performance chip?
Old Nov 14, 2003
blacklight03's Avatar
blacklight03 is an unknown quantity at this point
performance chip?
Is there a performance chip that actually works worth a damn? i see alot on ebay and just wondered if they were worth it.
Old Nov 14, 2003
Jodster's Avatar
Post Whore General
None of them on ebay are worth it. Jet chip makes a ECU reflash for us. Check our the Group buy section.
Old Nov 16, 2003
d17lucas's Avatar
d17lucas is an unknown quantity at this point
what is a ECU reflash? all i see form jet is that you send your ecu out and that reprogram it for you
get back
Old Nov 16, 2003
cdmx's Avatar
this is your second topic about the same subject in an hour!?
I told you to search
IBTL
Old Nov 16, 2003
cdmx's Avatar
JET FLASHES YOUR ECU AND "BURNS" A NEW PROGRAM IN
Old Nov 16, 2003
cdmx's Avatar
yep, all that money for a simple program..
Old Nov 16, 2003
cdmx's Avatar
I say you buy a S-AFC or V-AFC 2
Old Nov 16, 2003
CrankinCivic's Avatar
CrankinCivic is an unknown quantity at this point
are the gains the same with the s-afc or the jet chip ?
Old Nov 17, 2003
tell me where to find either one of those at so i can buy it. i cant find jack.
Old Nov 17, 2003
C2i0v0i1C's Avatar
SuperMODrizd
jet is worthless, they cant really do anything important i asked them at SEMA, the guy said the emanage can over ride ne thing they could do to it, the only thing we need to have done to the ecu is remove the fuel cut
Old Nov 17, 2003
Eeeeeeh's Avatar
Eeeeeeh is an unknown quantity at this point
How much would it be to remove the fuel cut?? And is it safe for our engines if your shifting at 7500 or more during a race???
Old Nov 17, 2003
ELaudio's Avatar
ELaudio is an unknown quantity at this point
Chip ugrades/S-AFC/V-AFC 2 - I have a question. Can any of these offer hp gains to a normally aspirated (with Intake/Header/Exhaust) D17? I know with the latter two, you can adjust your fuel curve (and VTEC timing on one of them I think), but does this translate to more power?
Old Nov 17, 2003
yea how much to do the fuel cut and im not sure about the shifts, although im just wanting this mod for tailgaters and such not racing.
Old Nov 17, 2003
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
here is what the eBay intake chip is....
it is really the intake sensor override!!
http://www.grandamgt.com/iatoverride.html
Old Nov 17, 2003
kjgracing's Avatar
bassically JETCHIp re-maps the fuel for 87 octane and advances the ignition timing 5 degrees.
Old Nov 17, 2003
cdmx's Avatar
dezod has the chip
Old Nov 17, 2003
which is better ? people say its cool and some say its not i wanna know if its worth the 200 bux or so to get it done , or should i just get a Sfac and put my car back on the dyno and move my cam gear again to get that lil better gain ?
Old Nov 17, 2003
Diemos's Avatar
Diemos is an unknown quantity at this point
It is a car, you are putting additional stress on the engine. Pre-mature engine wear. So, depends on how you look at it. Yes, or no depending on how much you value your car.
- Diemos
EDIT: Besides, there is a point at which a car stops developing more horsepower and torque. The added stress would not be worth the minimal if any additional power gained.
Old Nov 18, 2003
C2i0v0i1C's Avatar
SuperMODrizd
therefore being useless, fuel cut removal cost.....dont know bc i dont know of ne one that is able to do it yet or that has already done it, and the genious thats up a few posts how are u reving to 7500, the most ive ever been able to hit is like 7020, just letting it bounce off limiter and hoping for the highest number
Old Nov 18, 2003
ELaudio's Avatar
Keep in mind the redline is not a solid brick wall. You can safely rev your engine past redline, occasionally, without doing any damage.
Old Nov 18, 2003
Zzyzx's Avatar
Autocross Junky
the question is: is it worth reving past redline???? our torque peaks at 4800 RPM, redline is 7,000? that means that past 4800 rpm we are accelerating slower and slower and slower untill the point that the acceleration in the current gear would be less then the acceleration in the next (which is where you want to shift). So, where is this point, before 7,000 rpms or after?
Oh ya, I have an EX Peak torque is at 4800 for the rest its at 4500.
Personally I dont think theres any worth to not having a revlimiter (On a stock engine i.e. one with out internal modification or forced induction. Headder and intake dont count).
Old Nov 18, 2003
damn i started a WAR lol
Old Nov 18, 2003
SMX's Avatar
SMX
SMX is on a distinguished road
Redline is usually limited primarily due to such things as connecting rod stretch, weak cast pistons, and floating valves. You can run any engine past its redline. The question is what fails first and what are the consequences. Best case you bend a valve or two. Worst case you send a rod through the side of your block.
Unless you put together a forged bottom end, I wouldn't mess too much with removing rev limiters. You can do it on a stock engine, but why.
You can run 10 grand on a I4 or even a V8, but you better have it put together right.
Old Nov 18, 2003
Aaggie77's Avatar
Aaggie77 is an unknown quantity at this point
Back to the subject........
Old Nov 18, 2003
scivic02's Avatar
scivic02 is an unknown quantity at this point
I have the jet upgrade on my car it did nothing but fuc up my air fuel ratio i had it on the dyno at to different shops they both said the same thing they messed your ecu up so i called them and they said they cant do anything else so in the end im fuced
Old Nov 20, 2003
C2i0v0i1C's Avatar
SuperMODrizd
Re: performance chip?
so anyways NO, and the ones on ebay are REALLY not worth it, bc if they aint JET, then i dont think there is ne thing else that they make and JET wouldnt be selling them on ebay
Old Nov 20, 2003
Jodster's Avatar
Post Whore General
If you want ECU work done, call Hondata and see what they can do about a custom ECU reflash for you. And until you have some Valve train work done, you can not rev much high than stock redline.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
carid
Sep 28, 2015 10:13 AM
ttamrekab
Sep 28, 2015 01:22 AM
MamaBear2015
Sep 27, 2015 06:31 PM
Jrosa
Sep 14, 2015 08:24 PM
