atl01's Avatar
No. it fits is just a real tight fit.
Old Nov 6, 2003
C2i0v0i1C's Avatar
SuperMODrizd
i used zip ties to hold the casing together
Old Nov 6, 2003
BREEZE's Avatar
Yeah, i drive an EP
BREEZE is an unknown quantity at this point
zip ties......good as duct tape
Old Nov 24, 2003
showtyme's Avatar
showtyme is an unknown quantity at this point
I have the 255lph Walbro intank pump in my car and it works just fine. I would recommend the intank pumps just because the 255 lph pumps are so loud. All the Civics from 92-up use the same harness connection so you can use any fuel pump for civics in those years. The fit is sorta tight in the shell with the Walbro but it works just fine. Hope this helps you out a little.
Old Dec 10, 2003
Don't mind me reviving this - but what fuel pressure regulators would work with forced induction application?
CarStuff
Dec 6, 2020 12:52 PM
McD
Apr 29, 2015 03:50 PM
Trav_02civic
Engine start problems
Apr 23, 2015 08:57 AM
McD
Apr 22, 2015 05:28 PM
